查看: 7809|回复: 5
CH554串口接收数据转USB键值程序 CH559模拟USB复合设备,键鼠,支持类命令
ID:407961 发表于 2018-12-3 13:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个通过CH55X系列单片机接收串口数据转HID键盘上传程序
1、本例程基于USB单片机CH559、CH558、CH554编写,所有版权归WCH所有。
2、本例程实时更新,不另行通知。
  1. /********************************** (C) COPYRIGHT *******************************
  2. * File Name          :Composite_Dev.C
  3. * Author             : WCH
  4. * Version            : V1.0
  5. * Date               : 2017/01/20
  6. * Description        : CH559模拟USB复合设备,键鼠,支持类命令
  7. *******************************************************************************/
  8. #include "./Public/CH554.H"
  9. #include "./Public/DEBUG.H"
  10. #include <string.h>
  11. #include <stdio.h>
  12. #define THIS_ENDP0_SIZE         DEFAULT_ENDP0_SIZE
  13. #define CapsLockLED 0x02
  14. #define BUFMAX 16
  15. UINT8X  Ep0Buffer[8>(THIS_ENDP0_SIZE+2)?8:(THIS_ENDP0_SIZE+2)] _at_ 0x0000;    //端点0 OUT&IN缓冲区,必须是偶地址
  16. UINT8X  Ep1Buffer[64>(MAX_PACKET_SIZE+2)?64:(MAX_PACKET_SIZE+2)] _at_ 0x000a;  //端点1 IN缓冲区,必须是偶地址
  17. UINT8   SetupReq,SetupLen,Ready,Count,FLAG,UsbConfig,LED_VALID;
  18. PUINT8  pDescr;        //USB配置标志
  19. USB_SETUP_REQ   SetupReqBuf;                                                   //暂存Setup包
  20. bit Ep2InKey;
  21. #define UsbSetupBuf     ((PUSB_SETUP_REQ)Ep0Buffer)
  22. #define DEBUG 0
  23. #pragma  NOAREGS
  24. /*设备描述符*/
  25. UINT8C DevDesc[18] = {0x12,0x01,0x10,0x01,0x00,0x00,0x00,0x08,
  26.                       0x3d,0x41,0x07,0x21,0x00,0x00,0x00,0x00,
  27.                       0x00,0x01
  28.                      };
  29. UINT8C CfgDesc[59] =
  30. {
  31.     0x09,0x02,0x22,0x00,0x01,0x01,0x00,0xA0,0x32,             //配置描述符
  32.     0x09,0x04,0x00,0x00,0x01,0x03,0x01,0x01,0x00,             //接口描述符,键盘
  33.     0x09,0x21,0x11,0x01,0x00,0x01,0x22,0x3e,0x00,             //HID类描述符
  34.     0x07,0x05,0x81,0x03,0x08,0x00,0x0a,                       //端点描述符
  35. };
  36. /*字符串描述符*/
  37. /*HID类报表描述符*/
  38. UINT8C KeyRepDesc[62] =
  39. {
  40.     0x05,0x01,0x09,0x06,0xA1,0x01,0x05,0x07,
  41.     0x19,0xe0,0x29,0xe7,0x15,0x00,0x25,0x01,
  42.     0x75,0x01,0x95,0x08,0x81,0x02,0x95,0x01,
  43.     0x75,0x08,0x81,0x01,0x95,0x03,0x75,0x01,
  44.     0x05,0x08,0x19,0x01,0x29,0x03,0x91,0x02,
  45.     0x95,0x05,0x75,0x01,0x91,0x01,0x95,0x06,
  46.     0x75,0x08,0x26,0xff,0x00,0x05,0x07,0x19,
  47.     0x00,0x29,0x91,0x81,0x00,0xC0
  48. };
  49. /*键盘数据*/
  50. UINT8 HIDKey[8] = {0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0};
  51. UINT8 DataBuffer[BUFMAX];
  52. UINT8 DataLen =0;
  53. UINT8 RecvPoint =0;
  54. UINT8 SendPoint =0;
  55. /*******************************************************************************
  56. * Function Name  : USBDeviceInit()
  57. * Description    : USB设备模式配置,设备模式启动,收发端点配置,中断开启
  58. * Input          : None
  59. * Output         : None
  60. * Return         : None
  61. *******************************************************************************/
  62. void USBDeviceInit()
  63. {
  64.           IE_USB = 0;
  65.           USB_CTRL = 0x00;                                                           // 先设定USB设备模式
  66.     UEP0_DMA = Ep0Buffer;                                                      //端点0数据传输地址
  67.     UEP1_DMA = Ep1Buffer;                                                      //端点1数据传输地址
  68.     UEP4_1_MOD = ~(bUEP4_RX_EN | bUEP4_TX_EN |bUEP1_RX_EN | bUEP1_BUF_MOD) | bUEP4_TX_EN;//端点1单64字节收发缓冲区,端点0收发
  69.     UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_NAK;                                 //OUT事务返回ACK,IN事务返回NAK
  70.     UEP1_CTRL = bUEP_T_TOG | UEP_T_RES_NAK;
  71.
