#include "si446x.h"
#include "include_.h"
const u8 config_table[] = RADIO_CONFIGURATION_DATA_ARRAY;
extern u8 RecvFlag,SendFlag;
SI446X_WAIT_CTS( );
Function : wait the device ready to response a command
INTPUT : NONE
OUTPUT : NONE
void SI446X_WAIT_CTS( void )
u8 cts;
do
SI_CSN_LOW();
SPI_ExchangeByte( READ_CMD_BUFF );
cts = SPI_ExchangeByte(0xFF);
SI_CSN_HIGH();
}while( cts != 0xFF );
SI446X_CMD( );
Function : Send a command to the device
INTPUT : cmd, the buffer stores the command array
cmdsize, the size of the command array
OUTPUT : NONE
void SI446X_CMD( u8 *cmd, u8 cmdsize )
SI446X_WAIT_CTS( );
SI_CSN_LOW( );
while( cmdsize -- )
SPI_ExchangeByte( *cmd++ );
SI_CSN_HIGH( );
SI446X_POWER_UP( );
Function : Power up the device
INTPUT : f_xtal, the frequency of the external high-speed crystal
OUTPUT : NONE
void SI446X_POWER_UP( u32 f_xtal )
u8 cmd[7];
cmd[0] = POWER_UP;
cmd[1] = 0x01;
cmd[2] = 0x00;
cmd[3] = f_xtal>>24;
cmd[4] = f_xtal>>16;
cmd[5] = f_xtal>>8;
cmd[6] = f_xtal;
SI446X_CMD( cmd, 7 );
SI446X_READ_RESPONSE( );
Function : read a array of command response
INTPUT : buffer, a buffer, stores the data responsed
size, How many bytes should be read
OUTPUT : NONE
void SI446X_READ_RESPONSE( u8 *buffer, u8 size )
SI446X_WAIT_CTS( );
SI_CSN_LOW( );
while( size -- )
*buffer++ = SPI_ExchangeByte( 0xFF );
SI_CSN_HIGH( );
SI446X_NOP( );
Function : NO Operation command
INTPUT : NONE
OUTPUT : NONE
u8 SI446X_NOP( void )
u8 cts;
SI_CSN_LOW( );
cts = SPI_ExchangeByte( NOP );
SI_CSN_HIGH( );
return cts;
SI446X_PART_INFO( );
Function : Read the PART_INFO of the device, 8 bytes needed
INTPUT : buffer, the buffer stores the part information
OUTPUT : NONE
void SI446X_PART_INFO( u8 *buffer )
u8 cmd = PART_INFO;
SI446X_CMD( &cmd, 1 );
SI446X_READ_RESPONSE( buffer, 8 );
SI446X_FUNC_INFO( );
Function : Read the FUNC_INFO of the device, 7 bytes needed
INTPUT : buffer, the buffer stores the FUNC information
OUTPUT : NONE
void SI446X_FUNC_INFO( u8 *buffer )
u8 cmd = FUNC_INFO;
SI446X_READ_RESPONSE( buffer, 7 );
SI446X_INT_STATUS( );
Function : Read the INT status of the device, 9 bytes needed
INTPUT : buffer, the buffer stores the int status
OUTPUT : NONE
void SI446X_INT_STATUS( u8 *buffer )
u8 cmd[4];
cmd[0] = GET_INT_STATUS;
cmd[1] = 0;
cmd[2] = 0;
cmd[3] = 0;
SI446X_CMD( cmd, 4 );
SI446X_READ_RESPONSE( buffer, 9 );
SI446X_GET_PROPERTY( );
Function : Read the PROPERTY of the device
INTPUT : buffer, the buffer stores the PROPERTY value
GROUP_NUM, the group and number of the parameter
