查看: 3861|回复: 4
STM32F405霍尔方波控制无刷电机程序
ID:435514 发表于 2018-11-29 11:14 | 显示全部楼层 |阅读模式
三霍尔直流无刷电机控制
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "stm32f4xx.h"
  3. #include "main.h"
  4. #include "ADC.h"
  5. #include "STM103REG.h"
  6. #include "DISPLAY.h"
  7. /* Private typedef -----------------------------------------------------------*/
  8. /* Private define ------------------------------------------------------------*/
  9. /* Private macro -------------------------------------------------------------*/
  10. /* Private variables ---------------------------------------------------------*/
  11. static vu32 TimingDelay = 0;
  12. volatile struct {
  13.                 unsigned Key           :                1;
  14.                 unsigned CalSpeed :         1;
  15.                 unsigned Sec      :                1;
  16.                 unsigned Fault           :                1;
  17.                 }Flags;
  18. unsigned int DesiredSpeed=500;
  19. unsigned int ActualSpeed;
  20. unsigned int pwm=500;
  21. unsigned int T3Count;
  22. unsigned int ActualSpeed5[3];
  23. vu16 ADC_DMABUF;
  24. unsigned int AveActualSpeed;
  25. unsigned char AveNum;
  26. unsigned char j;
  27. float kp=0.5,ki=0.08,kd=0.0;
  28. int ek=0,ek1=0,ek2=0;
  29. float duk;
  30. int du;
  31. int ekSpeed=0;
  32. s16 speedref[2]={1,-1};
  33. u16 motor_statue=0;
  34. u8  startcnt=0;
  35. int ucT1S=0;
  36. int ucT2S=0;
  37. unsigned int dc_bus;
  38. short int ia_zm,ib_zm,ic_zm;
  39. u8 Direction1,Cur_Flag=1;
  40. extern u16 My_PWM;
  41. extern u16 Hall,time;
  42. extern u8 Direction;
  43. extern u8 TIM1_Configuration1(void);
  44. int state,state1,state2,state3,counter1,counter2,counter3,speed_1,aim_speed,check_run,speed_code,vol_over;
  45. short ADC_ConvertedValue[7]={0,0,0,0,0,0,0};
  46. TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
  47. TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  48. TIM_OCInitTypeDef  TIM_OCInitStructure;
  49. EXTI_InitTypeDef EXTI_InitStructure;
  50. ErrorStatus HSEStartUpStatus;
  51. /* Private function prototypes -----------------------------------------------*/
  52. void RCC_Configuration(void);
  53. void GPIO_Configuration(void);
  54. void LCD_GPIO_Configuration(void);
  55. void NVIC_Configuration(void);
  56. void CalculateDC(int u,int y);
  57. void TIM3_Configuration1(void);
  58. void TIM2_Configuration1(void);
  59. void TIM4_Configuration1(void);
  60. void SysTick_Configuration(void);
  61. int pid(int nonce,int aim);
  62. u8 key_con(void);
  63. /* Private functions ---------------------------------------------------------*/
  64. /*******************************************************************************
  65. * Function Name  : main
  66. * Description    : Main program.
  67. * Input          : None
  68. * Output         : None
  69. * Return         : None
  70. *******************************************************************************/
  71. int main(void)
  72. {
  73.         #ifdef DEBUG
  74.         debug();
  75.         #endif
  76.   int i;
  77.         u8 keytemp=0;
  78.         u8 flagccw=0;
  79.         /* System Clocks Configuration */
  80.         RCC_Configuration();
  81.
  82.         /* NVIC configuration */
  83.         NVIC_Configuration();
  84.   bsp_InitADC();
  85.         TIM1_Configuration1();
  86.         TIM2_Configuration1();
  87.         TIM4_Configuration1();
  88.         GPIO_Configuration();
  89.         LCD_GPIO_Configuration();
  90.         SysTick_Configuration();
  91.         //SysTick_CounterCmd(SysTick_Counter_Enable);
  92.
  93.   ShowMenu_init();
  94.         aim_speed=1000;
  95.         MENOFF();
  96.         MENON();//芯片端使能
  97.         LcdReset();
  98.