  72.           USB_DEV_AD = 0x00;
  73.           UDEV_CTRL = bUD_PD_DIS;                                                    // 禁止DP/DM下拉电阻
  74.           USB_CTRL = bUC_DEV_PU_EN | bUC_INT_BUSY | bUC_DMA_EN;                      // 启动USB设备及DMA,在中断期间中断标志未清除前自动返回NAK
  75.           UDEV_CTRL |= bUD_PORT_EN;                                                  // 允许USB端口
  76.           USB_INT_FG = 0xFF;                                                         // 清中断标志
  77.           USB_INT_EN = bUIE_SUSPEND | bUIE_TRANSFER | bUIE_BUS_RST;
  78.           IE_USB = 1;
  79. }
  80. /*******************************************************************************
  81. * Function Name  : Enp1IntIn()
  82. * Description    : USB设备模式端点1的中断上传
  83. * Input          : None
  84. * Output         : None
  85. * Return         : None
  86. *******************************************************************************/
  87. void Enp1IntIn( )
  88. {
  89.     memcpy( Ep1Buffer, HIDKey, sizeof(HIDKey));                              //加载上传数据
  90.     UEP1_T_LEN = sizeof(HIDKey);                                             //上传数据长度
  91.     UEP1_CTRL = UEP1_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_ACK;                //有数据时上传数据并应答ACK
  92. }
  93. /*******************************************************************************
  94. * Function Name  : DeviceInterrupt()
  95. * Description    : CH559USB中断处理函数
  96. *******************************************************************************/
  97. void    DeviceInterrupt( void ) interrupt INT_NO_USB using 1                      //USB中断服务程序,使用寄存器组1
  98. {
  99.     UINT8 len;
  100.     if(UIF_TRANSFER)                                                            //USB传输完成标志
  101.     {
  102.         switch (USB_INT_ST & (MASK_UIS_TOKEN | MASK_UIS_ENDP))
  103.         {
  104.         case UIS_TOKEN_IN | 2:                                                  //endpoint 2# 中断端点上传
  105.             UEP2_T_LEN = 0;                                                     //预使用发送长度一定要清空
  106. //            UEP1_CTRL ^= bUEP_T_TOG;                                          //如果不设置自动翻转则需要手动翻转
  107.             UEP2_CTRL = UEP2_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_NAK;           //默认应答NAK
  108.             break;
  109.         case UIS_TOKEN_IN | 1:                                                  //endpoint 1# 中断端点上传
  110.             UEP1_T_LEN = 0;                                                     //预使用发送长度一定要清空
  111. //            UEP2_CTRL ^= bUEP_T_TOG;                                          //如果不设置自动翻转则需要手动翻转
  112.             UEP1_CTRL = UEP1_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_NAK;           //默认应答NAK
  113.             FLAG = 1;                                                           /*传输完成标志*/
  114.             break;
  115.         case UIS_TOKEN_SETUP | 0:                                                //SETUP事务
  116.             len = USB_RX_LEN;
  117.             if(len == (sizeof(USB_SETUP_REQ)))
  118.             {
  119.                 SetupLen = UsbSetupBuf->wLengthL;
  120.                 if(UsbSetupBuf->wLengthH || SetupLen > 0x7F )
  121.                 {
  122.                     SetupLen = 0x7F;    // 限制总长度
  123.                 }
  124.                 len = 0;                                                        // 默认为成功并且上传0长度
  125.                 SetupReq = UsbSetupBuf->bRequest;
  126.                 if ( ( UsbSetupBuf->bRequestType & USB_REQ_TYP_MASK ) != USB_REQ_TYP_STANDARD )/* HID类命令 */
  127.                 {
  128.        switch( SetupReq )
  129.        {
  130.        case 0x01://GetReport
  131.        break;
  132.        case 0x02://GetIdle
  133.        break;
  134.        case 0x03://GetProtocol
  135.        break;
  136.        case 0x09://SetReport
  137.        break;
  138.        case 0x0A://SetIdle
  139.        break;
  140.        case 0x0B://SetProtocol
  141.        break;
  142.        default:
  143.        len = 0xFF;        /*命令不支持*/
  144.        break;
