查看: 1701|回复: 0
蓝牙hc-06控制单片机LED灯程序
ID:115923 发表于 2018-9-3 11:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h> //头文件调用,写程序时都要加上
#include <stdlib.h>
#define uint unsigned int //宏定义,为了后面定义变量书写简便
code unsigned char  LED[] ={~0x3F,~0x06,~0x5B,~0x4F,~0x66,~0x6D,~0x7D,~0x07,~0x7F,~0x6F,~0x77,~0x7C,~0x39,~0x5E,~0x79,~0x71};
void main (void)
       SCON= 0x50;      // SCON: 模式1, 8-bit UART, 使能接收
       TMOD|= 0x20;
       TH1=0xfd;           //波特率9600 初值
       TL1=0xfd;
       TR1=1;
       EA=1;                 //打开总中断
       ES=1;                 //打开串口中断
       while(1)              //主循环不做任何动作
/* 串口中断程序*/
void UART_SER () interrupt 4
       uchar n;  //定义临时变量
       if(RI)           //判断是接收中断产生
              RI=0;    //标志位清零
              n=SBUF;//读入缓冲区的值
              switch(n)
                     case'0':P2=~LED[0];break;
                     case'1':P2=~LED[1];break;
                     case'2':P2=~LED[2];break;
                     case'3':P2=~LED[3];break;
                     case'4':P2=~LED[4];break;
                     case'5':P2=~LED[5];break;
                     case'6':P2=~LED[6];break;
                     case'7':P2=~LED[7];break;
                     case'8':P2=~LED[8];break;
                     case'9':P2=~LED[9];break;
                     case'A':P2=~LED[10];break;
                     case'B':P2=~LED[11];break;
                     case'C':P2=~LED[12];break;
                     case'D':P2=~LED[13];break;
                     case'E':P2=~LED[14];break;
                     case'F':P2=~LED[15];break;
                     default: P2=~LED[0];
              TI=1;
              SBUF=n;//把接收到的值再发回
       if(TI)           //如果是发送标志位,清零
       TI=0;
