为什么这个代码放到我的板子上出来的结果不对呢??
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define w 6
- sbit LCD1602_E=P2^7;
- sbit LCD1602_RW=P2^5;
- sbit LCD1602_RS=P2^6;
- sbit Scl=P3^4;
- sbit Sda=P3^5;
- sbit Key=P3^6;
- sbit ALAM=P2^1;
- sbit YY=P2^4;
- sbit open_led=P2^2;
- bit operation=0;
- bit pass=0;
- bit ReInputEn=0;
- bit s3_keydown=0;
- bit key_disable=0;
- uchar countt0,second;
- void delay(uint x);
- uchar code a[]={0xfe,0xfd,0xfb,0xf7}; //???????????
- uchar code start_line[]="password: ";
- uchar code name[]="Coded Management";
- uchar code Correct[] =" correct ";
- uchar code Error[] =" error ";
- uchar code codepass[]=" pass ";
- uchar code LockOpen[]=" true ";
- uchar code SetNew[]="SetNewWordEnable";
- uchar code input[]="input: ";
- uchar code ResetOK[]="ResetPassWordOK";
- uchar code initword[]="Init PassWord...";
- uchar code Er_try[]="error,try again!";
- uchar code again[]="input again: ";
- uchar InputData[6]; //?????????????
- uchar CurrentPassWord[]={1,3,1,4,2,0};
- uchar TempPassWord[6];
- uchar N=0;
- uchar ErrorCont;
- uchar CorrectCont;
- uchar ReInputCont;
- uchar num,flag=0;
- uchar code initpassword[6]={1,2,3,4,5,6};
- void Delay5Ms()
- unsigned int TempCyc=5552;
- while(TempCyc--);
- void Delay400Ms()
- unsigned char TempCycA=5;
- unsigned char TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- void mDelay(uint t)
- uchar i;
- while(t--)
- for(i=0;i<125;i++)
- uint i,j;
- for(i=x;i>0;i--)
- for(j=110;j>0;j--);
- void Nop()
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- void Start()
- Sda=1;
- Scl=1;
- Nop();
- Sda=0;
- Nop();
- void Stop()
- Sda=0;
- Scl=1;
- Nop();
- Sda=1;
- Nop();
- void Ack()
- Sda=0;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- void NoAck()
- Sda=1;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- void Send(uchar Data)
- uchar Bitcounter=8;
- uchar temp;
- do
- temp=Data;
- Scl=0;
- Nop();
- if((temp&0x80)==0x80)
- Sda=1;
- else Sda=0;
- Scl=1;
- temp=Data<<1;
- Data=temp;
- Bitcounter--;
- }while(Bitcounter);
- Scl=0;
- uchar Read(void)
- uchar temp=0;
- uchar temp1=0;
- Sda=1;
- do
- Scl=0;
- Nop();
- Scl=1;
- Nop();
- if(Sda)
- temp=temp|0x01;
- else
- temp=temp&0xfe;
- if(Bitcounter-1)
- temp1=temp<<1;
- temp=temp1;
- Bitcounter--;
- return (temp);
- void WrToROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- for(i=0;i<Num;i++)
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Send(*(PData+i));
- Ack();
- Stop();
- mDelay(20);
- void RdFromROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Start();
- Send(0xa1);
- Ack();
- *(PData+i)=Read();
- Scl=0;
- NoAck();
- Stop();
- #define yi 0x80
- #define er 0x80+0x40
- void write_1602com(uchar com)
- LCD1602_E = 0;
- LCD1602_RS = 0;
- LCD1602_RW = 0;
- P0= com;
- delay(1);
- LCD1602_E = 1;
- delay(5);
- LCD1602_E = 0;;
- void write_1602data(uchar dat)
- LCD1602_E = 0;
- LCD1602_RS = 1;
- LCD1602_RW = 0;
- P0= dat;
- delay(1);
- LCD1602_E = 1;
- delay(5);
- LCD1602_E = 0;
- void lcd_init()
- write_1602com(0x38);
- write_1602com(0x0c);
- write_1602com(0x06);
- write_1602com(0x01);
- unsigned char coding (unsigned char m)
- unsigned char k;
- switch(m)
- case(0x18):k=1;break;
- case(0x28):k=2;break;
- case(0x48):k=3;break;
- case(0x88):k='A';break;
- case(0X14):k=4;break;
- case(0X24):k=5;break;
- case(0X44):k=6;break;
- case(0X84):k='B';break;
- case(0X12):k=7;break;
- case(0X22):k=8;break;
- case(0X42):k=9;break;
- case(0X82):k='C';break;
- case(0X11):k='*';break;
- case(0X21):k=0;break;
- case(0x41):k='#';break;
- case(0x81):k='D';break;
- return k;
- unsigned char keynum()
- unsigned char row,col,i;
- P1=0xf0;
- if((P1&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P1^0xf0;
- i=0;
- P1=a[i];
- while(i<4)
- col=~(P1&0xf0);
- break;
- else
- i++;
- P1=a[i];
- else
- return 0;
- while((P1&0xf0)!=0xf0)
- return (row|col);
- else return 0;
