查看: 12250|回复: 2
TJA1021引脚图—LIN2.0标准收发器数据手册下载
ID:303919 发表于 2018-8-31 20:11 | 显示全部楼层 |阅读模式
TJA1021—LIN2.0 标准收发器数据
TJA1021T引脚图:
TJA1021T管脚功能定义:
The TJA1021 is the interface between the LIN master/slave protocol controller and the
physical bus in a Local Interconnect Network (LIN). The TJA1021 is LIN 2.0/SAE J2602
compliant and provides optimum ElectroMagnetic Compatibility (EMC) performance due
to wave shaping of the LIN output.
The /20 version of the TJA1021 is optimized for the maximum specified LIN transmission
speed of 20 kBd; the /10 version of the TJA1021 is optimized for the LIN transmission
speed of 10.4 kBd as specified by the SAE J2602.
完整的pdf格式文档51黑下载地址:
TJA1021—LIN2.0 标准收发器数据手册.pdf (129.49 KB, 下载次数: 99)
ID:125320 发表于 2021-4-7 17:17 | 显示全部楼层
谢谢!好资料,51黑有你更精彩!!!
ID:615192 发表于 2021-7-29 10:21 | 显示全部楼层
谢谢分享!刚好有用到,下来看看
