因为主站,从站分开两个工程,这里只能分开贴不然容易混淆
主站代码这里是用来控制16个灯的
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
USHORT
usMBCRC16( UCHAR * pucFrame, USHORT usLen );
unsigned char MBRTU_RX_BUFF[100];//读取区
unsigned short int MBRTU_TX_CNT=0;//发送长度
short int *Modbus_InputReg[20];
unsigned char MBRTU_Addr=1;
unsigned char MBRTU_TX_BUFF[100];//传送区
unsigned short int MBRTU_RX_CNT=0;//读取长度
unsigned char MBRTU_FrameFlag=0;
unsigned char Modbus_OutputIO[20];
unsigned char Modbus_InputIO[20];
u16 *Modbus_HoldReg[20];
u16 startRegAddr;
u16 RegNum;
u16 calCRC;
void RTU_05 (void);
//输出GPIO配置
void Output_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* GPIOF Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB, ENABLE); //启用时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12;//打开PIN端口
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//模式为推挽或者其他模式在这里配置
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;//设置频率
GPIO_Init(GPIOA, &GPIO_InitStructure);//将&GPIO_InitStructure地址赋值给GPIOA,在这里的意思是 打开GPIOA的PIN端口
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_8|GPIO_Pin_10|
GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;;//打开PIN端口
GPIO_Init(GPIOB, &GPIO_InitStructure);//将&GPIO_InitStructure地址赋值给GPIOB,在这里的意思是 打开GPIOA的PIN端口
void USART1_IRQHandler(void)//串口1中断服务程序
u8 res;
if(USART_GetITStatus(USART1,USART_IT_RXNE)!=RESET)
res=USART_ReceiveData(USART1); //读接收到的字节,同时相关标志自动清除
if((MBRTU_RX_CNT<100))//读取长度小于100则将读取值 取出
MBRTU_RX_BUFF[MBRTU_RX_CNT]=res;
MBRTU_RX_CNT++;
TIM_ClearITPendingBit(TIM3,TIM_IT_Update);//清除定时器溢出中断
TIM_SetCounter(TIM3,0);//当接收到一个新的字节,将定时器7复位为0,重新计时(相当于喂狗)
TIM_Cmd(TIM3,ENABLE);//开始计时
void MBRTURun(void)
u16 recCRC;
if(MBRTU_FrameFlag==1)
if(MBRTU_RX_BUFF[0]==MBRTU_Addr && MBRTU_RX_CNT >= 5)
if((MBRTU_RX_BUFF[1]==01)||(MBRTU_RX_BUFF[1]==02)||(MBRTU_RX_BUFF[1]==03)||(MBRTU_RX_BUFF[1]==04)||(MBRTU_RX_BUFF[1]==05)||(MBRTU_RX_BUFF[1]==06)||(MBRTU_RX_BUFF[1]==15)||(MBRTU_RX_BUFF[1]==16))//?????
startRegAddr=(((u16)MBRTU_RX_BUFF[2])<<8)|MBRTU_RX_BUFF[3];
if(startRegAddr<1000)
calCRC=usMBCRC16(MBRTU_RX_BUFF,MBRTU_RX_CNT-2);
recCRC=MBRTU_RX_BUFF[MBRTU_RX_CNT-2]|(((u16)MBRTU_RX_BUFF[MBRTU_RX_CNT-1])<<8);
if(calCRC==recCRC)
switch(MBRTU_RX_BUFF[1])
case 1:
Modbus_01_Solve();
break;
case 2:
Modbus_02_Solve();
break;
case 4:
Modbus_04_Solve();
break;
case 5:
Modbus_05_Solve();
break;
case 15:
Modbus_15_Solve();
break;
case 03:
Modbus_03_Solve();
break;
case 06:
Modbus_06_Solve();
break;
case 16:
Modbus_16_Solve();
break;
MBRTU_TX_BUFF[0]=MBRTU_RX_BUFF[0];
MBRTU_TX_BUFF[1]=MBRTU_RX_BUFF[1]|0x80;
MBRTU_TX_BUFF[2]=0x04; //???