NUM_GROUP, number of the group
OUTPUT : NONE
void SI446X_GET_PROPERTY_X( SI446X_PROPERTY GROUP_NUM, u8 NUM_PROPS, u8 *buffer )
u8 cmd[4];
cmd[0] = GET_PROPERTY;
cmd[1] = GROUP_NUM>>8;
cmd[2] = NUM_PROPS;
cmd[3] = GROUP_NUM;
SI446X_READ_RESPONSE( buffer, NUM_PROPS + 1 );
SI446X_SET_PROPERTY_X( );
Function : Set the PROPERTY of the device
INTPUT : GROUP_NUM, the group and the number of the parameter
PAR_BUFF, buffer stores parameters
OUTPUT : NONE
void SI446X_SET_PROPERTY_X( SI446X_PROPERTY GROUP_NUM, u8 NUM_PROPS, u8 *PAR_BUFF )
u8 cmd[20], i = 0;
if( NUM_PROPS >= 16 ) { return; }
cmd[i++] = SET_PROPERTY;
cmd[i++] = GROUP_NUM>>8;
cmd[i++] = NUM_PROPS;
cmd[i++] = GROUP_NUM;
while( NUM_PROPS-- )
cmd[i++] = *PAR_BUFF++;
SI446X_CMD( cmd, i );
SI446X_SET_PROPERTY_1( );
Function : Set the PROPERTY of the device, only 1 byte
INTPUT : GROUP_NUM, the group and number index
prioriry, the value to be set
OUTPUT : NONE
void SI446X_SET_PROPERTY_1( SI446X_PROPERTY GROUP_NUM, u8 proirity )
u8 cmd[5];
cmd[0] = SET_PROPERTY;
cmd[2] = 1;
cmd[3] = GROUP_NUM;
cmd[4] = proirity;
SI446X_CMD( cmd, 5 );
SI446X_GET_PROPERTY_1( );
Function : Get the PROPERTY of the device, only 1 byte
OUTPUT : the PROPERTY value read from device
u8 SI446X_GET_PROPERTY_1( SI446X_PROPERTY GROUP_NUM )
u8 cmd[4];
cmd[2] = 1;
cmd[3] = GROUP_NUM;
SI446X_READ_RESPONSE( cmd, 2 );
return cmd[1];
SI446X_RESET( );
Function : reset the SI446x device
INTPUT : NONE
OUTPUT : NONE
void SI446X_RESET( void )
u32 x = 1000;
SI_SDN_LOW( ); //SI_SDN_HIGH( );
while( x-- );
SI_SDN_HIGH( ); //SI_SDN_LOW( );
SI_CSN_HIGH( );
x=100ul*10000;while(x--);
SI446X_W_TX_FIFO( );
Function : write data to TX fifo
INTPUT : txbuffer, a buffer stores TX array
size, how many bytes should be written
OUTPUT : NONE
void SI446X_W_TX_FIFO( u8 *txbuffer, u8 size )
SI_CSN_LOW( );
SPI_ExchangeByte( WRITE_TX_FIFO );
while( size -- ) { SPI_ExchangeByte( *txbuffer++ ); }
SI_CSN_HIGH( );
SI446X_SEND_PACKET( );
Function : send a packet
channel, tx channel
condition, tx condition
OUTPUT : NONE
void SI446X_SEND_PACKET( u8 *txbuffer, u8 size, u8 channel, u8 condition )
u8 cmd[5];
u8 tx_len = size;
SI446X_TX_FIFO_RESET( );
SI_CSN_LOW( );
#if PACKET_LENGTH == 0
tx_len ++;
SPI_ExchangeByte( size );
#endif
SI_CSN_HIGH( );
cmd[0] = START_TX;
cmd[1] = channel;
cmd[2] = condition;
cmd[3] = 0;
cmd[4] = tx_len;
while(NIRQ!=0);
SI_CSN_HIGH( );
cmd[0] = CHANGE_STATE;
cmd[1] = 0x03;
SI446X_CMD( cmd, 2 );
SI446X_START_TX( );
Function : start TX command