  145.        }
  146.                 }
  147.                 else
  148.                 {//标准请求
  149.                     switch(SetupReq)                                        //请求码
  150.                     {
  151.                     case USB_GET_DESCRIPTOR:
  152.                         switch(UsbSetupBuf->wValueH)
  153.                         {
  154.                         case 1:                                             //设备描述符
  155.                             pDescr = DevDesc;                               //把设备描述符送到要发送的缓冲区
  156.                             len = sizeof(DevDesc);
  157.                             break;
  158.                         case 2:                                             //配置描述符
  159.                             pDescr = CfgDesc;                               //把设备描述符送到要发送的缓冲区
  160.                             len = sizeof(CfgDesc);
  161.                             break;
  162.                         case 0x22:                                          //报表描述符
  163.                             if(UsbSetupBuf->wIndexL == 0)                   //接口0报表描述符
  164.                             {
  165.                                 pDescr = KeyRepDesc;                        //数据准备上传
  166.                                 len = sizeof(KeyRepDesc);
  167.                                 Ready = 1;                                  //如果有更多接口,该标准位应该在最后一个接口配置完成后有效
  168.                                 IE_UART1 = 1;//开启串口中断
  169.
  170.                             }
  171.                             else
  172.                             {
  173.                                 len = 0xff;                                 //本程序只有2个接口,这句话正常不可能执行
  174.                             }
  175.                             break;
  176.                         default:
  177.                             len = 0xff;                                     //不支持的命令或者出错
  178.                             break;
  179.                         }
  180.                         if ( SetupLen > len )
  181.                         {
  182.                             SetupLen = len;    //限制总长度
  183.                         }
  184.                         len = SetupLen >= 8 ? 8 : SetupLen;                  //本次传输长度
  185.                         memcpy(Ep0Buffer,pDescr,len);                        //加载上传数据
  186.                         SetupLen -= len;
  187.                         pDescr += len;
  188.                         break;
  189.                     case USB_SET_ADDRESS:
  190.                         SetupLen = UsbSetupBuf->wValueL;                     //暂存USB设备地址
  191.                         break;
  192.                     case USB_GET_CONFIGURATION:
  193.                         Ep0Buffer[0] = UsbConfig;
  194.                         if ( SetupLen >= 1 )
  195.                         {
  196.                             len = 1;
  197.                         }
  198.                         break;
  199.                     case USB_SET_CONFIGURATION:
  200.                         UsbConfig = UsbSetupBuf->wValueL;
  201.                         break;
  202.                     case 0x0A:
  203.                         break;
  204.                     case USB_CLEAR_FEATURE:                                            //Clear Feature
  205.                         if ( ( UsbSetupBuf->bRequestType & USB_REQ_RECIP_MASK ) == USB_REQ_RECIP_ENDP )// 端点
  206.                         {
  207.                             switch( UsbSetupBuf->wIndexL )
  208.                             {
  209.                             case 0x82:
  210.                                 UEP2_CTRL = UEP2_CTRL & ~ ( bUEP_T_TOG | MASK_UEP_T_RES ) | UEP_T_RES_NAK;
  211.                                 break;
  212.                             case 0x81:
  213.                                 UEP1_CTRL = UEP1_CTRL & ~ ( bUEP_T_TOG | MASK_UEP_T_RES ) | UEP_T_RES_NAK;
  214.                                 break;
  215.                             case 0x01:
