查看: 3220|回复: 0
51单片机MODBUS框架程序
新鲜出炉的MODBUS框架程序,有不足的地方望大家指出
  1. #include <all.h>
  2. unsigned char xdata Modbus_Read_Buffer[256] = 0;  //数据接收缓冲区
  3. unsigned char xdata Modbus_Write_Buffer[256] = 0; //数据发送缓冲区
  4. unsigned int Modbus_Read_Value = 0;        //接收字节计数
  5. unsigned int Modbus_Write_Value = 0;  //发送字节计数
  6. unsigned char Modbus_Read_Complete = 0; //帧接收完成标志位
  7. unsigned int Modbus_CRC_Cecode(unsigned char *puchMsg, unsigned int usDataLen);        //CRC校验
  8. void Modbus_Init();        //帧检测定时器
  9. void Modbus_data_Decode();
  10. void Modbus_Init()//利用定时器2来计算数据帧 定时1MS
  11. {
  12.         AUXR |= 0x04;//定时器2用作定时,不分频
  13.         IE2 |= 0x04;//允许定时器2中断
  14.         T2L = 0xCD;                //设置定时初值
  15.         T2H = 0xD4;                //设置定时初值
  16.         EA = 1;  //开总中断
  17.         AUXR |= 0x10;
  18. }
  19. unsigned int Modbus_CRC_Cecode(unsigned char *puchMsg, unsigned int usDataLen)
  20. {
  21.
  22.          unsigned int i,j,CRC_Reg,Check;
  23.          CRC_Reg = 0xFFFF;
  24.          for(i=0;i<usDataLen;i++)
  25.          {
  26.                 CRC_Reg = CRC_Reg ^ (unsigned int)*(puchMsg + i);
  27.                 for(j=0;j<8;j++)
  28.                 {
  29.                         Check = CRC_Reg & 0x0001;
  30.                         CRC_Reg >>= 1;
  31.                         if(Check==0x0001)
  32.                         {
  33.                                 CRC_Reg ^= 0xA001;
  34.                         }
  35.                 }
  36.          }
  37.
  38.          return CRC_Reg;
  39. }
  40. void Modbus_data_Decode()
  41. {
  42.          unsigned int CRC_Data,i;
  43.          unsigned char CRC_H, CRC_L;
  44.
  45.         if(Modbus_Read_Complete)
  46.         {
  47.                  EA = 0;
  48.                  Modbus_Read_Complete = 0;
  49.                  CRC_Data = Modbus_CRC_Cecode(Modbus_Read_Buffer,Modbus_Read_Value-2);
  50.
  51.                  CRC_H = CRC_Data >> 8;
  52.                  CRC_L = CRC_Data & 0x00ff;
  53.
  54.                  if((CRC_H == Modbus_Read_Buffer[Modbus_Read_Value-1]) && (CRC_L == Modbus_Read_Buffer[Modbus_Read_Value-2]))
  55.                  {
  56.                          //这里可以开始分析数据 程序进入这里就证明CRC检验已经通过了
  57.                         Modbus_Write_Value = 0; //清除发送直接计数 ,调试用
  58.                          for(i = 0; i < (Modbus_Read_Value-2); i++)         //调试用主要把接收的数据发送出去
  59.                         {
  60.                                 Modbus_Write_Buffer[i] = Modbus_Read_Buffer[i];         //调试用
  61.                                 Modbus_Write_Value++;                                                    //调试用
  62.                         }
  63.                  }
  64.                  Modbus_Write_Buffer[Modbus_Write_Value] = CRC_L;          //调试用
  65.                  Modbus_Write_Value++;        //调试用
  66.                  Modbus_Write_Buffer[Modbus_Write_Value] = CRC_H;           //调试用
  67.                  Modbus_Read_Value = 0;                //接收直接数清零
  68.
  69.                  EA = 1;
  70.                  for(i = 0; i <= Modbus_Write_Value; i++)                 //调试用
  71.                  {
  72.                          SBUF = Modbus_Write_Buffer[i];                          //调试用
  73.                         while(!TI);        //调试用
  74.                  }
  75.                  Modbus_Write_Value = 0;                                          //调试用
  76.
  77.          }
  78. }
  79. /* 串口接收监控,由空闲时间判定帧结束,需在定时中断中调用,ms-定时间隔 */
  80. void UartRxMonitor(unsigned char ms)
  81. {
  82.     static unsigned char cntbkp = 0;
  83.     static unsigned char idletmr = 0;
  84.     if (Modbus_Read_Value > 0)  //接收计数器大于零时,监控总线空闲时间
  85.     {
  86.         if (cntbkp != Modbus_Read_Value)  //接收计数器改变,即刚接收到数据时,清零空闲计时
  87.         {
  88.             cntbkp = Modbus_Read_Value;
  89.             idletmr = 0;
  90.         }
  91.         else                   //接收计数器未改变,即总线空闲时,累积空闲时间
  92.         {
  93.             if (idletmr < 2)  //空闲计时小于30ms时,持续累加
  94.             {
  95.                 idletmr += ms;
  96.                 if (idletmr >= 2)  //空闲时间达到2ms时,即判定为一帧接收完毕
  97.                 {
  98.                                         Modbus_Read_Complete = 1;  //设置帧接收完成标志
  99.                 }
  100.             }
  101.         }
  102.     }
  103.     else
  104.     {
  105.         cntbkp = 0;
  106.     }
  107. }
  108. void Timer2_Routine() interrupt 12
  109. {
  110.         UartRxMonitor(1);
  111.
  112. }
MODBUS调试.zip (44.77 KB, 下载次数: 83)
收藏收藏1 分享淘帖 顶 踩
