查看: 7659|回复: 2
求大神指点一下为啥电子密码锁(液晶显示)能输入管理员密码,但是初始化密码....
ID:457687 发表于 2018-12-28 22:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有木有大神指点一下,为啥电子密码锁(液晶显示)能输入管理员密码,但是初始化密码显示错误
  1. //包含头文件
  2. #include <REG51.h>
  3. #include<intrins.h>
  4. //宏定义
  5. #define LCM_Data  P0                  //将P0口定义为LCM_Data
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. //1602的控制脚
  9. sbit lcd1602_rs=P2^4;
  10. sbit lcd1602_rw=P2^5;
  11. sbit lcd1602_en=P2^6;
  12. sbit Scl=P1^1;                        //24C02串行时钟
  13. sbit Sda=P1^2;                        //24C02串行数据
  14. sbit ALAM = P1^3;                //报警
  15. sbit KEY = P1^6;                //开锁
  16. bit  pass=0;                        //密码正确标志
  17. bit  ReInputEn=0;                //重置输入允许标志
  18. bit  s3_keydown=0;                //3秒按键标志位
  19. bit  key_disable=0;                //锁定键盘标志
  20. unsigned char countt0,second;        //t0中断计数器,秒计数器
  21. void Delay5Ms(void);                //声明延时函数
  22. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盘扫描控制表
  23. //液晶显示数据数组
  24. unsigned char code start_line[]        = {"password:       "};
  25. unsigned char code name[]                  = {"===Coded Lock==="};        //显示名称
  26. unsigned char code Correct[]         = {"     correct    "};                //输入正确
  27. unsigned char code Error[]           = {"      error     "};          //输入错误
  28. unsigned char code codepass[]        = {"      pass      "};
  29. unsigned char code LockOpen[]        = {"      open      "};                //OPEN
  30. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  31. unsigned char code Input[]           = {"input:          "};                //INPUT
  32. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  33. unsigned char code initword[]        = {"Init password..."};
  34. unsigned char code Er_try[]                = {"error,try again!"};
  35. unsigned char code again[]                = {"input again     "};
  36. unsigned char InputData[6];        //输入密码暂存区
  37. unsigned char CurrentPassword[6]={0,0,0,0,0,0};                         //读取EEPROM密码暂存数组
  38. unsigned char TempPassword[6];
  39. unsigned char N=0;                                //密码输入位数记数
  40. unsigned char ErrorCont;                        //错误次数计数
  41. unsigned char CorrectCont;                        //正确输入计数
  42. unsigned char ReInputCont;                         //重新输入计数
  43. unsigned char code initpassword[6]={0,0,0,0,0,0};                        //输入管理员密码后将密码初始为000000
  44. unsigned char code adminpassword[6]={1,3,1,4,2,0};                        //输入管理员密码后将密码初始为000000
  45. //=====================5ms延时==============================
  46. void Delay5Ms(void)
  47. {
  48.         unsigned int TempCyc = 5552;
  49.         while(TempCyc--);
  50. }
  51. //===================400ms延时==============================
  52. void Delay400Ms(void)
  53. {
  54. unsigned char TempCycA = 5;
  55. unsigned int TempCycB;
  56. while(TempCycA--)
  57. {
  58.   TempCycB=7269;
  59.   while(TempCycB--);
  60. }
  61. }
  62. //================================24C02========================================================
  63. void mDelay(uint t) //延时
  64. {
  65.         uchar i;
  66.            while(t--)
  67.            {
  68.                    for(i=0;i<125;i++)
  69.                    {;}
  70.            }
  71. }
  72. void Nop(void)                  //空操作
  73. {
  74.          _nop_();                  //仅作延时用一条语句大约1us
  75.          _nop_();
  76.          _nop_();
  77.          _nop_();
  78. }
  79. /*****24c02程序参照24c02时序图*****/
  80. /*起始条件*/
  81. void Start(void)
  82. {
  83.          Sda=1;
  84.          Scl=1;
  85.          Nop();
  86.          Sda=0;
  87.          Nop();
  88. }
  89. /*停止条件*/
  90. void Stop(void)
  91. {
  92.          Sda=0;
  93.          Scl=1;
  94.          Nop();
  95.          Sda=1;
  96.          Nop();
  97. }
  98. /*应答位*/
  99. void Ack(void)
  100. {
  101.         Sda=0;
  102.         Nop();
  103.         Scl=1;
  104.         Nop();
  105.         Scl=0;
  106. }
  107. /*反向应答位*/
  108. void NoAck(void)
  109. {
  110.          Sda=1;
  111.          Nop();