//RS485_Send_Data(MBRTU_TX_BUFF,3);
MBRTU_TX_BUFF[2]=0x02; //???
MBRTU_TX_BUFF[2]=0x01;
MBRTU_FrameFlag=0;
MBRTU_RX_CNT=0;
RS485_TX_EN=0;
void Modbus_CoilsRefresh(unsigned char *mbOuputs)
//关联GPIO端口
//output
mbOuputs[15] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_12):GPIO_ResetBits(GPIOA,GPIO_Pin_12);
mbOuputs[14] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_11):GPIO_ResetBits(GPIOA,GPIO_Pin_11);
mbOuputs[13] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_10) : GPIO_ResetBits(GPIOA,GPIO_Pin_10);
mbOuputs[12] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_9) :GPIO_ResetBits(GPIOA,GPIO_Pin_9);
mbOuputs[11] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_8): GPIO_ResetBits(GPIOA,GPIO_Pin_8);
mbOuputs[10] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_15) : GPIO_ResetBits(GPIOB,GPIO_Pin_15);
mbOuputs[9] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_14) : GPIO_ResetBits(GPIOB,GPIO_Pin_14);
mbOuputs[8] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_13) : GPIO_ResetBits(GPIOB,GPIO_Pin_13);
mbOuputs[7] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_12) : GPIO_ResetBits(GPIOB,GPIO_Pin_12);
mbOuputs[6] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_11):GPIO_ResetBits(GPIOB,GPIO_Pin_11);
mbOuputs[5] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_10) : GPIO_ResetBits(GPIOB,GPIO_Pin_10);
mbOuputs[4] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_2) :GPIO_ResetBits(GPIOB,GPIO_Pin_2);
mbOuputs[3] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_1): GPIO_ResetBits(GPIOB,GPIO_Pin_1);
mbOuputs[2] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_0) : GPIO_ResetBits(GPIOB,GPIO_Pin_0);
mbOuputs[1] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_7) : GPIO_ResetBits(GPIOA,GPIO_Pin_7);
mbOuputs[0] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_6) : GPIO_ResetBits(GPIOA,GPIO_Pin_6);
void TIM2_NVIC_Configuration(void)//中断参数配置
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void TIM2_Init(void)//时间中断配置
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
NVIC_InitTypeDef NVIC_InitStruct;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInitStruct.TIM_Period = 200-1;//300MS
TIM_TimeBaseInitStruct.TIM_Prescaler = 7200-1;
TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseInitStruct);
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
NVIC_InitStruct.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStruct);
TIM_Cmd(TIM2, ENABLE);
TIM2_NVIC_Configuration();
void TIM3_NVIC_Configuration(void)//中断参数配置
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
