按键控制数码管
- # include <reg52.h>
- sbit ADDR0 = P1^0;
- sbit ADDR1 = P1^1;
- sbit ADDR2 = P1^2;
- sbit ADDR3 = P1^3;
- sbit ENLED = P1^4;
- sbit KEY_IN_1 = P2^4;
- sbit KEY_IN_2 = P2^5;
- sbit KEY_IN_3 = P2^6;
- sbit KEY_IN_4 = P2^7;
- sbit KEY_OUT_1 = P2^3;
- sbit KEY_OUT_2 = P2^2;
- sbit KEY_OUT_3 = P2^1;
- sbit KEY_OUT_4 = P2^0;
- unsigned char code LedChar[] = {
- 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E
- unsigned char KeySta[4][4] = {
- {1,1,1},{1,1,1},{1,1,1},{1,1,1}
- void main()
- unsigned char i,j;
- unsigned char backup[4][4] ={
- EA = 1;
- ENLED = 0;
- ADDR3 = 1;
- ADDR2 = 0;
- ADDR1 = 0;
- ADDR0 = 0;
- TMOD = 0x01;
- TH0 = 0xFc;
- TL0 = 0x67;
- ET0=1;
- TR0 = 1;
- P0 = LedChar[0];
- while(1)
- for(i=0;i<4;i++)
- for(j=0;j<4;j++)
- if( backup[i][j]!=KeySta[i][j])
- if( backup[i][j]!=0)
- P0 = LedChar[i*4+j];
- backup[i][j] = KeySta[i][j];
- void InterruptTimer0()interrupt 1
- unsigned char i;
- static unsigned char keyout = 0 ;
- static unsigned char keybuf[4][4] ={
- {0xFF,0xFF,0xFF,0xFF}, {0xFF,0xFF,0xFF,0xFF}, {0xFF,0xFF,0xFF,0xFF}, {0xFF,0xFF,0xFF,0xFF}
- TH0 =0xFC;
- TL0 = 0x67;
- keybuf[keyout][0] = (keybuf[keyout][0]<<1)|KEY_IN_1;
- keybuf[keyout][1] = (keybuf[keyout][1]<<1)|KEY_IN_2;
- keybuf[keyout][2] = (keybuf[keyout][2]<<1)|KEY_IN_3;
- keybuf[keyout][3] = (keybuf[keyout][3]<<1)|KEY_IN_4;
- for(i=0;i<4;i++)
- if((keybuf[keyout][i]&0xFF) == 0x00 )
- KeySta[keyout][i] =0;
- else if((keybuf[keyout][i]&0xFF) ==0x0F)
- KeySta[keyout][i] =1;
- keyout++;
- keyout = keyout & 0x03;
- switch(keyout)
- case 0: KEY_OUT_4 =1;KEY_OUT_1 =0;break;
- case 1: KEY_OUT_1 =1;KEY_OUT_2 =0;break;
- case 2: KEY_OUT_2 =1;KEY_OUT_3 =0;break;
- case 3: KEY_OUT_3 =1;KEY_OUT_4 =0;break;
- default: break;
shuma44.zip
(854 Bytes, 下载次数: 7)