  216.                                 UEP1_CTRL = UEP1_CTRL & ~ ( bUEP_R_TOG | MASK_UEP_R_RES ) | UEP_R_RES_ACK;
  217.                                 break;
  218.                             default:
  219.                                 len = 0xFF;                                            // 不支持的端点
  220.                                 break;
  221.                             }
  222.                         }
  223.                         else
  224.                         {
  225.                             len = 0xFF;                                                // 不是端点不支持
  226.                         }
  227.                         break;
  228.                     case USB_SET_FEATURE:                                              /* Set Feature */
  229.                         if( ( UsbSetupBuf->bRequestType & 0x1F ) == 0x00 )             /* 设置设备 */
  230.                         {
  231.                             if( ( ( ( UINT16 )UsbSetupBuf->wValueH << 8 ) | UsbSetupBuf->wValueL ) == 0x01 )
  232.                             {
  233.                                 if( CfgDesc[ 7 ] & 0x20 )
  234.                                 {
  235.                                     /* 设置唤醒使能标志 */
  236.                                 }
  237.                                 else
  238.                                 {
  239.                                     len = 0xFF;                                        /* 操作失败 */
  240.                                 }
  241.                             }
  242.                             else
  243.                             {
  244.                                 len = 0xFF;                                            /* 操作失败 */
  245.                             }
  246.                         }
  247.                         else if( ( UsbSetupBuf->bRequestType & 0x1F ) == 0x02 )        /* 设置端点 */
  248.                         {
  249.                             if( ( ( ( UINT16 )UsbSetupBuf->wValueH << 8 ) | UsbSetupBuf->wValueL ) == 0x00 )
  250.                             {
  251.                                 switch( ( ( UINT16 )UsbSetupBuf->wIndexH << 8 ) | UsbSetupBuf->wIndexL )
  252.                                 {
  253.                                 case 0x82:
  254.                                     UEP2_CTRL = UEP2_CTRL & (~bUEP_T_TOG) | UEP_T_RES_STALL;/* 设置端点2 IN STALL */
  255.                                     break;
  256.                                 case 0x02:
  257.                                     UEP2_CTRL = UEP2_CTRL & (~bUEP_R_TOG) | UEP_R_RES_STALL;/* 设置端点2 OUT Stall */
  258.                                     break;
  259.                                 case 0x81:
  260.                                     UEP1_CTRL = UEP1_CTRL & (~bUEP_T_TOG) | UEP_T_RES_STALL;/* 设置端点1 IN STALL */
  261.                                     break;
  262.                                 default:
  263.                                     len = 0xFF;                               //操作失败
  264.                                     break;
  265.                                 }
  266.                             }
  267.                             else
  268.                             {
  269.                                 len = 0xFF;                                   //操作失败
  270.                             }
  271.                         }
  272.                         else
  273.                         {
  274.                             len = 0xFF;                                      //操作失败
  275.                         }
  276.                         break;
  277.                     case USB_GET_STATUS:
  278.                         Ep0Buffer[0] = 0x00;
  279.                         Ep0Buffer[1] = 0x00;
  280.                         if ( SetupLen >= 2 )
  281.                         {
  282.                             len = 2;
  283.                         }
  284.                         else
  285.                         {
  286.                             len = SetupLen;