void TIM3_Init(void)//时间中断配置
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
TIM_TimeBaseInitStruct.TIM_Period = 320-1;//32MS////////////此数值 用于 STM32主动发送时间 不可随意更改表标准值320
TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV2;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStruct);
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
NVIC_InitStruct.NVIC_IRQChannel = TIM3_IRQn;
TIM_Cmd(TIM3, ENABLE);
TIM3_NVIC_Configuration();
void Modbus_02_Solve(void)
u16 ByteNum;
u16 i;
RegNum= (((u16)MBRTU_RX_BUFF[4])<<8)|MBRTU_RX_BUFF[5];
if((startRegAddr+RegNum)<100)
MBRTU_TX_BUFF[1]=MBRTU_RX_BUFF[1];
ByteNum=RegNum/8;
if(RegNum%8) ByteNum+=1;
MBRTU_TX_BUFF[2]=ByteNum;
for(i=0;i<RegNum;i++)
if(i%8==0) MBRTU_TX_BUFF[3+i/8]=0x00;
MBRTU_TX_BUFF[3+i/8]>>=1;
MBRTU_TX_BUFF[3+i/8]|=((Modbus_InputIO[startRegAddr+i])<<7)&0x80;
if(i==RegNum-1)
if(RegNum%8) MBRTU_TX_BUFF[3+i/8]>>=8-(RegNum%8);
calCRC=usMBCRC16(MBRTU_TX_BUFF,ByteNum+3);
MBRTU_TX_BUFF[ByteNum+3]=calCRC&0xFF;
MBRTU_TX_BUFF[ByteNum+4]=(calCRC>>8)&0xFF;
RS485_Send_Data(MBRTU_TX_BUFF,ByteNum+5);
void Modbus_01_Solve(void)
u16 ByteNum;
u16 i;
ByteNum=RegNum/8;
MBRTU_TX_BUFF[3+i/8]|=((Modbus_OutputIO[startRegAddr+i])<<7)&0x80;
if(i==RegNum-1)
void Modbus_05_Solve(void)
if(startRegAddr<100)
if((MBRTU_RX_BUFF[4]==0xFF)||(MBRTU_RX_BUFF[5]==0xFF)) Modbus_OutputIO[startRegAddr]=0x01;
else Modbus_OutputIO[startRegAddr]=0x00;
MBRTU_TX_BUFF[2]=MBRTU_RX_BUFF[2];
MBRTU_TX_BUFF[3]=MBRTU_RX_BUFF[3];
MBRTU_TX_BUFF[4]=MBRTU_RX_BUFF[4];
MBRTU_TX_BUFF[5]=MBRTU_RX_BUFF[5];
calCRC=usMBCRC16(MBRTU_TX_BUFF,6);
MBRTU_TX_BUFF[6]=calCRC&0xFF;
MBRTU_TX_BUFF[7]=(calCRC>>8)&0xFF;
RS485_Send_Data(MBRTU_TX_BUFF,8);
void Modbus_15_Solve(void)
u16 i;
RegNum=(((u16)MBRTU_RX_BUFF[4])<<8)|MBRTU_RX_BUFF[5];
if(MBRTU_RX_BUFF[7+i/8]&0x01) Modbus_OutputIO[startRegAddr+i]=0x01;
else Modbus_OutputIO[startRegAddr+i]=0x00;
MBRTU_RX_BUFF[7+i/8]>>=1;
void Modbus_03_Solve(void)
u8 i;
RegNum= (((u16)MBRTU_RX_BUFF[4])<<8)|MBRTU_RX_BUFF[5];//???????
if((startRegAddr+RegNum)<1000)//?????+??????
MBRTU_TX_BUFF[2]=RegNum*2;
MBRTU_TX_BUFF[4+i*2]= *Modbus_HoldReg[startRegAddr+i]&0xFF;
MBRTU_TX_BUFF[3+i*2]=(*Modbus_HoldReg[startRegAddr+i]>>8)&0xFF;
calCRC=usMBCRC16(MBRTU_TX_BUFF,RegNum*2+3);
MBRTU_TX_BUFF[RegNum*2+3]=calCRC&0xFF;
MBRTU_TX_BUFF[RegNum*2+4]=(calCRC>>8)&0xFF;
RS485_Send_Data(MBRTU_TX_BUFF,RegNum*2+5);
else//?????+??????
void Modbus_04_Solve(void)
u8 i;
MBRTU_TX_BUFF[4+i*2]=*Modbus_InputReg[startRegAddr+i]&0xFF;
MBRTU_TX_BUFF[3+i*2]=(*Modbus_InputReg[startRegAddr+i]>>8)&0xFF;
void Modbus_06_Solve(void)
*Modbus_HoldReg[startRegAddr]=MBRTU_RX_BUFF[5];//?????