  112.          Scl=1;
  113.          Nop();
  114.          Scl=0;
  115. }
  116. /*发送数据子程序,Data为要求发送的数据*/
  117. void Send(uchar Data)
  118. {
  119.            uchar BitCounter=8;
  120.            uchar temp;
  121.            do
  122.            {
  123.                    temp=Data;                                           //将待发送数据暂存temp
  124.                    Scl=0;
  125.                    Nop();
  126.                    if((temp&0x80)==0x80)                   //将读到的数据&0x80
  127.                    Sda=1;
  128.                    else
  129.                    Sda=0;
  130.                    Scl=1;
  131.                    temp=Data<<1;                                   //数据左移
  132.                    Data=temp;                                           //数据左移后重新赋值Data
  133.                    BitCounter--;                                   //该变量减到0时,数据也就传送完成了
  134.            }
  135.            while(BitCounter);                                   //判断是否传送完成
  136.            Scl=0;
  137. }
  138. /*读一字节的数据,并返回该字节值*/
  139. uchar Read(void)
  140. {
  141.     uchar temp=0;
  142.         uchar temp1=0;
  143.         uchar BitCounter=8;
  144.         Sda=1;
  145.         do
  146.         {
  147.                 Scl=0;
  148.                 Nop();
  149.                 Scl=1;
  150.                 Nop();
  151.                 if(Sda)                                   //数据位是否为1
  152.                         temp=temp|0x01;           //为1 temp的最低位为1(|0x01,就是将最低位变为1)
  153.                 else                                   //如果为0
  154.                         temp=temp&0xfe;           //temp最低位为0(&0xfe(11111110)最低位就是0)
  155.                 if(BitCounter-1)           //BitCounter减1后是否为真
  156.                 {
  157.                         temp1=temp<<1;           //temp左移
  158.                         temp=temp1;
  159.                 }
  160.                 BitCounter--;                   //BitCounter减到0时,数据就接收完了
  161.         }
  162.         while(BitCounter);                   //判断是否接收完成
  163.         return(temp);
  164. }
  165. void WrToROM(uchar Data[],uchar Address,uchar Num)
  166. {
  167.   uchar i;
  168.   uchar *PData;
  169.   PData=Data;
  170.   for(i=0;i<Num;i++)
  171.   {
  172.   Start();
  173.   Send(0xa0);
  174.   Ack();
  175.   Send(Address+i);
  176.   Ack();
  177.   Send(*(PData+i));
  178.   Ack();
  179.   Stop();
  180.   mDelay(20);
  181.   }
  182. }
  183. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  184. {
  185.   uchar i;
  186.   uchar *PData;
  187.   PData=Data;
  188.   for(i=0;i<Num;i++)
  189.   {
  190.   Start();
  191.   Send(0xa0);
  192.   Ack();
  193.   Send(Address+i);
  194.   Ack();
  195.   Start();
  196.   Send(0xa1);
  197.   Ack();
  198.   *(PData+i)=Read();
  199.   Scl=0;
  200.   NoAck();
  201.   Stop();
  202.   }
  203. }
  204. //=======================================LCD1602====================================================
  205. #define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
  206. #define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
  207. //----------------延时函数,后面经常调用----------------------
  208. void delay(uint xms)//延时函数,有参函数
  209. {
  210.         uint x,y;
  211.         for(x=xms;x>0;x--)
  212.          for(y=110;y>0;y--);
  213. }
  214. //--------------------------写指令---------------------------
  215. void write_1602com(uchar com)//****液晶写入指令函数****
  216. {
  217.         lcd1602_rs=0;//数据/指令选择置为指令
  218.         lcd1602_rw=0; //读写选择置为写
  219.         P0=com;//送入数据
  220.         delay(1);
  221.         lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
  222.         delay(1);
  223.         lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
  224. }
  225. //-------------------------写数据-----------------------------
  226. void write_1602dat(uchar dat)//***液晶写入数据函数****
  227. {
  228.         lcd1602_rs=1;//数据/指令选择置为数据
  229.         lcd1602_rw=0; //读写选择置为写
  230.         P0=dat;//送入数据
  231.         delay(1);
  232.         lcd1602_en=1; //en置高电平,为制造下降沿做准备
  233.         delay(1);
  234.         lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