INTPUT : channel, tx channel
tx_len, how many bytes to be sent
OUTPUT : NONE
void SI446X_START_TX( u8 channel, u8 condition, u16 tx_len )
u8 cmd[5];
cmd[0] = START_TX;
cmd[1] = channel;
cmd[2] = condition;
cmd[3] = tx_len>>8;
cmd[4] = tx_len;
SI446X_READ_PACKET( );
Function : read RX fifo
INTPUT : buffer, a buffer to store data read
OUTPUT : received bytes
u8 SI446X_READ_PACKET( u8 *buffer )
u8 length, i;
SI446X_WAIT_CTS( );
SI_CSN_LOW( );
SPI_ExchangeByte( READ_RX_FIFO );
length = SPI_ExchangeByte( 0xFF );
#else
length = PACKET_LENGTH;
#endif
i = length;
while( length -- )
SI_CSN_HIGH( );
return i;
SI446X_START_RX( );
Function : start RX state
INTPUT : channel, receive channel
condition, receive condition
rx_len, how many bytes should be read
n_state1, next state 1
n_state2, next state 2
n_state3, next state 3
OUTPUT : NONE
void SI446X_START_RX( u8 channel, u8 condition, u16 rx_len,
u8 n_state1, u8 n_state2, u8 n_state3 )
u8 cmd[8];
SI446X_RX_FIFO_RESET( );
cmd[0] = START_RX;
cmd[1] = channel;
cmd[2] = condition;
cmd[3] = rx_len>>8;
cmd[4] = rx_len;
cmd[5] = n_state1;
cmd[6] = n_state2;
cmd[7] = n_state3;
SI446X_CMD( cmd, 8 );
Function : reset the RX FIFO of the device
INTPUT : None
OUTPUT : NONE
void SI446X_RX_FIFO_RESET( void )
u8 cmd[2];
cmd[0] = FIFO_INFO;
cmd[1] = 0x02;
Function : reset the TX FIFO of the device
INTPUT : None
OUTPUT : NONE
void SI446X_TX_FIFO_RESET( void )
u8 cmd[2];
cmd[0] = FIFO_INFO;
cmd[1] = 0x01;
SI446X_PKT_INFO( );
Function : read packet information
INTPUT : buffer, stores the read information
FIELD, feild mask
length, the packet length
diff_len, diffrence packet length
OUTPUT : NONE
void SI446X_PKT_INFO( u8 *buffer, u8 FIELD, u16 length, u16 diff_len )
u8 cmd[6];
cmd[0] = PACKET_INFO;
cmd[1] = FIELD;
cmd[2] = length >> 8;
cmd[3] = length;
cmd[4] = diff_len >> 8;
cmd[5] = diff_len;
SI446X_CMD( cmd, 6 );
SI446X_READ_RESPONSE( buffer, 3 );
SI446X_FIFO_INFO( );
Function : read fifo information
OUTPUT : NONE
void SI446X_FIFO_INFO( u8 *buffer )
u8 cmd[2];
cmd[0] = FIFO_INFO;
cmd[1] = 0x03;
SI446X_READ_RESPONSE( buffer, 3);
SI446X_GPIO_CONFIG( );
Function : config the GPIOs, IRQ, SDO
INTPUT :
OUTPUT : NONE
void SI446X_GPIO_CONFIG( u8 G0, u8 G1, u8 G2, u8 G3,
u8 IRQ, u8 SDO, u8 GEN_CONFIG )
u8 cmd[10];
cmd[0] = GPIO_PIN_CFG;
cmd[1] = G0;
cmd[2] = G1;
cmd[3] = G2;
cmd[4] = G3;
cmd[5] = IRQ;
cmd[6] = SDO;
cmd[7] = GEN_CONFIG;
SI446X_READ_RESPONSE( cmd, 8 );
void testinf(void)
SI446X_CMD( &Rf_Rec_Buf[0], 4 );
SI446X_POWER_UP( 0xffffff );
