shuzi.h
- #ifndef __SHUZI_H__
- #define __SHUZI_H__
- #define uchar unsigned char
- //取模软件:zimo221
- //取模方式:纵向取模 字节倒序
- uchar code SHUZI[]=
- /*-- 文字: 0 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,
- 0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
- /*-- 文字: 1 --*/
- 0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,
- 0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,
- /*-- 文字: 2 --*/
- 0x00,0x70,0x08,0x08,0x08,0x08,0xF0,0x00,
- 0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
- /*-- 文字: 3 --*/
- 0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,
- 0x00,0x18,0x20,0x21,0x21,0x22,0x1C,0x00,
- /*-- 文字: 4 --*/
- 0x00,0x00,0x80,0x40,0x30,0xF8,0x00,0x00,
- 0x00,0x06,0x05,0x24,0x24,0x3F,0x24,0x24,
- /*-- 文字: 5 --*/
- 0x00,0xF8,0x88,0x88,0x88,0x08,0x08,0x00,
- 0x00,0x19,0x20,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 6 --*/
- 0x00,0xE0,0x10,0x88,0x88,0x90,0x00,0x00,
- 0x00,0x0F,0x11,0x20,0x20,0x20,0x1F,0x00,
- /*-- 文字: 7 --*/
- 0x00,0x18,0x08,0x08,0x88,0x68,0x18,0x00,
- 0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x00,
- /*-- 文字: 8 --*/
- 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,
- 0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
- /*-- 文字: 9 --*/
- 0x00,0xF0,0x08,0x08,0x08,0x10,0xE0,0x00,
- 0x00,0x01,0x12,0x22,0x22,0x11,0x0F,0x00,
- /*-- 文字: - --*/
- ///*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
- //0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- //0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
- #endif
hanzi.h
- #ifndef __HANZI_H__
- #define __HANZI_H__
- //取模软件:zimo221
- //取模方式:纵向取模 字节倒序
- uchar code HANZI[]=
- /*-- 文字: 星 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
- 0x00,0x00,0x00,0xBE,0x2A,0x2A,0x2A,0xEA,
- 0x2A,0x2A,0x2A,0x3E,0x00,0x00,0x00,0x00,
- 0x00,0x44,0x42,0x49,0x49,0x49,0x49,0x7F,
- 0x49,0x49,0x49,0x49,0x41,0x40,0x00,0x00,
- /*-- 文字: 期 --*/
- 0x00,0x04,0xFF,0x24,0x24,0x24,0xFF,0x04,
- 0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00,
- 0x88,0x48,0x2F,0x09,0x09,0x19,0xAF,0x48,
- 0x30,0x0F,0x02,0x42,0x82,0x7F,0x00,0x00,
- /*-- 文字: 一 --*/
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: 二 --*/
- 0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,
- 0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00,
- 0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
- 0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,
- /*-- 文字: 三 --*/
- 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,
- 0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
- 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,
- 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- /*-- 文字: 四 --*/
- 0x00,0xFC,0x04,0x04,0x04,0xFC,0x04,0x04,
- 0x04,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
- 0x00,0x7F,0x28,0x24,0x23,0x20,0x20,0x20,
- 0x20,0x21,0x22,0x22,0x22,0x7F,0x00,0x00,
- /*-- 文字: 五 --*/
- 0x00,0x02,0x42,0x42,0x42,0xC2,0x7E,0x42,
- 0x42,0x42,0x42,0xC2,0x02,0x02,0x00,0x00,
- 0x40,0x40,0x40,0x40,0x78,0x47,0x40,0x40,
- 0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x00,
- /*-- 文字: 六 --*/
- 0x20,0x20,0x20,0x20,0x20,0x20,0x21,0x22,
- 0x2C,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- 0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,
- 0x00,0x01,0x02,0x04,0x18,0x60,0x00,0x00,
- /*-- 文字: 日 --*/
- 0x00,0x00,0x00,0xFE,0x82,0x82,0x82,0x82,
- 0x82,0x82,0x82,0xFE,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0x40,0x40,0x40,0x40,
- 0x40,0x40,0x40,0xFF,0x00,0x00,0x00,0x00,
- #endif