  235. }
  236. //-------------------------初始化-------------------------
  237. void lcd_init(void)
  238. {
  239.         write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
  240.         write_1602com(0x0c);//开显示不显示光标
  241.         write_1602com(0x06);//整屏不移动,光标自动右移
  242.         write_1602com(0x01);//清显示
  243. }
  244. //==============将按键值编码为数值=========================
  245. unsigned char coding(unsigned char m)
  246. {
  247.         unsigned char k;
  248.         switch(m)
  249.         {
  250.           case (0x11): k=1;break;
  251.                 case (0x21): k=2;break;
  252.                 case (0x41): k=3;break;
  253.                 case (0x81): k='A';break;
  254.                 case (0x12): k=4;break;
  255.                 case (0x22): k=5;break;
  256.                 case (0x42): k=6;break;
  257.                 case (0x82): k='B';break;
  258.                 case (0x14): k=7;break;
  259.                 case (0x24): k=8;break;
  260.                 case (0x44): k=9;break;
  261.                 case (0x84): k='C';break;
  262.                 case (0x18): k='*';break;
  263.                 case (0x28): k=0;break;
  264.                 case (0x48): k='#';break;
  265.                 case (0x88): k='D';break;
  266.                 /*case (0x12): k=1;break;
  267.                 case (0x14): k=4;break;
  268.                 case (0x18): k=7;break;
  269.                 case (0x21): k='*';break;
  270.                 case (0x22): k=2;break;
  271.                 case (0x24): k=5;break;
  272.                 case (0x28): k=8;break;
  273.                 case (0x11): k=0;break;
  274.                 case (0x42): k=3;break;
  275.                 case (0x44): k=6;break;
  276.                 case (0x48): k=9;break;
  277.                 case (0x41): k='#';break;
  278.                 case (0x88): k='A';break;
  279.                 case (0x84): k='B';break;
  280.                 case (0x82): k='C';break;
  281.                 case (0x81): k='D';break;*/
  282.         }
  283.         return(k);
  284. }
  285. //=====================按键检测并返回按键值===============================
  286. unsigned char keynum(void)
  287. {
  288.          unsigned char row,col,i;
  289.          P3=0xf0;
  290.          if((P3&0xf0)!=0xf0)
  291.          {
  292.                    Delay5Ms();
  293.         Delay5Ms();
  294.                    if((P3&0xf0)!=0xf0)
  295.                 {
  296.                     row=P3^0xf0;          //确定行线
  297.                         i=0;
  298.                         P3=a[i];                  //精确定位
  299.                         while(i<4)
  300.                         {
  301.                                  if((P3&0xf0)!=0xf0)
  302.                                   {
  303.                                            col=~(P3&0xff);          //确定列线
  304.                                            break;            //已定位后提前退出
  305.                                   }
  306.                                 else
  307.                                   {
  308.                                            i++;
  309.                                            P3=a[i];
  310.                                   }
  311.                         }
  312.                 }
  313.                 else
  314.                 {
  315.                         return 0;
  316.                 }
  317.                 while((P3&0xf0)!=0xf0);
  318.                 return (row|col);                         //行线与列线组合后返回
  319.          }
  320.          else return 0;                                 //无键按下时返回0
  321. }
  322. //=======================一声提示音,表示有效输入========================
  323. void OneAlam(void)
  324. {
  325.         ALAM=0;
  326.         Delay5Ms();
  327.     ALAM=1;
  328. }
  329. //========================二声提示音,表示操作成功========================
  330. void TwoAlam(void)
  331. {
  332.         ALAM=0;
  333.         Delay5Ms();
  334.     ALAM=1;
  335.     Delay5Ms();
  336.         ALAM=0;
  337.         Delay5Ms();
  338.     ALAM=1;
  339. }
  340. //========================三声提示音,表示错误========================
