查看: 7943|回复: 16
共阳极数码管 段选位与上 0xf7 后小数点显示 数字却不显示了 是什么原因
ID:377512 发表于 2018-7-28 18:10 | 显示全部楼层 |阅读模式
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define MAIN_Fosc                11059200UL
  5. typedef unsigned int INT16U;
  6. sbit DU = P2^6;
  7. sbit WE = P2^7;
  8. uchar code table[]={
  9. //         0                1           2          3                  4                5
  10.         0xc0,  0xf9,  0xa4,  0xb0,  0x99,  0x92,
  11. //         6                 7                8           9          .                 关显示
  12.     0x82,  0xf8,  0x80,  0x90,  0x7f,   0xff
  13. };
  14. uchar code T_COM[] = {
  15. //1      2     3       4     5      6
  16. 0x01,  0x02,  0x04,  0x08,  0x10,  0x20
  17. };
  18. void Delay_Ms(INT16U ms)
  19. {
  20.      INT16U i;
  21.          do{
  22.               i = MAIN_Fosc / 96000;
  23.                   while(--i);   //96T per loop
  24.      }while(--ms);
  25. }
  26. void Display(uchar z)
  27. {
  28. //------------------------------
  29.         DU = 0;
  30.         P0 = table[z];
  31.         DU = 1;
  32.         DU = 0;
  33.         WE = 0;
  34.         P0 = T_COM[0];
  35.         WE = 1;
  36.         WE = 0;
  37.         Delay_Ms(3);
  38. //-------------------------------
  39.         DU = 0;
  40.         P0 = table[z] & 0x7f;
  41.         DU = 1;
  42.         DU = 0;
  43.         WE = 0;
  44.         P0 = T_COM[1];
  45.         WE = 1;
  46.         WE = 0;
  47.         Delay_Ms(3);
  48. //------------------------------
  49.         DU = 0;
  50.         P0 = table[z];
  51.         DU = 1;
  52.         DU = 0;
  53.         WE = 0;
  54.         P0 = T_COM[2];
  55.         WE = 1;
  56.         WE = 0;
  57.         Delay_Ms(3);
  58. //-------------------------------
  59.         DU = 0;
  60.         P0 = table[z] & 0x7f;
  61.         DU = 1;
  62.         DU = 0;
  63.         WE = 0;
  64.         P0 = T_COM[3];
  65.         WE = 1;
  66.         WE = 0;
  67.         Delay_Ms(3);
  68. //------------------------------
  69.         DU = 0;
  70.         P0 = table[z];
  71.         DU = 1;
  72.         DU = 0;
  73.         WE = 0;
  74.         P0 = T_COM[4];
  75.         WE = 1;
  76.         WE = 0;
  77.         Delay_Ms(3);
  78. //-------------------------------
  79.         DU = 0;
  80.         P0 = table[z] & 0x7f;
  81.         DU = 1;
  82.         DU = 0;
  83.         WE = 0;
  84.         P0 = T_COM[5];
  85.         WE = 1;
  86.         WE = 0;
  87.         Delay_Ms(3);
  88. }
  89. void main()
  90. {
  91.   Display(0);
  92. }
想不太明白  DP最高位为0的时候会亮  如果输出0 十六进制是 c0 二进制就是 1100 0000 与上 0x7F   0111 1111  变成 0100 0000  没想到有啥毛病  数码一直不显示
ID:96682 发表于 2018-7-29 03:13 | 显示全部楼层
楼主列出的二进制也不完全对啊
ID:377512 发表于 2018-7-29 08:45 来自手机 | 显示全部楼层
wc86110 发表于 2018-7-29 03:13
楼主列出的二进制也不完全对啊
哪里不对
ID:380415 发表于 2018-7-29 10:29 | 显示全部楼层
在实际中要做消影操作
ID:213173 发表于 2018-7-29 10:37 | 显示全部楼层
楼主要在显示程序里每位送段码前加消隐语句!