  287.                         }
  288.                         break;
  289.                     default:
  290.                         len = 0xff;                                           //操作失败
  291.                         break;
  292.                     }
  293.                 }
  294.             }
  295.             else
  296.             {
  297.                 len = 0xff;                                                   //包长度错误
  298.             }
  299.             if(len == 0xff)
  300.             {
  301.                 SetupReq = 0xFF;
  302.                 UEP0_CTRL = bUEP_R_TOG | bUEP_T_TOG | UEP_R_RES_STALL | UEP_T_RES_STALL;//STALL
  303.             }
  304.             else if(len <= 8)                                                //上传数据或者状态阶段返回0长度包
  305.             {
  306.                 UEP0_T_LEN = len;
  307.                 UEP0_CTRL = bUEP_R_TOG | bUEP_T_TOG | UEP_R_RES_ACK | UEP_T_RES_ACK;//默认数据包是DATA1,返回应答ACK
  308.             }
  309.             else
  310.             {
  311.                 UEP0_T_LEN = 0;  //虽然尚未到状态阶段,但是提前预置上传0长度数据包以防主机提前进入状态阶段
  312.                 UEP0_CTRL = bUEP_R_TOG | bUEP_T_TOG | UEP_R_RES_ACK | UEP_T_RES_ACK;//默认数据包是DATA1,返回应答ACK
  313.             }
  314.             break;
  315.         case UIS_TOKEN_IN | 0:                                               //endpoint0 IN
  316.             switch(SetupReq)
  317.             {
  318.             case USB_GET_DESCRIPTOR:
  319.                 len = SetupLen >= 8 ? 8 : SetupLen;                          //本次传输长度
  320.                 memcpy( Ep0Buffer, pDescr, len );                            //加载上传数据
  321.                 SetupLen -= len;
  322.                 pDescr += len;
  323.                 UEP0_T_LEN = len;
  324.                 UEP0_CTRL ^= bUEP_T_TOG;                                     //同步标志位翻转
  325.                 break;
  326.             case USB_SET_ADDRESS:
  327.                 USB_DEV_AD = USB_DEV_AD & bUDA_GP_BIT | SetupLen;
  328.                 UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_NAK;
  329.                 break;
  330.             default:
  331.                 UEP0_T_LEN = 0;                                              //状态阶段完成中断或者是强制上传0长度数据包结束控制传输
  332.                 UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_NAK;
  333.                 break;
  334.             }
  335.             break;
  336.         case UIS_TOKEN_OUT | 0:  // endpoint0 OUT
  337.             len = USB_RX_LEN;
  338.             if((SetupReq == 0x09)&& (len == 1))
  339.             {
  340.               LED_VALID = Ep0Buffer[0];
  341.             }
  342.             else if((SetupReq == 0x09) && (len == 8)){//SetReport
  343.             }
  344.             UEP0_T_LEN = 0;  //虽然尚未到状态阶段,但是提前预置上传0长度数据包以防主机提前进入状态阶段
  345.             UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_ACK;//默认数据包是DATA0,返回应答ACK
  346.             break;
  347.         default:
  348.             break;
  349.         }
  350.         UIF_TRANSFER = 0;                                                 //写0清空中断
  351.     }
  352.     if(UIF_BUS_RST)                                                       //设备模式USB总线复位中断
  353.     {
  354.         UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_NAK;
  355.         UEP1_CTRL = bUEP_AUTO_TOG | UEP_R_RES_ACK;
  356.         UEP2_CTRL = bUEP_AUTO_TOG | UEP_R_RES_ACK | UEP_T_RES_NAK;
  357.         USB_DEV_AD = 0x00;
  358.         UIF_SUSPEND = 0;
  359.         UIF_TRANSFER = 0;
  360.         UIF_BUS_RST = 0;                                                 //清中断标志
  361.     }
  362.     if (UIF_SUSPEND)                                                     //USB总线挂起/唤醒完成
  363.     {
  364.         UIF_SUSPEND = 0;
  365.     }
  366.     else {                                                               //意外的中断,不可能发生的情况
  367.         USB_INT_FG = 0xFF;                                               //清中断标志
  368.     }
  369. }
  370. /*******************************************************************************