  341. void ThreeAlam(void)
  342. {
  343.         ALAM=0;
  344.         Delay5Ms();
  345.     ALAM=1;
  346.     Delay5Ms();
  347.         ALAM=0;
  348.         Delay5Ms();
  349.     ALAM=1;
  350.     Delay5Ms();
  351.         ALAM=0;
  352.         Delay5Ms();
  353.     ALAM=1;
  354. }
  355. //=====================显示输入的N个数字,用H代替以便隐藏============//
  356. void DisplayOne(void)
  357. {
  358. //        DisplayOneChar(9+N,1,'*');
  359.         write_1602com(yi+5+N);
  360.         write_1602dat('*');
  361. }
  362. void   DisplayOneChar(uchar X, uchar Y)        //按指定位置显示一个字符
  363. {
  364.   Y &= 0x01;
  365.   X &= 0x0F;              //限制X不能大于15,Y不能大于1
  366.   if (Y) X |= 0x40;       //当要显示第二行时地址码+0x40;
  367.   X |= 0x80;              //算出指令码
  368.   write_1602com(X);  //这里不检测忙信号,发送地址码
  369.         }
  370. //=======================显示提示输入=========================
  371. void DisplayChar(void)
  372. {
  373.         unsigned char i;
  374.         if(pass==1)
  375.         {
  376.                 //DisplayListChar(0,1,LockOpen);
  377.                 write_1602com(er);                                   //在二行开始显示
  378.                 for(i=0;i<16;i++)
  379.                 {
  380.                         write_1602dat(LockOpen[i]);           //显示open 开锁成功
  381.                 }
  382.         }
  383.         else
  384.         {
  385.                 if(N==0)
  386.                 {
  387.                         //DisplayListChar(0,1,Error);
  388.                         write_1602com(er);
  389.                         for(i=0;i<16;i++)
  390.                         {
  391.                                 write_1602dat(Error[i]);        //显示错误
  392.                         }
  393.                 }
  394.                 else
  395.                 {
  396.                         //DisplayListChar(0,1,start_line);
  397.                         write_1602com(er);
  398.                         for(i=0;i<16;i++)
  399.                         {
  400.                                 write_1602dat(start_line[i]);//显示开始输入
  401.                         }
  402.                 }
  403.         }
  404. }
  405. //========================重置密码==================================================
  406. void ResetPassword(void)
  407. {
  408.         unsigned char i;
  409.         unsigned char j;
  410.         if(pass==0)
  411.         {
  412.                 pass=0;
  413.                 DisplayChar();           //显示错误
  414.                 ThreeAlam();           //没开锁时按下重置密码报警3声
  415.         }
  416.         else                                   //开锁状态下才能进行密码重置程序
  417.         {
  418.             if(ReInputEn==1)   //开锁状态下,ReInputEn置1,重置密码允许
  419.                 {
  420.                         if(N==6)           //输入6位密码
  421.                         {
  422.                                 ReInputCont++;                        //密码次数计数
  423.                                 if(ReInputCont==2)                //输入两次密码
  424.                                 {
  425.                                         for(i=0;i<6;)
  426.                                         {
  427.                                                 if(TempPassword[i]==InputData[i])        //将两次输入的新密码作对比
  428.                                                         i++;
  429.                                                 else        //如果两次的密码不同
  430.                                                 {
  431.                                                         //DisplayListChar(0,1,Error);
  432.                                                         write_1602com(er);
  433.                                                         for(j=0;j<16;j++)
  434.                                                         {
  435.        write_1602dat(Error[j]);        //显示错误Error
  436.                                                         }
  437.                                                         ThreeAlam();                        //错误提示
  438.                                                         pass=0;                                        //关锁
