查看: 2095|回复: 0
单片机数码管显示时间的程序问题 求分析
ID:400074 发表于 2018-12-28 08:09 | 显示全部楼层 |阅读模式
谁能帮我分析下,数码管单独显示时分秒可以得,但按键按下切换到年月日时就只能显示1个1了,哪位老师帮忙指导下
#include <reg52.h>
#include <intrins.h>
#define DATA  P0
typedef unsigned char u8;
typedef unsigned int u16;
sbit seg_sel = P1^4;
sbit bit_sel = P1^5;
sbit key = P3^2;
u8 count ;
u8 shi,fen,miao;
u8 code seg_tab[]={
                          0xc0,0xf9,0xa4,0xb0,
                          0x99,0x92,0x82,0xf8,
                          0x80,0x90,0x88,0x83,
                          0xc6,0xa1,0x86,0x8e,0xbf
u8 code bit_tab[]={
                          0x10,0x20,0x40,0x80,
                          0x01,0x02,0x04,0x08
void delay(u16 num)
        u16 x,y;
        for(x=num;x>0;x--)
        for(y=110;y>0;y--);
void led_display(u8 which_bit,u8 which_num)
         bit_sel = 1;
         DATA = bit_tab[which_bit];
         bit_sel = 0;
         seg_sel = 1;
         DATA = seg_tab[which_num];
         seg_sel = 0;
         delay(2);
void display_shi(u8 which_bit,u8 num)
   u8 x,y;
   x = num/10;
   y = num%10;
   if(which_bit == 1)
             led_display(0,y);
          delay(1);
          led_display(1,x);
          delay(2);
          led_display(2,seg_tab[17]) ;
   if(which_bit == 2)
             led_display(3,y);
           delay(1);
          led_display(4,x);
         delay(2);
         led_display(5,seg_tab[17]);
   if(which_bit == 3)
              led_display(6,y);
    delay(1);
           led_display(7,x);
           delay(2);
void display_nian(u8 which_bit)
           if(which_bit == 1)
             led_display(0,6);
          delay(1);
          led_display(1,2);
          delay(2);
    if(which_bit == 2)
             led_display(3,2);
          delay(1);
          led_display(4,1);
  delay(2);
          led_display(5,seg_tab[17]) ;
    if(which_bit == 3)
             led_display(6,8);
          delay(1);
          led_display(7,1);
          delay(2);
void main ()
           TMOD = 0X01;
        TH0 =(65536-50000)/256;
        TL0 = (65536-50000)%256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
        DATA = 0xff;
        display_shi(1,miao);
                display_shi(2,fen);
                display_shi(3,shi);
                if(key==1)
                display_shi(2,fen);
                display_shi(3,shi);
          if(key==0)
                   delay(10);
                 if(key==0)
                  display_nian(1);
                display_nian(2);
                display_nian(3);
                 } while(!key);
void LED_0() interrupt 1
        count++;
        if(count==20)
           count=0;
           miao++;
           if(miao==60)
                     miao=0;
                  fen++;
                  if(fen==60)
                           fen=0;
                         shi++;
                         if(shi==23)
                                 shi=0;