*Modbus_HoldReg[startRegAddr]|=((u16)MBRTU_RX_BUFF[4])<<8;//?????
void Modbus_16_Solve(void)
u8 i;
*Modbus_HoldReg[startRegAddr+i]=MBRTU_RX_BUFF[7+i*2]; //?????
*Modbus_HoldReg[startRegAddr+i]|=((u16)MBRTU_RX_BUFF[8+i*2])<<8; //?????
void TIM3_IRQHandler(void)////定时3中断启用
if(TIM_GetITStatus(TIM3, TIM_IT_Update) == SET)
RTU_05 (); //主站主动发送函数
TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
MBRTU_FrameFlag=1;//定时中断启用RTU中间量
u8 RS485_TX_BUFF[12];//发送缓冲区
char set[11]={01,15,00,00,00,16,02,00,00,00,00};//存放15个灯代码
u16 shuzuB[16];//用来存放计算出的15个值
u16 c,x[16];
char A[8]={1,0,0,1,1,1,1,1};//低位16-24
char B[8]={0,0,1,1,1,1,1,1};//高位25-31 前八个
void RTU_05 (void)//主站主动发送函数
//if(A[0]==1||A[01]==1||A[2]==1||A[3]==1||A[4]==1||A[5]==1||A[6]==1||A[7]==01)
shuzuB[15] = A[7]*128; //0000 0001 01 1
shuzuB[14] = A[6]*64; //0000 0010 02 2 7-----------0
shuzuB[13] = A[5]*32; //0000 0100 04 3
shuzuB[12] = A[4]*16; //0000 1000 08 4
shuzuB[11] = A[3]*8; //0001 0000 10 5
shuzuB[10] = A[2]*4; //0010 0000 20 6
shuzuB[9] = A[1]*2; //0100 0000 40 7
shuzuB[8] = A[0] *1; //1000 0000 80 8
set[7] = shuzuB[8]+shuzuB[9]+shuzuB[10]+shuzuB[11]+shuzuB[12]+shuzuB[13]+shuzuB[14]+shuzuB[15];
//if(B[0]==1||B[01]==1||B[2]==1||B[3]==1||B[4]==1||B[5]==1||B[6]==1||B[7]==01)
shuzuB[7] = B[7]*128; //0000 0001 01 1
shuzuB[6] = B[6]*64; //0000 0010 02 2
shuzuB[5] = B[5]*32; //0000 0100 04 3
shuzuB[4] = B[4]*16; //0000 1000 08 4 低位 7------------0
shuzuB[3] = B[3]*8; //0001 0000 10 5
shuzuB[2] = B[2]*4; //0010 0000 20 6
shuzuB[1] = B[1]*2; //0100 0000 40 7
shuzuB[0] = B[0]*1; //1000 0000 80 8
set[8] =shuzuB[0]+shuzuB[1]+shuzuB[2]+shuzuB[3]+shuzuB[4]+shuzuB[5]+shuzuB[6]+shuzuB[7];
RS485_TX_BUFF[0]=set[0];
RS485_TX_BUFF[1]=set[1];
RS485_TX_BUFF[2]=set[2];
RS485_TX_BUFF[3]=set[3];
RS485_TX_BUFF[4]=set[4];
RS485_TX_BUFF[5]=set[5];
RS485_TX_BUFF[6]=set[6];
RS485_TX_BUFF[7]= set[7];//
RS485_TX_BUFF[8]= set[8]; //
calCRC=usMBCRC16(RS485_TX_BUFF,9);
RS485_TX_BUFF[9]=calCRC&0xFF;
RS485_TX_BUFF[10]=(calCRC>>8)&0xFF;
RS485_Send_Data(RS485_TX_BUFF,11);
void view32(void)
view[15] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_12):GPIO_ResetBits(GPIOA,GPIO_Pin_12);
view[14] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_11):GPIO_ResetBits(GPIOA,GPIO_Pin_11);
view[13] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_10) : GPIO_ResetBits(GPIOA,GPIO_Pin_10);
view[12] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_9) :GPIO_ResetBits(GPIOA,GPIO_Pin_9);
view[11] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_8): GPIO_ResetBits(GPIOA,GPIO_Pin_8);
view[10] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_15) : GPIO_ResetBits(GPIOB,GPIO_Pin_15);
view[9] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_14) : GPIO_ResetBits(GPIOB,GPIO_Pin_14);
view[8] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_13) : GPIO_ResetBits(GPIOB,GPIO_Pin_13);