  99.         while (1)
  100.         {
  101.         dc_bus=ADC_ConvertedValue[4]/60;
  102.   if((dc_bus>30)|(dc_bus<18))
  103.   {
  104.                  vol_over++;
  105.                  if(vol_over==4)//防止电压抖动
  106.                  {
  107.                    TIM_Cmd(TIM1, DISABLE);
  108.                    TIM_CtrlPWMOutputs(TIM1, DISABLE);
  109.                          vol_over=0;
  110.                  }
  111.          }
  112.          else
  113.          {
  114.            vol_over=0;
  115.          }
  116.         ia_zm =(short int)(((ADC_ConvertedValue[5])-560));
  117.         ib_zm =(short int)(((ADC_ConvertedValue[6])-560));
  118.         ic_zm =(short int)(((0-(ADC_ConvertedValue[5])-(ADC_ConvertedValue[6]))+560+560));
  119.         if((ia_zm>400)|(ib_zm>400)|(ic_zm>400))
  120.         {
  121.                 TIM_Cmd(TIM1, DISABLE);
  122.                 TIM_CtrlPWMOutputs(TIM1, DISABLE);
  123.                 Cur_Flag=0;
  124.         }
  125.   keytemp= key_con();
  126.
  127.   if(keytemp==1)
  128.         {
  129.                     TIM_Cmd(TIM1, ENABLE);
  130.                     TIM_CtrlPWMOutputs(TIM1, ENABLE);
  131.                                 startcnt=0;
  132.
  133.         }
  134.
  135.         if(keytemp==2)
  136.         {
  137.                 Cur_Flag=1;
  138.                 TIM_Cmd(TIM1, DISABLE);
  139.                 TIM_CtrlPWMOutputs(TIM1, DISABLE);
  140.
  141.         }
  142.
  143.         if(keytemp==5)
  144.         {
  145.                 if(time >1800)
  146.                 {
  147.                          time=0;
  148.                          if(flagccw==0)
  149.                          {
  150.                                  Direction=1;
  151.                                  Direction1=1;
  152.                          }
  153.                          else
  154.                          {
  155.                                  Direction=0;
  156.                                  Direction1=0;
  157.                          }
  158.                          flagccw=~flagccw;
  159.                 }
  160.         }
  161.          ucT1S++;
  162.          ucT2S++;
  163.          if(ucT1S>=30)
  164.          {
  165.                  ShowMenuMain();
  166.                  ucT1S=0;
  167.          }
  168.    keytemp= key_con();
  169.   if(startcnt<36)  //换相6次后启动
  170.         {
  171.                 if(time>10)
  172.                 {
  173.                         Hall_SW();
  174.                         Hall++;
  175.                         if(        Hall>6)Hall=1;
  176.                         time=0;
  177.                 }
  178.           startcnt++;
  179.         }
  180.   else
  181.         {
  182.                 startcnt=37;
  183.                 aim_speed=ADC_ConvertedValue[3]/60*40;
  184.                 if(aim_speed>2500)aim_speed=2500;
  185.                 for(i=0;i<100000;i++);
  186.                 My_PWM+=pid(speed_1,aim_speed)/((speed_1/My_PWM)+1);
  187.                 if(My_PWM<=0)
  188.                 My_PWM=0;
  189.                 if(My_PWM>5000)
  190.                 My_PWM=5000;
  191.         }
  192. }
  193. }
  194. int pid(int nonce,int aim)
  195. {
  196.         static int ek_2=0;
  197.         static int ek_1=0;
  198.         static int ek=0;
  199. //        int ec;
  200.         int uk;
  201.
  202.         ek=aim-nonce;
  203. //        ec=ek/T;
  204.         uk=kp*(ek-ek_1+ki*ek+kd*(ek-2*ek_1+ek_2));
  205.         ek_2=ek_1;
  206.         ek_1=ek;
  207.         return (uk);
  208. }
  209. /*******************************************************************************
  210. * Function Name  : RCC_Configuration
  211. * Description    : Configures the different system clocks.
