查看: 2318|回复: 0
一个简单的lcd1602显示时间(粗糙)
ID:440677 发表于 2018-12-7 08:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include <intrins.h>
#include <string.h>
sbit IO=P1^0;
sbit SCLK=P1^1;
sbit RST=P1^2;
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
uchar *WEEK[]=
        "SUN","***","MON","TUS","WEN","THU","FRI","SAT"
uchar LCD_DSY_BUFFER1[]={"DATE 00-00-00   "};
uchar LCD_DSY_BUFFER2[]={"TIME 00:00:00   "};
uchar DateTime[7];
void DelayMS(uint ms)
  uchar i;
  while(ms--)
     { for(i=0;i<120;i++); }
void Write_A_Byte_TO_DS1302(uchar x)
  uchar i;
  for(i=0;i<8;i++)
    { IO=x&0x01;SCLK=1;SCLK=0;x>>=1; }
uchar Get_A_Byte_FROM_DS1302()
   uchar i,b=0x00;
   for(i=0;i<8;i++)
         b |= _crol_((uchar)IO,i);
         SCLK=1;SCLK=0;
   return b/16*10+b%16;
uchar Read_Data(uchar addr)
  uchar dat;
  RST=0;SCLK=0;RST=1;
  Write_A_Byte_TO_DS1302(addr);
  dat=Get_A_Byte_FROM_DS1302();
  SCLK=1;RST=0;
  return dat;
void GetTime()
   uchar i,addr=0x81;
   for(i=0;i<7;i++)
   { DateTime[i]=Read_Data(addr);addr+=2; }
uchar read_lcd_state()
  uchar state;
  RS=0;RW=1;EN=1;DelayMS(1);
  state=P0;
  EN=0;DelayMS(1);
  return state;
void lcd_busy_wait()
  while((read_lcd_state()&0x80)==0x80);
  DelayMS(5);
void write_lcd_data(uchar dat)
         lcd_busy_wait();
         RS=1;RW=0;EN=0;P0=dat;EN=1;DelayMS(1);
         EN=0;
void write_lcd_command(uchar dat)
         lcd_busy_wait();
         RS=0;RW=0;EN=0;P0=dat;EN=1;DelayMS(1);
         EN=0;
void init_lcd()
         write_lcd_command(0x38);
         DelayMS(1);
         write_lcd_command(0x01);
         DelayMS(1);
         write_lcd_command(0x06);
         DelayMS(1);
         write_lcd_command(0x0c);
         DelayMS(1);
void set_lcd_pos(uchar p)
        write_lcd_command(p|0x80);
void Display_LCD_String(uchar p,uchar *s)
        uchar i;
        set_lcd_pos(p);
        for(i=0;i<16;i++)
          write_lcd_data(s[i]);
          DelayMS(1);
void Format_DateTime(uchar d,uchar *a)
   a[0]=d/10+'0';
   a[1]=d%10+'0';
  init_lcd();
        GetTime();
        Format_DateTime(DateTime[6],LCD_DSY_BUFFER1+5);
          Format_DateTime(DateTime[4],LCD_DSY_BUFFER1+8);
        Format_DateTime(DateTime[3],LCD_DSY_BUFFER1+11);
        strcpy(LCD_DSY_BUFFER1+13,WEEK[DateTime[5]]);
        Format_DateTime(DateTime[2],LCD_DSY_BUFFER2+5);
        Format_DateTime(DateTime[1],LCD_DSY_BUFFER2+8);
        Format_DateTime(DateTime[0],LCD_DSY_BUFFER2+11);
        Display_LCD_String(0x00,LCD_DSY_BUFFER1);
        Display_LCD_String(0x40,LCD_DSY_BUFFER2);
