查看: 3587|回复: 2
带AT24C02存储的单片机六位密码锁Proteus仿真+代码
按行列键盘0~9输入六位密码数据存储到AT24C02,按“=”键从AT24C02中读取数据并在液晶屏中显示,再按“+/-”清屏。
按行列键盘0~9输入六位密码,按“=”验证密码,正确显示“TURE”,并且亮绿灯;错误显示“FLASE”,并且亮红灯,蜂鸣器响起。
如果输入验证密码过程中输入错误,可按“%”退位,也可按“?”清除所有密码。
  1. #include <reg52.H>
  2. #include "LCD1602_run.h"
  3. #include "LCD1602_mid_run.h"
  4. #include "keypad.h"
  5. #include "timer_Init.h"
  6. #include "iic.h"
  7. #include "at24c02.h"
  8. #include <string.h>
  9. sbit LedRed = P0^0;
  10. sbit LedGreen = P0^1;
  11. void main()
  12. {
  13.         unsigned char Cou;
  14.         unsigned char KeyBuff[7];
  15.         unsigned char KeyPassword[7];
  16.         unsigned char i;
  17.         unsigned char KeyBuffIndex=0;
  18.         unsigned char KeyBuffIndex2=0;
  19.   Timer_Init();
  20.         LCD_initial();
  21.         P0=0xff;
  22.         while(1)
  23.         {
  24.           if((KeyNum <= '9') && (KeyNum >= '0') && (KeyNum != '=')&& (KeyNum != 'c')) /*存密码*/
  25.                 {
  26.
  27.                         KeyBuff[KeyBuffIndex] = KeyNum;
  28.                         At24c02_Write_Add(KeyBuffIndex, KeyNum);
  29. //                         LCD1602_write_char(        0,KeyBuffIndex,' ');
  30.                         LCD1602_write_char(        0,KeyBuffIndex,'*');
  31.
  32.                         KeyBuffIndex++;
  33.                         if(KeyBuffIndex == 6)
  34.                         {
  35.                                 KeyBuff[KeyBuffIndex] = '\0';
  36.                                 KeyBuffIndex = 0;
  37.                         }
  38.                         while(KeyNum != 0x11);
  39.                 }
  40.
  41.                 if(KeyNum == '=')/*显示存储密码*/
  42.                 {
  43.
  44.                         LCD_write_cmd(0X01);
  45.                         while(KeyNum != 0x11);
  46.                         for(i = 0; i < 6; i++)
  47.                         {
  48.                                 KeyPassword [i] = At24c02_Read_Add(i);
  49.                         }
  50.                         KeyPassword [i] = '\0';
  51.                         LCD1602_write_string(1,0,KeyPassword);
  52.                         Cou = 0;
  53.
  54.                 }
  55.
  56.                 if(KeyNum == 'c') /*清屏*/
  57.                 {
  58.
  59.                         while(KeyNum != 0x11);
  60.                         LCD_write_cmd( 0x01 );
  61.                         break;
  62.                 }
  63.         }
  64.
  65.         while(1)
  66.         {
  67.                 if((KeyNum <= '9') && (KeyNum >= '0') && (KeyNum != '=') && (KeyNum != '%') && (KeyNum != '?') ) /*输入密码*/
  68.                         {
  69.                                 KeyBuff[KeyBuffIndex2] = KeyNum;
  70. //                                 LCD1602_write_char(        1,KeyBuffIndex2,KeyNum);
  71.                                 LCD1602_write_char(        0,KeyBuffIndex2,'*');
  72.
  73.                                 KeyBuffIndex2 ++;
  74.                                 if(KeyBuffIndex2 == 6)
  75.                                 {
  76.                                         KeyBuff[KeyBuffIndex2] = '\0';
  77.                                         KeyBuffIndex2 = 0;
  78.                                 }
  79.
  80.                                 //Cou ++;
  81.                                 while(KeyNum != 0x11);
  82.                         }
  83.
  84.                 if( (KeyNum == '%') && (KeyBuffIndex2 > 0 ) ) /*退位*/
  85.                 {
  86.                   KeyBuffIndex2 --;
  87. //                        KeyBuff[KeyBuffIndex] = KeyNum;
  88.                         LCD1602_write_char(        0,KeyBuffIndex2,' ');
  89. //                        KeyBuffIndex2 = KeyBuffIndex2 - 1;
  90.                         //LCD1602_write_char(        0,KeyBuffIndex2,'*');
  91.                         while(KeyNum != 0x11);
  92.                 }
  93.
  94.                 if(KeyNum == '?') /*清屏*/
  95.                 {
  96.
  97.                         while(KeyNum != 0x11);
  98.                         LCD_write_cmd( 0x01 );
  99.                         KeyBuffIndex2 = 0;
  100.
  101.                 }
  102.
  103.                 if( KeyNum == '=' )/*检验密码*/
  104.                 {
  105.                   for(i = 0; i < 6; i++)
  106.                         {
  107.                                 KeyPassword [i] = At24c02_Read_Add(i);
  108.                         }
  109.                          KeyPassword [i] = '\0';
  110.                          LCD_write_cmd( 0x01 );
  111.                         if( strcmp( KeyBuff,KeyPassword ) == 0 )
  112.                                 {
  113. ……………………
  114. …………限于本文篇幅 余下代码请从51黑下载附件…………
密码锁.rar (115.17 KB, 下载次数: 128)
收藏收藏4 分享淘帖 顶 踩
ID:447989 发表于 2018-12-17 15:56 | 只看该作者
谢谢分享!见识学习。
ID:442274 发表于 2021-5-18 22:15 | 只看该作者
初始界面液晶无显示,要按键才显示*号的密文
