200黑币
整个流程为:mcu通过内部中断PWM方式产生可调输出电压,接到PCF8591的AIN3,返回uchar类型,然后通过mcu显示到lcd上。
现在问题是:不论我如何改变pwm的占空比,再或者不论PCF有没有输入都会输出4.8。之前在考虑是不是i2c读字节前需要空读,但是没有能够写出来,求助。
有思路的可以留言可以QQ联系,谢谢。
只要能解决,500黑币都给!
main.c
- <div>#include <reg51.h> //51寄存器文件
- #include <intrins.h>
- #include <I2C.H>
- #include"1602.h"
- #define PCF8591 0x90 //PCF8591 地址</div><div>typedef unsigned int uint;//WORD代替unsigned int
- typedef unsigned char uchar;
- unsigned char timer0,timer1,second,second1;
- unsigned int count,count1,mid;
- unsigned int key;
- unsigned char v,ss,aa;
- unsigned long test_ss;
- sbit PWM=P3^7;
- unsigned int i,j;
- unsigned char Data,keyFlag;
- uint a,b,c;
- uchar shi,ge,ms,vt;
- uint a,b,c,o;
- float why;</div><div>void scan_key();
- int T1s();</div><div>uchar dis1[] = {"V1:"};
- uchar dis2[] = {"V2:"};
- uchar dis1t[] = {"T1:"};
- uchar dis2t[] = {"T2:"};
- uchar dist1[] = "00.0s";
- uchar dist2[] = "00.0x";</div><div>void system_Ini()
- TMOD = 0x11;
- //PWM
- TH0 = 0xff;
- TL0 = 0xf7;
- TH1 = 0xff;
- TL1 = 0xf7;
- EA = 1;
- ET0 = 1;
- ET1 = 1;
- TR0 = 1;
- TR1 = 1;
- //IE =0x8A;
- ADC发送字节[命令]数据函数
- bit ISendByte(unsigned char sla,unsigned char c)
- Start_I2c(); //启动总线
- SendByte(sla); //发送器件地址
- if(ack==0)return(0);
- SendByte(c); //发送数据
- Stop_I2c(); //结束总线
- return(1);
- ADC读字节数据函数
- unsigned char IRcvByte(unsigned char sla)
- { unsigned char c = 0;
- SendByte(sla+1); //发送器件地址
- c=RcvByte(); //读取第1路电压值,范围是0-255
- c=0;
- //for(what=0;what<5;what++)//连续读5次,取最后一次,以便读取稳定值
- Ack_I2c(1); //发送非就答位
- return(c);
- main()
- BYTE i;
- //uchar shi,ge;
- lcd_init(); //初始化LCD
- system_Ini();
- delay(10);
- lcd_pos(0); //设置显示位置为第一行的第1个字符
- i = 0;
- while(dis1[i] != '\0')
- { //显示字符"一号电压"
- lcd_wdat(dis1[i]);
- i++;
- lcd_pos(8); //设置显示位置为第一行的第9个字符
- i = 0;
- { //显示字符"一号时间"
- lcd_wdat(dis1t[i]);
- i++;
- lcd_pos(0x40); //设置显示位置为第二行第1个字符
- i = 0;
- while(dis2[i] != '\0')
- lcd_wdat(dis2[i]); //显示字符"二号电压"
- i++;
- lcd_pos(0x48); //设置显示位置为第二行第9个字符
- i = 0;
- lcd_wdat(dis2t[i]); //显示字符"二号时间"
- i++;
- lcd_pos(0x4b); //设置显示位置为第一行的第12个字符
- lcd_wdat(0x30+0);
- lcd_pos(0x4c); //设置显示位置为第一行的第12个字符
- lcd_wdat(0x30+0);
- lcd_pos(0x4d); //设置显示位置为第一行的第12个字符
- lcd_wdat('.');
- lcd_pos(0x4e); //设置显示位置为第一行的第12个字符
- lcd_wdat(0x30+0);
- //while(1);
- lcd_pos(3); //设置显示位置为第一行的第12个字符
- lcd_wdat(0x30+0);
- lcd_pos(4); //设置显示位置为第一行的第12个字符
- lcd_wdat('.');
- lcd_pos(5); //设置显示位置为第一行的第12个字符
- lcd_wdat(0x30+0);
- while(1)
- //if(ms>0) ISendByte(PCF8591,0x43);
- if((count>0)&&(keyFlag == 1))
- ISendByte(PCF8591,0x43);
- Data=IRcvByte(PCF8591);
- ss=Data*48/255;
- a = ss/10 ;
- b = (ss)%10;
- //c = (ss-a*100-b*10)%10;
- lcd_wdat('0'+a);
- lcd_wdat('.');
- lcd_wdat(0x30+b);
- //lcd_pos(6); //设置显示位置为第一行的第12个字符
- //lcd_wdat(0x30+c);
- shi=second/10;
- ge=second%10;
- lcd_pos(0x4b); //设置显示位置为第2行的第12个字符
- lcd_wdat(0x30+shi);
- lcd_pos(0x4c); //设置显示位置为第2行的第12个字符
- lcd_wdat(0x30+ge);
- lcd_pos(0x4d); //设置显示位置为第2行的第12个字符
- lcd_wdat('.');
- lcd_pos(0x4e); //设置显示位置为第2行的第12个字符
- lcd_wdat(0x30+ms);
- [ t1 (0.5ms)中断] 中断中做 PWM 输出
- ------------1000/(0.02ms*250)=200Hz
- void T0zd(void) interrupt 1 //3 为定时器1的中断号 1 定时器0的中断号 0 外部中断1 2 外部中断2 4 串口中断
- scan_key(); //检测按键
- switch(key){
- case 8:
- keyFlag = 1;
- TR0 = 0;
- TH0 = 0xff;
- TL0 = 0xf7;
- TR0 = 1;
- timer1++;
- if(timer1>=100)
- timer1=0;
- ms++;
- vt++;
- if(timer1<=0) PWM=1;
- else PWM=0;
- if(ms == 10)
- ms = 0;
- count++;
- if(count == 10)
- count = 0;
- second++;
- if(second == 60)
- second = 0;
- else
- }break;
- default:;
- void T1zd(void) interrupt 3 //3 为定时器1的中断号 1 定时器0的中断号 0 外部中断1 2 外部中断2 4 串口中断
- void scan_key() //按键检测函数
- if(P1== 0xfe)
- key= 1;
- if(P1== 0xfd)
- key= 2;
- if(P1== 0xfb)
- key= 3;
- if(P1== 0xf7)
- key= 4;
- if(P1== 0xef)
- key= 5;
- if(P1== 0xdf)
- key= 6;
- if(P1== 0xbf)
- key= 7;
- if(P1== 0x7f)
- key= 8;
- </div>
I2C.c
