我在做步进电机的proteus仿真实验室,程序没错,但是步进电机只会在proteus运行时抖动几下,之后就不动了,不知道这是什么原因,
有知道的跟我说下,万分感谢!
- /*完整的C语言程序:*/
- #include <reg52.h> //可用非常成功。
- #define uchar unsigned char
- #define uint unsigned int
- unsigned char code table1[]={0x03,0x06,0x0c,0x09,0x09,0x0c,0x06,0x03};
- 0000,0011
- 0000,0110
- 0000,1100
- 0000,1001
- //unsigned char code table2[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40}; //共阴数码管 0~9
- unsigned char code table2[17] = { 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
- //0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F的显示码
- uchar table_begin;
- uint maichong; //脉冲
- uchar zhuansu; //转速
- uchar flag; //方向
- sbit key_fuwei=P3^0; //复位键
- sbit key_z=P3^1; //正转键
- sbit key_f=P3^2; //反转键
- sbit key_jia=P3^3; //加速键
- sbit key_jian=P3^6; //减速键
- sbit A1=P2^0;
- sbit A2=P2^1;
- sbit A3=P2^2;
- sbit A4=P2^3;
- void display();
- void delayms(xms);
- void delay(uchar x)
- uchar i,j; //延时
- for(i=0;i<x;i++)
- for(j=100;j>0;j--);
- void fuwei(void) //复位
- flag=2;//复位
- zhuansu=0;
- /*void Display(void) //显示
- unsigned char b1, b2;
- b1=zhuansu/10;
- b2=zhuansu%10;
- if(flag == 0) //0
- P0=0x71;//显示F
- else
- P0=0x79;
- A1=0;
- delayms(3);
- A1=1;
- P0=0x40;
- A2=0; //显示--
- delayms(3);
- A2=1;
- P0=table2[b1];
- A3=0; //显示十位
- delayms(3);
- A3=1;
- P0=table2[b2];
- A4=0;
- delayms(3); //显示个位
- A4=1;
- void display()
- uchar b1,b2,b3,b4;
- if(flag==0)
- P0=0x5e;//正转显示d
- else
- if(flag==1)
- P0=0x7c;//反转显示b
- else
- P0=0x71;//复位显示F
- b1=10;
- b2=0x3f; // 显示0
- b3=zhuansu/10;
- b4=zhuansu%10;
- //P0=table2;
- A1=0; //P2.0
- delay(1);
- A1=1;
- P0=b2;
- A2=0; //P2.1
- delay(1);
- A2=1;
- P0=table2[b3];
- A3=0; //P2.3 显示转速的十位
- delay(1);
- A3=1;
- P0=table2[b4];
- A4=0; //P2.4 显示转速的个位
- delay(1);
- A4=1;
- void key() //按键扫描
- if(key_fuwei==0)
- delay(5);
- if(key_fuwei==0)
- fuwei();
- if(key_z==0)
- delay(5);
- if(key_z==0)
- flag=0;
- zhuansu=10;
- while(key_z==0);
- if(key_f==0)
- delay(5);
- if(key_f==0)
- flag=1;
- zhuansu=10;
- while(key_f==0);
- if(key_jia==0)
- delay(5);
- if(key_jia==0)
- zhuansu++;
- if(zhuansu==21)
- zhuansu=20;
- while(key_jia==0);
- if(key_jian==0)
- delay(5);
- if(key_jian==0)
- zhuansu--;
- if(zhuansu<=0)
- zhuansu=0;
- while(key_jian==0);
- void dispose() //脉冲函数
- switch(zhuansu)
- case 0: flag=2; break;
- case 1: maichong=300; break;
- case 2: maichong=295; break;
- case 3: maichong=290; break;
- case 4: maichong=280; break;
- case 5: maichong=260; break;
- case 6: maichong=240; break;
- case 7: maichong=200; break;
- case 8: maichong=180; break;
- case 9: maichong=160; break;
- case 10: maichong=120; break;
- case 11: maichong=80; break;
- case 12: maichong=70; break;
- case 13: maichong=60; break;
- case 14: maichong=40; break;
- case 15: maichong=35; break;
- case 16: maichong=30; break;
- case 17: maichong=25; break;
- case 18: maichong=20; break;
- case 19: maichong=15; break;
- case 20: maichong=10; break;
- if(flag==0) //正转
- table_begin=0;
- else
- if(flag==1) //反转
- table_begin=4;
- void zhuandong(void)
- uint i,j;
- if(zhuansu>0&&zhuansu<=20)
- for(j=0+table_begin;j<4+table_begin;j++)
- P1=table1[j];
- for(i=0;i<maichong;i++) //既有显示功能,又有延时功能,转速越低延时越长
- display();
- void main()
- fuwei();
- display();
- for(;;)
- key();
- dispose();
- if(flag==2)
- display();
- else
- zhuandong();
步进电机调速 数码.zip
(216.51 KB, 下载次数: 36)