  371. * Function Name  : QueryUART1Interrupt(void)
  372. * Description    : UART1中断服务程序
  373. *******************************************************************************/
  374. void  QueryUART1Interrupt( void ) interrupt INT_NO_UART1 using 2             //UART1中断服务程序,使用寄存器组1
  375. {
  376.     if(U1RI)
  377.     {
  378.         U1RI = 0;
  379.         DataBuffer[RecvPoint++] = SBUF1;
  380.         DataLen++;
  381.         if(RecvPoint==BUFMAX) RecvPoint=0;
  382.     }
  383.     U1TI = 0;
  384. }
  385. /*******************************************************************************
  386. * Function Name  : KeyCodeCorrespond()
  387. * Description    : 键码比对表,由数值对应键盘值。
  388. * Input          : UINT8 keyCode
  389. * Output         : None
  390. * Return         : None
  391. *******************************************************************************/
  392. void KeyCodeCorrespond(UINT8 keyCode)
  393. {
  394.         HIDKey[0] = 0;
  395.         if((keyCode>='a')&&(keyCode<='z')){                                       //键值a-z
  396.                 if(LED_VALID&0x02)
  397.                 {
  398.                         FLAG = 0;
  399.                         HIDKey[2] = 0x39;
  400.                         Enp1IntIn();
  401.                         while(FLAG == 0);
  402.                         FLAG = 0;
  403.                         memset(&HIDKey[0],0,8);
  404.                         Enp1IntIn();
  405.                         while(FLAG == 0);
  406.                 }
  407.                 keyCode -= 0x5D;
  408.                 HIDKey[2] = keyCode;
  409.
  410.         }
  411.   else if((keyCode>='A')&&(keyCode<='Z')){
  412.                 if((LED_VALID&0x02) == 0)
  413.                 {
  414.                         FLAG = 0;
  415.                         HIDKey[2] = 0x39;
  416.                         Enp1IntIn();
  417.                         while(FLAG == 0);
  418.                         FLAG = 0;
  419.                         memset(&HIDKey[0],0,8);
  420.                         Enp1IntIn();
  421.                         while(FLAG == 0);
  422.                 }
  423.
  424.
  425.           keyCode -= 0x3D;
  426.     HIDKey[2] = keyCode;
  427. //    HIDKey[0]        = 0x02;                                                          //shift+
  428.
  429.   }
  430.   else if((keyCode>='1')&&(keyCode<='9')){
  431.                 keyCode -= 0x13;                                                        //字母区数字键
  432.                 HIDKey[2] = keyCode;
  433.         }
  434.         else if(keyCode=='0'){
  435.                 HIDKey[2] = 0x27;
  436.         }
  437.         else if(keyCode <= 0x2f){
  438.                 if(keyCode == 0x20){
  439.                         HIDKey[2] = 0x2C;                                                     //空格
  440.                 }
  441.                 else if(keyCode == 0x21){//'!'
  442.                         HIDKey[2] = 0x1E;
  443.                         HIDKey[0]        = 0x02;                                                          //shift+
  444.                 }
  445.                 else if(keyCode == 0x22){//'"'
  446.                         HIDKey[2] = 0x34;
  447.                         HIDKey[0]        = 0x02;                                                          //shift+
  448.                 }
  449.                 else if(keyCode == 0x23){//'#'
  450.                         HIDKey[2] = 0x20;
  451.                         HIDKey[0]        = 0x02;                                                          //shift+
  452.                 }
  453.                 else if(keyCode == 0x24){//'
  454.                         HIDKey[2] = 0x21;
  455.                         HIDKey[0]        = 0x02;                                                          //shift+
  456.                 }
  457.                 else if(keyCode == 0x25){//'%'
  458.                         HIDKey[2] = 0x22;
  459.                         HIDKey[0]        = 0x02;                                                          //shift+