SI446X_READ_RESPONSE( &Rf_Rec_Buf[0], 4 );
SI446X_NOP( );
SI446X_PART_INFO( &Rf_Rec_Buf[0] );
SI446X_FUNC_INFO( &Rf_Rec_Buf[0] );
SI446X_INT_STATUS( &Rf_Rec_Buf[0] );
SI446X_GET_PROPERTY_X( 3, 4, &Rf_Rec_Buf[0] );
SI446X_SET_PROPERTY_X( 3, 4, &Rf_Rec_Buf[0] );
SI446X_SET_PROPERTY_1( 3, 3 );
SI446X_GET_PROPERTY_1( 3 );
SI446X_RESET( );
SI446X_CONFIG_INIT( );
SI446X_W_TX_FIFO( &Rf_Rec_Buf[0], 4 );
SI446X_SEND_PACKET( &Rf_Rec_Buf[0], 8, 4, 4 );
SI446X_START_TX( 4, 4, 4 );
SI446X_START_RX( 3, 3, 3,
3, 3, 3 );
SI446X_PKT_INFO( &Rf_Rec_Buf[0], 3, 3, 3 );
SI446X_FIFO_INFO( &Rf_Rec_Buf[0] );
SI446X_READ_PACKET( &Rf_Rec_Buf[0] );
Function : configuration the device
INTPUT : NONE
OUTPUT : NONE
void SI446X_CONFIG_INIT( void )
u8 i;
u16 j = 0;
RCC->APB2ENR|=1<<3;//ʹÄÜPROTBʱÖÓ
GPIOB->CRH&=0xfff000ff;
GPIOB->CRH|=0x00038300;
GPIOB->ODR|=(1<<12)|(1<<11)|(1<<10);
SPI2_Init();
SI446X_RESET( ); //SI446X Ä£¿é¸´Î»
while( ( i = config_table[j] ) != 0 )
j += 1;
SI446X_CMD( (u8*)config_table + j, i );
j += i;
#if PACKET_LENGTH > 0 //fixed packet length
SI446X_SET_PROPERTY_1( PKT_FIELD_1_LENGTH_7_0, PACKET_LENGTH );
SI446X_SET_PROPERTY_1( PKT_FIELD_1_CRC_CONFIG, 0xA2 );
SI446X_SET_PROPERTY_1( PKT_CRC_CONFIG, 0x05 );
#else //variable packet length
SI446X_SET_PROPERTY_1( PKT_CONFIG1, 0x00 );
SI446X_SET_PROPERTY_1( PKT_CRC_CONFIG, 0x00 );
SI446X_SET_PROPERTY_1( PKT_LEN_FIELD_SOURCE, 0x01 );
SI446X_SET_PROPERTY_1( PKT_LEN, 0x2A );
SI446X_SET_PROPERTY_1( PKT_LEN_ADJUST, 0x00 );
SI446X_SET_PROPERTY_1( PKT_FIELD_1_LENGTH_12_8, 0x00 );
SI446X_SET_PROPERTY_1( PKT_FIELD_1_LENGTH_7_0, 0x01 );
SI446X_SET_PROPERTY_1( PKT_FIELD_1_CONFIG, 0x00 );
SI446X_SET_PROPERTY_1( PKT_FIELD_1_CRC_CONFIG, 0x00 );
SI446X_SET_PROPERTY_1( PKT_FIELD_2_LENGTH_12_8, 0x00 );
SI446X_SET_PROPERTY_1( PKT_FIELD_2_LENGTH_7_0, 0x10 );
SI446X_SET_PROPERTY_1( PKT_FIELD_2_CONFIG, 0x00 );
SI446X_SET_PROPERTY_1( PKT_FIELD_2_CRC_CONFIG, 0x00 );
#endif //PACKET_LENGTH
//ÖØÒª£º 4463µÄGDO2£¬GDO3¿ØÖÆÉäƵ¿ª¹Ø£¬ 0X20 ,0X21
//·¢Éäʱ±ØÐ룺 GDO2=1£¬GDO3=0
//½ÓÊÕʱ±ØÐ룺 GDO2=0£¬GDO3=1
SI446X_GPIO_CONFIG( 0, 0, 0x20, 0x21, 0, 0, 0 );//ÖØÒª
SI446X_START_RX( 0, 0, PACKET_LENGTH,0,0,3 );
function name: SI4463_RF_Master_Send 0
input:
output:
Describe:
Notice:
creat date: 2013-05-16
creator: tiny
u8 SI4463_RF_Master_Send(u8 *sendBuff,u8 *SI4463_INFO_BUF,u8 sendByteCnt,u8 TX_Channel,u16 *delay)
static u8 actStep=0;
u8 tmp=0;
sendByteCnt=PACKET_LENGTH;
#endif
switch(actStep)
case 0:
SI446X_SEND_PACKET(sendBuff, sendByteCnt,TX_Channel,0);