view[7] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_12) : GPIO_ResetBits(GPIOB,GPIO_Pin_12);
view[6] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_11):GPIO_ResetBits(GPIOB,GPIO_Pin_11);
view[5] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_10) : GPIO_ResetBits(GPIOB,GPIO_Pin_10);
view[4] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_2) :GPIO_ResetBits(GPIOB,GPIO_Pin_2);
view[3] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_1): GPIO_ResetBits(GPIOB,GPIO_Pin_1);
view[2] == 0 ? GPIO_SetBits(GPIOB,GPIO_Pin_0) : GPIO_ResetBits(GPIOB,GPIO_Pin_0);
view[1] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_7) : GPIO_ResetBits(GPIOA,GPIO_Pin_7);
view[0] == 0 ? GPIO_SetBits(GPIOA,GPIO_Pin_6) : GPIO_ResetBits(GPIOA,GPIO_Pin_6);
/*RS485驱动 代码*/
//485初始化
void RS485_Config(u32 bound)
USART_InitTypeDef usart;
GPIO_InitTypeDef usart1;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//启用时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_USART1, ENABLE);
usart1.GPIO_Pin=GPIO_Pin_6; //PB6端口配置TX
usart1.GPIO_Speed=GPIO_Speed_50MHz;
usart1.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &usart1);
usart1.GPIO_Pin=GPIO_Pin_7;
usart1.GPIO_Speed=GPIO_Speed_50MHz;//PB7//PB7端口配置RX
usart1.GPIO_Mode=GPIO_Mode_IN_FLOATING;
usart.USART_BaudRate= bound; //波特率
usart.USART_WordLength=USART_WordLength_8b;//8位数据长度设置
usart.USART_StopBits = USART_StopBits_1;//一位停止位
usart.USART_Parity =USART_Parity_No;//校验位
usart.USART_HardwareFlowControl=USART_HardwareFlowControl_None;//无硬件数据流
usart.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;//收发模式
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择串口1中断
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //响应式中断优先级设置为2级
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;//先占优先级为2级
NVIC_Init(&NVIC_InitStructure);//根据NVICInitStructure制定参数初始化NVIC寄存器
USART_Init(USART1, &usart);//初始化串口
USART_Cmd(USART1, ENABLE);//使能串口
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); // //开启中断
RS485_TX_EN=0;//默认为接收模式
//发送n个字节数据
//buff:发送区首地址
//len:发送的字节数
void RS485_Send_Data(u8 *buf,u8 len) //modbus发送数据函数
RS485_TX_EN=1;//切换为发送模式
while(len--)
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待发送区为空
USART_SendData(USART1,*(buf++));
while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==RESET);
//等待发送完成
RS485_TX_EN=0;//切换为接收模式
static const UCHAR aucCRCHi[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
static const UCHAR aucCRCLo[] = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
0x41, 0x81, 0x80, 0x40
USHORT
UCHAR ucCRCHi = 0xFF;
UCHAR ucCRCLo = 0xFF;
int iIndex;
while( usLen-- )
iIndex = ucCRCLo ^ *( pucFrame++ );
ucCRCLo = ( UCHAR )( ucCRCHi ^ aucCRCHi[iIndex] );
ucCRCHi = aucCRCLo[iIndex];
return ( USHORT )( ucCRCHi << 8 | ucCRCLo );
