查看: 5904|回复: 9
51单片机用DAC0832和运放构成的四种波形发生器(仿真+源程序)
ID:344053 发表于 2018-12-17 18:42 | 显示全部楼层 |阅读模式
原程序过于复杂 修改后舍去了外部中断优化了程序结构 用数组替换了原来的正弦波产生函数 添加了部分注释
程序和仿真比较完美了
能产生比较完美的正弦波了,也比较容易理解。
  1. /*******************************************************************
  2. 感谢javaleilei的分享
  3. 对于之前程序过于复杂 舍去了外部中断优化了程序结构 用数组替换了原来的正弦波产生函数 添加了部分注释
  4. 程序和仿真比较完美了
  5. 最终修改 BY:Pia Ji
  6. *******************************************************************/
  7. #include <reg51.h>
  8. unsigned char flag=0;
  9. sbit key1 = P3^0;
  10. sbit key2 = P3^1;
  11. sbit key3 = P3^2;
  12. sbit key4 = P3^3;
  13. unsigned char code sin_num[]={
  14. 0,0,0,0,0,0,0,0,1,1,1,1,1,2,2,2,
  15. 2,3,3,4,4,4,5,5,6,6,7,7,8,8,9,9,
  16. 10,10,11,12,12,13,14,15,15,16,17,18,18,19,20,21,
  17. 22,23,24,25,25,26,27,28,29,30,31,32,34,35,36,37,
  18. 38,39,40,41,42,44,45,46,47,49,50,51,52,54,55,56,
  19. 57,59,60,61,63,64,66,67,68,70,71,73,74,75,77,78,
  20. 80,81,83,84,86,87,89,90,92,93,95,96,98,99,101,102,
  21. 104,106,107,109,110,112, 113,115,116,118,120,121,123,124,126,128,
  22. 129,131, 132,134,135, 137, 139,140,142,143,145,146,148, 149,151,153,
  23. 154,156,157,159,160,162,163,165, 166,168,169,171,172,174,175,177,
  24. 178,180,181, 182,184,185,187,188,189,191,192,194,195,196,198,199,
  25. 200,201,203,204,205,206,208,209,210,211,213,214,215,216,217,218,
  26. 219,220,221,223,224,225,226,227,228,229,230,230,231,232,233,234,
  27. 235,236,237,237,238,239,240,240,241,242,243,243,244,245,245,246,
  28. 246,247,247,248,248,249,249,250,250,251,251, 251,252,252,253,253,
  29. 253,253,254,254,254,254,254,255,255,255,255, 255,255,255,255,255
  30. }; //这是正弦波上升半周期的采样
  31. void delay(unsigned int x)//延时
  32. {
  33.         while(--x);
  34. }
  35. void key_pors()//按键处理函数
  36. {
  37.         if(key1==0)
  38.                 flag=0;
  39.         else if(key2==0)
  40.                 flag=1;
  41.         else if(key3==0)
  42.                 flag=2;
  43.         else if(key4==0)
  44.                 flag=3;
  45. }
  46. void show_wave()
  47. {
  48.         int i;
  49.         switch(flag)
  50.   {
  51.    case 0: //三角波
  52.                         for(i=0;i<255;i++)
  53.                         {
  54.                                 P1=i;
  55.                         }
  56.                         for(i=255;i>0;i--)
  57.                         {
  58.                                 P1=i;
  59.                         }
  60.                         break;
  61.
  62.           case 1://方波
  63.                         P1=0;
  64.                         delay(100);
  65.                         P1=0xff;
  66.                         delay(100);
  67.                         break;
  68.
  69.           case 2://三角波
  70.                         for(i=255;i>0;i--)
  71.                                 P1=i;
  72.                         break;
  73.
  74.           case 3: //正弦波 采用数组采样值 波形更好
  75.                         for(i=0;i<255;i++)
  76.                                 P1=sin_num[i];
  77.                         for(i=255;i>=0;i--)
  78.                                 P1=sin_num[i];
  79.                         break;
  80.           default : P1=0;//否则为0 防错
  81.         }
  82. }
  83. void main()
  84. {
  85.         while(1)
  86.         {
  87.                 key_pors();
  88.                 show_wave();
  89.         }
  90. }
四种波形发生器.zip (102.28 KB, 下载次数: 185)
ID:344053 发表于 2018-12-18 18:57 | 显示全部楼层
zhf1689878504 发表于 2018-12-18 13:23
楼主还有没有原来的程序呀
有原来没改过的程序,可以发你,也可以给你原帖子连接自己下载
ID:559306 发表于 2019-6-11 20:50 | 显示全部楼层
仿真图怎么没有啊
ID:559306 发表于 2019-6-11 21:17 | 显示全部楼层
仿真图呢
ID:344053 发表于 2019-7-14 09:25 | 显示全部楼层
在文件里面呢 用的 Proteus8.6 老版本可能没关联文件 不支持。
ID:697110 发表于 2020-2-24 23:43 | 显示全部楼层
你好,请问一下正弦信号的码表是怎么来的呢
ID:344053 发表于 2020-3-4 09:05 | 显示全部楼层
你好,可以使用Sin函数计算取出,也可用百度搜索,有专门的网站的。做成码表只是为了方便单片机处理,节省不必要的处理时间。
ID:736498 发表于 2020-4-24 11:42 | 显示全部楼层
请问怎么实现频率可调啊
ID:344053 发表于 2020-4-28 16:53 | 显示全部楼层
兽人大只佬 发表于 2020-4-24 11:42
请问怎么实现频率可调啊
您好,正弦波建议使用SIN函数,用定时器定时改变输入值来实现频率可调。方波使用定时器直接翻转输出即可。