*delay=0;
actStep=1;
break;
case 1:
SI446X_INT_STATUS(SI4463_INFO_BUF);
if((SI4463_INFO_BUF[3] &( 1<<5 )))
tmp=1;
actStep=0;
if(*delay>=20)
actStep=0;
break;
return tmp;
function name: SI4463_5_RF_Master_Receive
input:
output:
Describe:
Notice:
creator: tiny
u8 SI4463_RF_Master_Receive(u8 *receiveBuff,u8 *SI4463_INFO_BUF,u8 receiveByteCnt,u8 RX_Channel,u16 *delay,u16 timeOut)
static u8 actStep=1;
u8 tmp=0;
switch(actStep)
case 0:
SI446X_START_RX(RX_Channel, 0, receiveByteCnt,0,3,3);
*delay=0;
actStep=1;
break;
case 1:
SI446X_START_RX(RX_Channel, 0, receiveByteCnt,0,0,3);
*delay=0;
actStep=2;
break;
case 2:
if(!NIRQ)
*delay=0;
actStep=3;
if(*delay>=timeOut)
//SI446X_START_RX( 0, 0, PACKET_LENGTH,0,3,3 );
tmp=0x80;
actStep=0;
break;
case 3:
if(SI4463_INFO_BUF[3] & ( 1<<4 ) )
tmp = SI446X_READ_PACKET(receiveBuff);
tmp|=0x80;
actStep=0;
if(*delay>=timeOut)
tmp=0x80;
actStep=0;
break;
return tmp;
function name: SI4463_RF_Slaver_Send
input:
output:
Describe:
Notice:
creator: tiny
u8 SI4463_RF_Slaver_Send(u8 *sendBuff,u8 *SI4463_INFO_BUF,u8 sendByteCnt,u8 TX_Channel,u16 *delay)
u8 tmp=0;
#endif
switch(actStep)
case 0:
//SI446X_START_RX(TX_Channel, 0, PACKET_LENGTH,0,3,3 );
*delay=0;
actStep=1;
break;
case 1:
if(*delay>=1)
*delay=0;
actStep=2;
break;
case 2:
tmp=1;
actStep=0;
if(*delay>=4)
tmp=1;
actStep=0;
break;
return tmp;
function name: SI4463_RF_Slaver_Receive
input:
output:
Describe:
Notice:
creator: tiny
u8 SI4463_RF_Slaver_Receive(u8 *receiveBuff,u8 *SI4463_INFO_BUF,u8 receiveByteCnt,u8 RX_Channel,u16 *delay)
u8 tmp=0;
switch(actStep)
case 0:
SI446X_START_RX(RX_Channel, 0, PACKET_LENGTH,0,0,3 );
*delay=0;
actStep=2;
break;
case 1:
if(*delay>=1)
SI446X_START_RX(RX_Channel, 0, receiveByteCnt,0,0,3 );
*delay=0;
actStep=3;
break;
case 2:
if(!NIRQ)
*delay=0;
actStep=3;
if(*delay>=200U*3)
tmp=0xff;
actStep=0;
break;
case 3:
actStep=0;
if(*delay>=200U*3)
tmp=0xff;
actStep=0;
break;
return tmp;
input:
output:
Describe:
Notice:
creator: tiny
u8 SI4463_RF_Slaver_Receive(u8 *receiveBuff,u8 *SI4463_INFO_BUF,u8 receiveByteCnt,u8 RX_Channel,u16 *delay,u8 timeOutVal)
static u8 actStep=2;
u8 tmp=0;
switch(actStep)
case 0:
SI446X_START_RX(RX_Channel, 0, receiveByteCnt,0,3,3 );
*delay=0;
actStep=1;
break;
case 1:
*delay=0;
actStep=2;
break;
case 2:
if(!READ_SI_NIRQ())
*delay=0;
actStep=3;
if(*delay>=200U*timeOutVal)
actStep=0;
break;
case 3:
actStep=0;
actStep=0;
break;
return tmp;
------------------------------------End of FILE----------------------------------