  212. * Input          : None
  213. * Output         : None
  214. * Return         : None
  215. *******************************************************************************/
  216. void RCC_Configuration(void)
  217. {
  218.     ErrorStatus HSEStartUpStatus;
  219.     // RCC system reset(for debug purpose)
  220.     RCC_DeInit();
  221.     // Enable HSE
  222.     RCC_HSEConfig(RCC_HSE_ON);
  223.     // Wait till HSE is ready
  224.     HSEStartUpStatus = RCC_WaitForHSEStartUp();
  225.     if(HSEStartUpStatus == SUCCESS)
  226.     {
  227.         // Enable Prefetch Buffer
  228.         FLASH_PrefetchBufferCmd(ENABLE);
  229.         // Flash 2 wait state
  230.         FLASH_SetLatency(FLASH_Latency_2);
  231.         // HCLK = SYSCLK
  232.         RCC_HCLKConfig(RCC_SYSCLK_Div1);
  233.         // PCLK2 = HCLK
  234.         RCC_PCLK2Config(RCC_HCLK_Div1);
  235.         // PCLK1 = HCLK/2
  236.         RCC_PCLK1Config(RCC_HCLK_Div2);
  237.         // PLLCLK = 8MHz * 9 = 72 MHz
  238.        // RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  239.         RCC_PLLConfig(RCC_PLLSource_HSE,25, 336, 2, 7);
  240.         // Enable PLL
  241.         RCC_PLLCmd(ENABLE);
  242.         // Wait till PLL is ready
  243.         while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
  244.         {
  245.         }
  246.         // Select PLL as system clock source
  247.         RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  248.         // Wait till PLL is used as system clock source
  249.         while(RCC_GetSYSCLKSource() != 0x08)
  250.         {
  251.         }
  252.     }
  253.     else
  254.     {
  255.         // If HSE fails to start-up, the application will have wrong clock configuration.
  256.         // User can add here some code to deal with this error
  257.         // Go to infinite loop
  258.         while (1)
  259.         {
  260.         }
  261.     }
  262. }
  263. /*******************************************************************************
  264. * Function Name  : key_con
  265. * Description    : Configures the Motor operation mode
  266. * Input          : None
  267. * Output         : None
  268. * Return         : None
  269. *******************************************************************************/
  270. u8 key_con(void)
  271. {
  272.         static u8 key;
  273.         key=0;
  274.          if(!GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_5))
  275.          {
  276.                  key=2;
  277.
  278.          }
  279.           if(!GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_15))
  280.          {
  281.                  key=1;
  282.
  283.          }
  284.           if(!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1))
  285.          {
  286.                  key=3;
  287.
  288.          }
  289.           if(!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_10))
  290.          {
  291.                  key=4;
  292.
  293.          }
  294.           if(!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_11))
  295.          {
  296.                  key=5;
  297.
  298.          }
  299.          return key;
  300. }
  301. /*******************************************************************************
  302. * Function Name  : GPIO_Configuration
  303. * Description    : Configures the different GPIO ports.
  304. * Input          : None
  305. * Output         : None
  306. * Return         : None
  307. *******************************************************************************/
  308. void GPIO_Configuration(void)
  309. {
  310.         GPIO_InitTypeDef GPIO_InitStructure;
  311.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA|RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOC|RCC_AHB1Periph_GPIOD ,ENABLE);
  312.         //按键输入
  313.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  314.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  315.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  316.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 |GPIO_Pin_15;
  317.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//IO口上拉
  318.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  319.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  320.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_10|GPIO_Pin_11 ;
  321.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//IO口
  322.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  323.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  324.         /* 配置Hall接口IO */
  325.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8;
  326.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  327.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  328.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  329.         /*霍尔信号线中断配置*/
  330.         SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC,GPIO_PinSource6);
  331.   SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC,GPIO_PinSource7);
  332.         SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC,GPIO_PinSource8);
  333.         EXTI_InitStructure.EXTI_Line = EXTI_Line6|EXTI_Line7|EXTI_Line8;
  334.         EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  335.         EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
  336.         EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  337.         EXTI_Init(&EXTI_InitStructure);
  338.         /*PA8,PA9,PA10 为上半桥臂*/
  339.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8| GPIO_Pin_9 | GPIO_Pin_10 ;
  340.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  341.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  342.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  343.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  344.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  345.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_TIM1);
  346.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_TIM1);
  347.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_TIM1);
  348.         /*PB13,PB14,PB15 为下半桥臂*/
  349.         GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 ;
  350.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  351.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  352.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  353. }
  354. void LCD_GPIO_Configuration()
  355. {
  356.           GPIO_InitTypeDef GPIO_InitStructure;
  357.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA|RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOC|RCC_AHB1Periph_GPIOD,ENABLE);
  358.
