温度传感器SHT1x和SHT2x的iic通信代码,这都是从网上找的代码,sht1x亲测可用,sht2x时序也是准确的。后续将呈现sht7x代码
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "lcd.h"
- #include "SHT10.h"
- SHT1x sht1x; //定义传感器结构体
- int main(void)
- u8 t=0,error=0,checksum,value=0;
- volatile u8 T_Display=0,H_Display=0;
- u16 T_Value=0,H_Value=0;
- delay_init(); //延时函数初始化
- uart_init(9600); //USART1初始化
- LED_Init(); //LED初始化
- LCD_Init();
- SHT1x_Init();
- POINT_COLOR=RED;//设置字体为红色
- LCD_ShowString(60,120,200,16,16,"SHT1X Test");
- POINT_COLOR=BLUE;//设置字体为蓝色
- LCD_ShowString(60,150,200,16,16,"Temp: . C");
- LCD_ShowString(60,170,200,16,16,"Humi: . %RH");
- if(!SHT1X_read_statusreg(&value))
- if(value&0x07)
- for(value=5;value!=0;value--)
- if(!SHT1X_write_statusreg(0))break;
- else SHT1X_softreset();
- while(1)
- //------------------------读取SHT1X传感器数据--------------------------------------
- error+=SHT1x_Measure( &T_Value,&checksum,0); //measure temperature
- error+=SHT1x_Measure( &H_Value,&checksum,1); //measure humidity
- if(error!=0)SHT1x_Reset(); //通讯故障,复位传感器
- else
- sht1x.T_Result = T_Value;
- sht1x.H_Result = H_Value;
- SHT1X_Caculation1((float*)&sht1x.T_Result, (float*)&sht1x.H_Result );
- sht1x.Temperature=sht1x.T_Result;
- sht1x.Humidity=(u16)sht1x.H_Result;
- sht1x.DEW=SHT1X_dewpoint1(sht1x.T_Result, sht1x.H_Result);
- //显示函数处理
- //-------------------温度显示-------------------------------------------------
- if(sht1x.Temperature<0)
- LCD_ShowChar(60+40,150,'-',16,0); //显示负号
- sht1x.Temperature=-sht1x.Temperature; //转为正数
- else LCD_ShowChar(60+40,150,' ',16,0); //去掉负号
- LCD_ShowNum(60+40+8,150,sht1x.Temperature/100,2,16); //显示正数部分
- if((sht1x.Temperature%100)>=0 && (sht1x.Temperature%100)<=9 )
- LCD_ShowNum(60+40+32,150,sht1x.Temperature%100,1,16); //显示小数部分
- else
- LCD_ShowNum(60+40+32,150,sht1x.Temperature%100,2,16); //显示小数部分
- //-------------------------湿度显示-----------------------------------------------
- LCD_ShowNum(60+40+8,170,sht1x.Humidity/100,2,16); //显示正数部分
- if((sht1x.Humidity%100)>=0 && (sht1x.Humidity%100)<=9 )
- LCD_ShowNum(60+40+32,170,sht1x.Humidity%100,1,16); //显示小数部分
- else
- LCD_ShowNum(60+40+32,170,sht1x.Humidity%100,2,16); //显示小数部分
- t++;
- if(t==20)
- t=0;
- LED0=!LED0;
温度传感器程序.rar
(1.12 MB, 下载次数: 54)