- void OneAlam()
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- void TwoAlam()
- ALAM=0;
- Delay5MS();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- void ThreeAlam()
- ALAM=0;
- Delay5MS();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- void DisplayOne()
- write_1602com(yi+5+N);
- write_1602data('*');
- void DisplayOne()
- void DisplayChar()
- uchar i;
- if(pass==1)
- write_1602com(er);
- for(i=0;i<16;i++)
- write_1602data(LockOpen[i]);
- else
- if(N==0)
- for(i=0;i<16;i++)
- write_1602data(Error[i]);
- else
- for(i=0;i<16;i++)
- write_1602data(start_line[i]);
- void DisplayInput()
- unsigned char i;
- if(CorrectCont==1)
- for(i=0;i<16;i++)
- write_1602data(input[i]);
- void ResetPassWord()
- uchar i,j;
- if(pass==0)
- pass=0;
- DisplayChar();
- ThreeAlam();
- else
- if(ReInputEn==1)
- if(N==6)
- ReInputCont++;
- if(ReInputCont==2)
- for(i=0;i<6;)
- if(TempPassWord[i]==InputData[i])
- i++;
- else
- for(j=0;j<16;j++)
- write_1602data(Error[j]);
- ThreeAlam();
- pass=0;
- ReInputEn=0;
- ReInputCont=0;
- DisplayChar();
- break;
- if(i==6)
- for(j=0;j<16;j++)
- write_1602data(ResetOK[j]);
- TwoAlam();
- WrToROM(TempPassWord,0,6);
- ReInputEn=0;
- ReInputCont=0;
- CorrectCont=0;
- else
- OneAlam();
- for(j=0;j<16;j++)
- write_1602data(again[j]);
- for(i=0;i<6;i++)
- TempPassWord[i]=InputData[i];
- N=0;
- void Alam_KeyUnable()
- P1=0X00;
- ALAM=~ALAM;
- Delay5Ms();
- void Cancel()
- uchar i,j;
- for(j=0;j<16;j++)
- write_1602data(start_line[j]);
- TwoAlam();
- for(i=0;i<6;i++)
- InputData[i]=0;
- Key=1;
- ALAM=1;
- flag=0;
- operation=0;
- pass=0;
- ReInputEn=0;
- ErrorCont=0;
- CorrectCont=0;
- ReInputCont=0;
- open_led=1;
- s3_keydown=0;
- key_disable=0;
- N=0;
- void Ensure()
- uchar i,j;
- RdFromROM(CurrentPassWord,0,6);
- if(N==6)
- if(ReInputEn==0)
- for(i=0;i<6;)
- if(CurrentPassWord[i]==InputData[i])
- i++;
- else
- ErrorCont++;
- if(ErrorCont==3)
- for(i=0;i<16;i++)
- do
- Alam_KeyUnable();
- while(1);
- else
- TR0=1;
- key_disable=1;
- pass=0;
- break;
- if(i==6)
- CorrectCont++;
- for(j=0;j<16;j++)
- TwoAlam();
- Key=0;
- flag=1;
- pass=1;
- TR0=0;
- open_led=0;
- for(j=0;j<100;j++)
- InputData[i]=0;
- else
- for(j=0;j<16;j++)
- write_1602data(SetNew[j]);
- TwoAlam();
- ReInputEn=1;
- CorrectCont=0;
- else
- if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
- WrToROM(initpassword,0,6);
- for(j=0;j<16;j++)
- write_1602data(initword[j]);
- TwoAlam();
- Delay400Ms();
- TwoAlam();
- N=0;
- else
- for(j=0;j<16;j++)
- ThreeAlam;
- pass=0;
- else
- for(j=0;j<16;j++)
- write_1602data(Er_try[j]);
- ThreeAlam;
- else
- for(j=0;j<16;j++)
- ThreeAlam;
- pass=0;
- N=0;
- operation=1;
- void main()
- unsigned char KEY,NUM;
- unsigned char i,j;
- P1=0XFF;
- TMOD=0X11;
- TL0=0XB0;
- TH0=0X3C;
- EA=1;
- ET0=1;
- TR0=0;
- Delay400Ms();
- lcd_init();
- write_1602com(yi);
- for(i=0;i<16;i++)
- write_1602data(name[i]);
- for(i=0;i<16;i++)
- write_1602com(er+9);
- write_1602com(0x0f);
- Delay5Ms();
- N=0;
- while(1)
- if(key_disable==1)
- Alam_KeyUnable();
- else
- ALAM=1;
- flag=0;
- if(flag==1)
- YY=0;
- num++;
- if(num>20)
- flag=0;
- num=0;
- KEY=keynum();
- if(KEY!=0)
- second=0;
- else
- NUM=coding(KEY);
- switch(NUM)
- case ('A'): ;break;
- case ('B'): ;break;
- case ('C'): ;break;
- case ('D'):
- ResetPassWord();break;
- case ('*'):Cancel();break;
- case ('#'):Ensure();break;
- default:
- for(i=0;i<16;i++)
- operation=0;
- if(N<6)
- OneAlam();
- for(j=0;j<=N;j++)
- write_1602com(er+6+j);
- InputData[N]=NUM;
- N++;
- else
- N=6;
- break;
- void time0_int(void) interrupt 1
- TL0=0XB0;
- TH0=0X3C;
- countt0++;
- if(countt0==20)
- countt0=0;
- second++;
- if(pass==1)
- if(second==1)
- open_led=1;
- TR0=0;
- TL0=0XB0;
- TH0=0X3C;
- second=0;
- else
- if(second==3)
- TR0=0;
- second=0;
- key_disable=0;
- s3_keydown=0;
- TL0=0XB0;
- TH0=0X3C;
- else
- TR0=1;