  460.                 }
  461.                 else if(keyCode == 0x26){//'&'
  462.                         HIDKey[2] = 0x24;
  463.                         HIDKey[0]        = 0x02;                                                          //shift+
  464.                 }
  465.                 else if(keyCode == 0x27){//'%'
  466.                         HIDKey[2] = 0x34;
  467.                 }
  468.                 else if(keyCode == 0x28){/*(*/
  469.                         HIDKey[2] = 0x26;
  470.                         HIDKey[0]        = 0x02;                                                          //shift+
  471.                 }
  472.                 else if(keyCode == 0x29){/*)*/
  473.                         HIDKey[2] = 0x27;
  474.                         HIDKey[0]        = 0x02;                                                          //shift+
  475.                 }
  476.                 else if(keyCode == 0x2a){/***/
  477.                         HIDKey[2] = 0x25;
  478.                         HIDKey[0]        = 0x02;                                                          //shift+
  479.                 }
  480.                 else if(keyCode == 0x2b){/*+*/
  481.                         HIDKey[2] = 0x2e;
  482.                         HIDKey[0]        = 0x02;                                                          //shift+
  483.                 }
  484.                 else if(keyCode == 0x2c){/*,*/
  485.                         HIDKey[2] = 0x36;
  486.                 }
  487.                 else if(keyCode == 0x2d){/*-*/
  488.                         HIDKey[2] = 0x2d;
  489.                 }
  490.                 else if(keyCode == 0x2e){/*,*/
  491.                         HIDKey[2] = 0x37;
  492.                 }
  493.                 else if(keyCode == 0x2f){/*/*/
  494.                         HIDKey[2] = 0x38;
  495.                 }
  496.   }
  497.   else if(keyCode <= 0x3f){
  498.                 if(keyCode == 0x3a){/*:*/
  499.                         HIDKey[2] = 0x33;
  500.                         HIDKey[0]        |= 0x02;                                                          //shift+
  501.                 }
  502.                 else if(keyCode == 0x3b){/*;*/
  503.                         HIDKey[2] = 0x33;
  504.                 }
  505.                 else if(keyCode == 0x3c){/*<*/
  506.                         HIDKey[2] = 0x36;
  507.                         HIDKey[0]        |= 0x02;                                                          //shift+
  508.                 }
  509.                 else if(keyCode == 0x3d){/*=*/
  510.                         HIDKey[2] = 0x2e;
  511.                 }
  512.                 else if(keyCode == 0x3e){/*>*/
  513.                         HIDKey[2] = 0x37;
  514.                         HIDKey[0]        |= 0x02;                                                          //shift+
  515.                 }
  516.                 else if(keyCode == 0x3f){/*?*/
  517.                         HIDKey[2] = 0x38;
  518.                         HIDKey[0]        |= 0x02;                                                          //shift+
  519.                 }
  520.   }
  521.   else if(keyCode == 0x40){/*@*/
  522.     HIDKey[2] = 0x1f;
  523.     HIDKey[0]        = 0x02;                                                          //shift+
  524.   }
  525.   else if((keyCode >= 0x5b)&&(keyCode <= 0x60)){
  526.                 if(keyCode == 0x5b){/*[*/
  527.                         HIDKey[2] = 0x2f;
  528.                 }
  529.                 else if(keyCode == 0x5c){/*\*/
  530.                         HIDKey[2] = 0x31;
  531.                 }
  532.                 else if(keyCode == 0x5d){/*:*/
  533.                         HIDKey[2] = 0x30;
  534.                 }
  535.                 else if(keyCode == 0x5e){/*:*/
  536.                         HIDKey[2] = 0x23;
  537.                         HIDKey[0]        = 0x02;                                                          //shift+