  359.         /*-----------------GPIOA--------------------*/
  360.          //DO 点
  361.         GPIO_InitStructure.GPIO_Pin =PAO_LCDDB0|PAO_LCDEN|PAO_LCDRS;
  362.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  363.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  364.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  365.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  366.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  367.         /*-----------------GPIOB--------------------*/
  368.         //DO 点
  369.         GPIO_InitStructure.GPIO_Pin =  PBO_LCDCS1|PBO_LCDCS2|PBO_LCDDB5|PBO_LCDDB6|PBO_LCDDB7;
  370.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  371.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  372.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  373.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  374.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  375.         /*-----------------GPIOC--------------------*/
  376.         GPIO_InitStructure.GPIO_Pin = PCO_LCDDB1|PCO_LCDDB2|PCO_LCDDB3;
  377.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  378.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  379.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  380.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  381.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  382.         /*-----------------GPIOD--------------------*/
  383.         GPIO_InitStructure.GPIO_Pin = PDO_LCDDB4;
  384.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  385.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  386.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  387.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  388.         GPIO_Init(GPIOD, &GPIO_InitStructure);
  389. }
  390. //闭环计算子程序
  391. void CalculateDC(int u,int y)
  392. {
  393.         ek=u-y;
  394.         if(ek>1||ek<-1)
  395.         {
  396.                 duk=kp*(ek-ek1)+ki*ek+kd*(ek+ek2-ek1*2);
  397.                 du=(int)duk;
  398.                 if(duk>1)duk=1;
  399.                 if(duk<-1)duk=-1;
  400.                 if(du>10)du=10;
  401.                 if(du<-5)du=-5;
  402.                 pwm+=du;
  403.                 if(pwm<60)
  404.                 {
  405.                         pwm=60;
  406.                 }
  407.                 if(pwm>0x7FE)
  408.                 {
  409.                         pwm=0x7FE;
  410.                 }
  411.
  412.                 ek2=ek1;
  413.                 ek1=ek;
  414.         }
  415. }
  416. /*******************************************************************************
  417. * Function Name  : NVIC_Configuration
  418. * Description    : Configure the nested vectored interrupt controller.
  419. * Input          : None
  420. * Output         : None
  421. * Return         : None
  422. *******************************************************************************/
  423. void NVIC_Configuration(void)
  424. {
  425.         NVIC_InitTypeDef NVIC_InitStructure;
  426.
  427. //        #ifdef  VECT_TAB_RAM
  428. //                /* Set the Vector Table base location at 0x20000000 */
  429. //                NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  430. //        #else  /* VECT_TAB_FLASH  */
  431. //                /* Set the Vector Table base location at 0x08000000 */
  432. //                NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  433. //        #endif
  434. //        /* Configure one bit for preemption priority */
  435. //        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  436.
  437.         NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  438.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  439.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  440.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  441.         NVIC_Init(&NVIC_InitStructure);
  442.
  443.         NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  444.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  445.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  446.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  447.         NVIC_Init(&NVIC_InitStructure);
  448.
  449.         NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  450.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  451.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  452.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  453.         NVIC_Init(&NVIC_InitStructure);
  454.         NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  455.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  456.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  457.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  458.         NVIC_Init(&NVIC_InitStructure);
  459. }
  460. #ifdef  DEBUG
  461. /*******************************************************************************
  462. * Function Name  : assert_failed
  463. * Description    : Reports the name of the source file and the source line number
  464. *                  where the assert_param error has occurred.
  465. * Input          : - file: pointer to the source file name
  466. *                  - line: assert_param error line source number
  467. * Output         : None
  468. * Return         : None
  469. *******************************************************************************/
  470. void assert_failed(u8* file, u32 line)
  471. {
  472.   /* User can add his own implementation to report the file name and line number,
  473.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  474.   /* Infinite loop */
  475.   while (1)
  476.   {
  477.   }
  478. }
  479. #endif
  480. /*******************************************************************************
  481. * Function Name  : SysTick_Config
  482. * Description    : Configure a SysTick Base time to 10 ms.
  483. ……………………
  484. …………限于本文篇幅 余下代码请从51黑下载附件…………
F405霍尔方波控制无刷电机.rar (505.81 KB, 下载次数: 76)
ID:464519 发表于 2019-1-8 14:11 | 显示全部楼层
程序不能运行 提示有一个error
stm32f4xx.h(102): error:  #35: #error directive: "Please select first the target STM32F4xx device used in your application (in stm32f4xx.h file)"
   #error "Please select first the target STM32F4xx device used in your application (in stm32f4xx.h file)"
main.c: 0 warnings, 1 error
"main.c" - 1 Error(s), 0 Warning(s).
ID:513563 发表于 2019-12-30 21:51 | 显示全部楼层
比较简单
ID:513563 发表于 2019-12-30 21:52 | 显示全部楼层
基本上还是属于简单的,没有结构。
ID:669414 发表于 2022-8-3 14:43 | 显示全部楼层
下来学习,我也想做一个无刷
