查看: 1774|回复: 2
单片机电子秤仿真的问题 求助 如何修改
回帖奖励 10 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
电子秤课程设计 键盘有问题 程序可能有问题 按=后总价一直显示00.765
#include<reg51.h>
#include<intrins.h>
#include <absacc.h>
#include <math.h>
#define uint   unsigned int
#define BUSY  0x80                               //常量定义
#define DATAPORT P0
sbit ADCS =P3^5;
sbit ADDI =P3^7;
sbit ADDO =P3^7;
sbit ADCLK =P3^6;
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_EN=P2^2;
uint x1,y1,z1=0,w1,temp1;
uchar ad_data,k,n,m,e,num,s;                              //采样值存储
sbit beep =P3^0;
char press_data;                                  //标度变换存储单元
unsigned char ad_alarm;                           //报警值存储单元
unsigned char press_ge=0;                        //显示值百位
unsigned char press_shifen=0;                        //显示值十位
unsigned char press_baifen=0;                         //显示值个位
unsigned char press_qianfen=0;                        //显示值十分位
uchar code str0[]={"Weight:  .   Kg "};
uchar code str2[]={"Price:          "};
uchar code str3[]={"Total:             "};
uchar code table2[]={0x37,0x38,0x39,0xfd,0x34,0x35,0x36,0x78,0x31,0x32,0x33,0x2d,0x3d,0x30,0x2e,0x2b}; //键盘码
void delay(uint);
void lcd_wait(void);
void delay_LCM(uint);                                                         //LCD延时子程序
void initLCM( void);                                                           //LCD初始化子程序
void lcd_wait(void);                                                          //LCD检测忙子程序
void WriteCommandLCM(uchar WCLCM,uchar BusyC);                              //写指令到ICM子函数
void WriteDataLCM(uchar WDLCM);                                             //写数据到LCM子函数
void DisplayOneChar(uchar X,uchar Y,uchar DData);                           //显示指定坐标的一个字符子函数
void DisplayListChar(uchar X,uchar Y,uchar code *DData);                     //显示指定坐标的一串字符子函数
void weishu(uint m);
void weishu1(uint m);
void display(void);
uchar Adc0832(unsigned char channel);
void alarm(void);
void data_pro(void);
/**********main funcation************/
void main(void)
    delay(500);                      //系统延时500ms启动
    //ad_data=0;                       //采样值存储单元初始化为0
       initLCM( );
       WriteCommandLCM(0x01,1);            //清显示屏
    DisplayListChar(0,0,str0);
       DisplayListChar(0,1,str2);
       ad_data =Adc0832(0);       //采样值存储单元初始化为0
       alarm();
       data_pro();
       display();
    if(k==1)
      DisplayOneChar((s+7),1,table2[num-1]);
      x1=m;
      y1=n;
      y1=y1*10+x1;
    if(k=='*')
     data_pro();
     weishu(z1);
     k=0;
    if(k=='=')
        z1=z1*temp1;
        DisplayListChar(0,1,str3);
        s=0;
        weishu1(765);
        k=0;
    if(k==' ')
       WriteCommandLCM(0x80+0x40,1);
       z1=0;
       s=0;     //防止清零时指针后移动
/*********延时K*1ms,12.000mhz**********/
void delay(uint k)
   uint i,j;
   for(i=0;i<k;i++)
    for(j=0;j<100;j++);
/**********写指令到ICM子函数************/
    if(BusyC)
    lcd_wait();
    DATAPORT=WCLCM;
    LCM_RS=0;                   // 选中指令寄存器
    LCM_RW=0;
    LCM_RW=0;                // 写模式
    LCM_EN=1;
    _nop_();
    _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
    LCM_EN=0;