        P0 = 0xff;//消隐
        DU = 1;//开段选
        DU = 0;//关段选
        P0 = table[z];//送段码
        DU = 1;//开段选
        DU = 0;//关段选
        WE = 0;//赘句
        P0 = T_COM[0];//送位码
        WE = 1;//开位选
        WE = 0;//关位选
        Delay_Ms(3);
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:375003 发表于 2018-7-29 10:50 | 显示全部楼层
问题在这里,因为这个点不是在每个位上,如果要显示小数点的时候,先要判断这个位有没有小数点
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:155507 发表于 2018-7-29 12:16 | 显示全部楼层
要数码显示, 你把Delay_Ms(3);  设置成Delay_Ms(9);
ID:377512 发表于 2018-7-29 12:42 来自手机 | 显示全部楼层
共阳极 直接和 0x7f与 最高位为0 数据的最高位也为0 这样就不需要判断了
ID:377512 发表于 2018-7-29 13:07 来自手机 | 显示全部楼层
设置成9之后数码管交替显示 还是不是一起显示 延时的时间太长了
ID:377512 发表于 2018-7-29 13:10 来自手机 | 显示全部楼层
去了小数点就可以完全显示
ID:261288 发表于 2018-7-29 20:40 | 显示全部楼层
段码”或“0x7f才能显示
ID:140489 发表于 2018-7-30 09:34 | 显示全部楼层
段码”或“0x7f才能显示,才是正解,
ID:377512 发表于 2018-7-30 10:43 来自手机 | 显示全部楼层
lids 发表于 2018-7-30 09:34
段码”或“0x7f才能显示,才是正解,
要是或的话 数据有一位是0和1或之后是 1 改变了数据的值 比如 1010 1010按位或0111 1111 变成 1111 1111 或有一个值为1 则为1
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:213173 发表于 2018-7-30 17:53 | 显示全部楼层
李博文 发表于 2018-7-30 10:43
要是或的话 数据有一位是0和1或之后是 1 改变了数据的值 比如 1010 1010按位或0111 1111 变成 1111 1111  ...
楼上好多朋友是瞎猜,此程序的共阳数码管加点当然是 P0 = table[z] & 0x7f; 。由于段码与位码共用P0,不加消隐指令肯定会出问题。楼主认为去掉 & 0x7f就显示正常的说法是不正确的,只是楼主用仿真软件看不出来,要是实际电路就可以看出问题来了。给你改了一下,你试试。#include<reg52.h>
#include<intrins.h>
sbit DU = P2^6;
sbit WE = P2^7;
//         0                1           2          3                  4                5
//         6                 7                8           9          .                 关显示
//1      2     3       4     5      6
     INT16U i;
         do{
     }while(--ms);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        P0 = table[z];
        DU = 1;
        DU = 0;
        P0 = T_COM[0];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        DU = 1;
        DU = 0;
        P0 = T_COM[1];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        P0 = table[z];
        DU = 1;
        DU = 0;
        P0 = T_COM[2];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        DU = 1;
        DU = 0;
        P0 = T_COM[3];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        P0 = table[z];
        DU = 1;
        DU = 0;
        P0 = T_COM[4];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        DU = 1;
        DU = 0;
        P0 = T_COM[5];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
                Display(0);
参与人数 2黑币 +15 收起 理由
NPC-1024 + 8 回帖助人的奖励!
李博文 + 7 很给力!
ID:377512 发表于 2018-7-30 19:46 | 显示全部楼层
wulin 发表于 2018-7-30 17:53
楼上好多朋友是瞎猜,此程序的共阳数码管加点当然是 P0 = table[z] & 0x7f; 。由于段码与位码共用P0,不 ...
我用八位共阳极的数码管怎么 只显示小数点 和后两位数
ID:213173 发表于 2018-7-31 05:35 | 显示全部楼层
ID:377512 发表于 2018-7-31 11:22 来自手机 | 显示全部楼层
wulin 发表于 2018-7-31 05:35
这与使用八数码管没有什么关系,程序是显示六位,后两位闲置而已。
一直没出来这样的效果