  538.                 }
  539.                 else if(keyCode == 0x5f){/*:*/
  540.                         HIDKey[2] = 0x2d;
  541.                         HIDKey[0]        = 0x02;                                                          //shift+
  542.                 }
  543.                 else if(keyCode == 0x60){/*`*/
  544.                         HIDKey[2] = 0x35;
  545.                 }
  546.         }
  547.   else if((keyCode >= 0x7b)&&(keyCode <= 0x7f)){
  548.                 if(keyCode == 0x7b){/*{*/
  549.                         HIDKey[2] = 0x2f;
  550.                         HIDKey[0]        = 0x02;                                                          //shift+
  551.                 }
  552.                 else if(keyCode == 0x7c){/*|*/
  553.                         HIDKey[2] = 0x31;
  554.                         HIDKey[0]        = 0x02;                                                          //shift+
  555.                 }
  556.                 else if(keyCode == 0x7d){/*}*/
  557.                         HIDKey[2] = 0x30;
  558.                         HIDKey[0]        = 0x02;                                                          //shift+
  559.                 }
  560.                 else if(keyCode == 0x7e){/*~*/
  561.                         HIDKey[2] = 0x35;
  562.                         HIDKey[0]        = 0x02;                                                          //shift+
  563.                 }
  564.                 else if(keyCode == 0x7f){/*{*/
  565.                         HIDKey[2] = 0x4c;
  566.                 }
  567.         }
  568.   else if((keyCode >= 0x80)&&(keyCode <= 0x87)){/*left ctl*/
  569.     keyCode &= 0x0f;
  570.     HIDKey[0]        = (1<<keyCode);                                                  //
  571.   }
  572.   else if((keyCode >= 0xd7)&&(keyCode <= 0xda)){/**/
  573.     keyCode -= 0x88;
  574.     HIDKey[2]        = keyCode;
  575.   }
  576.   else if((keyCode >= 0xb0)&&(keyCode <= 0xb3)){/**/
  577.     keyCode -= 0x88;
  578.     HIDKey[2]        = keyCode;
  579.   }
  580.   else if((keyCode >= 0xd1)&&(keyCode <= 0xd5)){/**/
  581.     keyCode -= 0x88;
  582.     HIDKey[2]        = keyCode;
  583.   }
  584.   else if((keyCode >= 0xC1)&&(keyCode <= 0xCD)){/**/
  585.     keyCode -= 0x88;
  586.     HIDKey[2]        = keyCode;
  587.   }
  588. }
  589. void HIDValueHandle()
  590. {
  591.         DataLen--;
  592.         KeyCodeCorrespond(DataBuffer[SendPoint]);
  593.
  594.         SendPoint++;
  595.         if(SendPoint>=BUFMAX) SendPoint=0;
  596.         FLAG = 0;
  597.         Enp1IntIn();
  598.         while(FLAG == 0);
  599.         FLAG = 0;
  600.         memset(&HIDKey[0],0,8);
  601.         Enp1IntIn();
  602.         while(FLAG == 0);
  603.
  604. }
  605. main()
  606. {
  607.     CfgFsys( );                                                           //CH559时钟选择配置
  608.     mDelaymS(5);                                                          //修改主频等待内部晶振稳定,必加
  609.     mInitSTDIO( );                                                        //串口0初始化
  610.     printf("start\n");
  611.         USBDeviceInit();                                                      //USB设备模式初始化
  612.     UART1Setup();
  613.     EA = 1;                                                               //允许单片机中断
  614.     IP_EX = bIP_UART1;//串口优先等级高
  615.     UEP1_T_LEN = 0;                                                       //预使用发送长度一定要清空
  616.     FLAG = 0;
  617.     Ready = 0;
  618.         LED_VALID = 1;   //给一个默认值
  619.     while(1)
  620. ……………………
  621. …………限于本文篇幅 余下代码请从51黑下载附件…………
全部资料51hei下载地址:
CH554串口接收数据转USB键值上传201808.zip (135.46 KB, 下载次数: 102)
收藏收藏1 分享淘帖 顶 踩
ID:483484 发表于 2019-3-2 23:16 | 只看该作者
能找你做个usb幽灵键鼠吗 类似飞易来或文盒诚意我qq 1662003456
ID:611832 发表于 2019-9-15 22:31 来自手机 | 只看该作者
做好了吗?求分享
ID:612579 发表于 2019-9-17 14:52 | 只看该作者
想做个串口转USB HID,这个能用吗?
ID:811328 发表于 2020-8-4 20:18 | 只看该作者
楼主能帮我修复一下键鼠模拟的BUG吗 , 源码出了问题
求解决,可以的话留下QQ我加你
ID:944652 发表于 2021-6-29 12:27 | 只看该作者
很想做个串口转USB HID的键盘