/**********写数据到LCM子函数************/
    lcd_wait( );             //检测忙信号
    DATAPORT=WDLCM;
    LCM_RS=1;                // 选中数据寄存器
    LCM_RW=0;                // 写模式
    LCM_EN=1;
    _nop_();
       _nop_();
       _nop_();
       _nop_();
       _nop_();
       _nop_();
       _nop_();
    _nop_();
    LCM_EN=0;
/***********lcm内部等待函数*************/
void lcd_wait(void)
    DATAPORT=0xff;         //读LCD前若单片机输出低电平,而读出LCD为高电平,则冲突,Proteus仿真会有显示逻辑黄色
    LCM_EN=1;
    LCM_RS=0;
    LCM_RW=0;
    LCM_RW=1;
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    while(DATAPORT&BUSY)
    {  LCM_EN=0;
       _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
       LCM_EN=1;
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    _nop_();
       LCM_EN=0;
/**********LCM初始化子函数***********/
void initLCM( )
    LCM_EN=0;
    DATAPORT=0;
    delay(15);
    WriteCommandLCM(0x38,0);    //三次显示模式设置,不检测忙信号
    delay(5);
    delay(5);
    delay(5);
    WriteCommandLCM(0x38,1);    //8bit数据传送,2行显示,5*7字型,检测忙信号
    WriteCommandLCM(0x08,1);    //关闭显示,检测忙信号
    WriteCommandLCM(0x01,1);    //清屏,检测忙信号
    WriteCommandLCM(0x06,1);    //显示光标右移设置,检测忙信号
    WriteCommandLCM(0x0c,1);    //显示屏打开,光标不显示,不闪烁,检测忙信号
    TMOD=0x11;
    EA=1;
    ET1=1;
    TR1=1;
    k=0;
    x1=0;
    y1=0;
    z1=0;
/****显示指定坐标的一个字符子函数****/
    Y&=0x01;
    X&=0x0f;
    if(Y)
    X|=0x40;               //若y为1(显示第二行),地址码+0X40
    X|=0x80;                    //指令码为地址码+0X80
    WriteCommandLCM(X,1);
    WriteDataLCM(DData);
/*******显示指定坐标的一串字符子函数*****/
    uchar ListLength=0;
    Y&=0x01;
    X&=0x0f;
    while(X<16)
        DisplayOneChar(X,Y,DData[ListLength]);
        ListLength++;
        X++;
/*****************系统显示子函数*****************/
void display(void)
    //DisplayListChar(0,1,str2);
    DisplayOneChar(8,0,press_ge+0x30);
    DisplayOneChar(10,0,press_shifen+0x30);
    DisplayOneChar(11,0,press_baifen+0x30);
    DisplayOneChar(12,0,press_qianfen+0x30);
    delay(1000);                               //稳定显示
读ADC0832函数
//采集并返回
uchar Adc0832(unsigned char channel)     //AD转换,返回结果
     uchar i=0;
    uchar j;
    uint dat=0;
    uchar ndat=0;
    if(channel==0)channel=2;
    if(channel==1)channel=3;
    ADDI=1;
    _nop_();
    _nop_();
    ADCS=0;//拉低CS端
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿1
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=channel&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿2
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=(channel>>1)&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿3
    ADDI=1;//控制命令结束
    _nop_();
    _nop_();
    dat=0;
    for(i=0;i<8;i++)
        dat|=ADDO;//收数据
        ADCLK=1;
        _nop_();
        _nop_();
        ADCLK=0;//形成一次时钟脉冲
        _nop_();
        _nop_();
        dat<<=1;
        if(i==7)dat|=ADDO;
    for(i=0;i<8;i++)
        j=0;
        j=j|ADDO;//收数据
        ADCLK=1;
        _nop_();
        _nop_();
        ADCLK=0;//形成一次时钟脉冲
        _nop_();
        _nop_();
        j=j<<7;
        ndat=ndat|j;
        if(i<7)ndat>>=1;
    ADCS=1;//拉低CS端
    ADCLK=0;//拉低CLK端
    ADDO=1;//拉高数据端,回到初始状态
    dat<<=8;
    dat|=ndat;
    return(dat);            //return ad k
void data_pro(void)
      unsigned int;
      float  press;
      if(0<ad_data<256)
            int vary=ad_data;
            press=(0.019531*vary);
            temp1=(int)(press*1000);                    //放大1000倍,便于后面的计算
            press_ge=temp1/1000;                     //取压力值百位
            press_shifen=(temp1%1000)/100;                //取压力值十位
            press_baifen=((temp1%1000)%100)/10;            //取压力值个位
            press_qianfen=((temp1%1000)%100)%10;            //取压力值十分位
/*****************报警子函数*******************/
void alarm(void)
     if(ad_data>=256)
           beep=0;          //则启动报警
           beep=1;
void weishu(uint m)
   uchar wei4,wei3,wei2,wei1,wei0;
   wei4=m/10000;
   wei3=m%10000/1000;
   wei2=m%1000/100;
   wei1=m%100/10;
   wei0=m%10;
   DisplayOneChar(7,1,0x30+wei4);
   DisplayOneChar(8,1,0x30+wei3);
   DisplayOneChar(10,1,0x30+wei2);
       //DisplayOneChar(10,1,'.');
   DisplayOneChar(11,1,0x30+wei1);
   DisplayOneChar(12,1,0x30+wei0);
   uchar wei5,wei4,wei3,wei2,wei1,wei0;
   wei5=m/100000;
   wei4=m%100000/10000;
   wei3=m%10000/1000;
   wei2=m%1000/100;
   wei1=m%100/10;
   wei0=m%10;
   DisplayOneChar(9,1,'.');
void temer1() interrupt 3
{ uchar temp;
  EX1=0;
  P1=0xfe;
  temp=P1;
  temp=temp&0xf0;
  if(temp!=0xf0)
    delay(5);
    temp=P1;
    temp=temp&0xf0;
    while(temp!=0xf0)
      temp=P1;
      switch(temp)
        case 0xee:num=1;n=7;k=1,s++;break;
        case 0xde:num=2;n=8;k=1,s++;break;
        case 0xbe:num=3;n=9;k=1,s++;break;
        case 0x7e:num=4;k='/',s++;break;
      while(temp!=0xf0)
           temp=P1;
        temp=temp&0xf0;
    //DisplayOneChar((s+6),1,table2[num-1]);
  P1=0xfd;
  temp=P1;
  temp=temp&0xf0;
  if(temp!=0xf0)
    delay(5);
    temp=P1;
    temp=temp&0xf0;
    while(temp!=0xf0)
      temp=P1;
      switch(temp)
        case 0xed:num=5;n=4;k=1;s++;break;
        case 0xdd:num=6;n=5;k=1;s++;break;
        case 0xbd:num=7;n=6;k=1;s++;break;
        case 0x7d:num=8;k='*';s++;break;
      while(temp!=0xf0)
           temp=P1;
        temp=temp&0xf0;
    //DisplayOneChar(k+6,1,table2[num-1]);
  P1=0xfb;
  temp=P1;
  temp=temp&0xf0;
  if(temp!=0xf0)
    delay(5);
    temp=P1;
    temp=temp&0xf0;
    while(temp!=0xf0)
      temp=P1;
      switch(temp)
        case 0xeb:num=9;n=1;k=1;s++;break;
        case 0xdb:num=10;n=2;k=1;s++;break;
        case 0xbb:num=11;n=3;k=1;s++;break;
        case 0x7b:num=12;k='-';s++;break;
      while(temp!=0xf0)
           temp=P1;
        temp=temp&0xf0;
//    DisplayOneChar(k+6,1,table2[num-1]);
  P1=0xf7;
  temp=P1;
  temp=temp&0xf0;
  if(temp!=0xf0)
    delay(5);
    temp=P1;
    temp=temp&0xf0;
    while(temp!=0xf0)
      temp=P1;
      switch(temp)
        case 0xe7:num=13;k=' ';break;
        case 0xd7:num=14;n=0;k=1;s++;;break;
        case 0xb7:num=15;k='=';s++;break;
        case 0x77:num=16;k='+';s++;;break;
      while(temp!=0xf0)
           temp=P1;
        temp=temp&0xf0;
  EX1=1;
protes仿真截图
protes仿真截图
ID:414432 发表于 2018-10-25 10:44 | 只看该作者
价格显示有问题 按=后 一直是00.765
ID:414432 发表于 2018-10-25 10:45 | 只看该作者
要如何修改才能正确显示总价 求助