  439.                                                         ReInputEn=0;                        //关闭重置功能,
  440.                                                         ReInputCont=0;
  441.                                                         DisplayChar();
  442.                                                         break;
  443.                                                 }
  444.                                         }
  445.                                         if(i==6)
  446.                                         {
  447.                                                 //DisplayListChar(0,1,ResetOK);
  448.                                                 write_1602com(er);
  449.                                                 for(j=0;j<16;j++)
  450.                                                 {
  451.                                                         write_1602dat(ResetOK[j]);          //密码修改成功,显示
  452.                                                 }
  453.                                                 TwoAlam();                                //操作成功提示
  454.                                                  WrToROM(TempPassword,0,6);                //将新密码写入24C02存储
  455.                                                 ReInputEn=0;
  456.                                         }
  457.                                         ReInputCont=0;
  458.                                         CorrectCont=0;
  459.                                 }
  460.                                 else                                          //输入一次密码时
  461.                                 {
  462.                                         OneAlam();
  463.                                         //DisplayListChar(0, 1, again);                 //显示再次输入一次
  464.                                         write_1602com(er);
  465.                                         for(j=0;j<16;j++)
  466.                                         {
  467.                                                 write_1602dat(again[j]);                        //显示再输入一次
  468.                                         }
  469.                                         for(i=0;i<6;i++)
  470.                                         {
  471.                                                 TempPassword[i]=InputData[i];                //将第一次输入的数据暂存起来
  472.                                         }
  473.                                 }
  474.                         N=0;                                                //输入数据位数计数器清零
  475.                    }
  476.             }
  477.         }
  478. }
  479. //=======================输入密码错误超过三过,报警并锁死键盘======================
  480. void Alam_KeyUnable(void)
  481. {
  482.         P1=0x00;
  483.         {
  484.                 ALAM=~ALAM;                                 //蜂鸣器一直闪烁鸣响
  485.                 Delay5Ms();
  486.         }
  487. }
  488. //=======================取消所有操作============================================
  489. void Cancel(void)
  490. {
  491.         unsigned char i;
  492.         unsigned char j;
  493.         //DisplayListChar(0, 1, start_line);
  494.         write_1602com(er);
  495.         for(j=0;j<16;j++)
  496.         {
  497.                 write_1602dat(start_line[j]);          //显示开机输入密码界面
  498.         }
  499.         TwoAlam();                                //提示音
  500.         for(i=0;i<6;i++)
  501.         {
  502.                 InputData[i]=0;                //将输入密码清零
  503.         }
  504.         KEY=1;                                        //关闭锁
  505.         ALAM=1;                                        //报警关
  506.         pass=0;                                        //密码正确标志清零
  507.         ReInputEn=0;                        //重置输入充许标志清零
  508.         ErrorCont=0;                        //密码错误输入次数清零
  509.         CorrectCont=0;                        //密码正确输入次数清零
  510.         ReInputCont=0;                        //重置密码输入次数清零
  511.         s3_keydown=0;
  512.         key_disable=0;                        //锁定键盘标志清零
  513.         N=0;                                        //输入位数计数器清零
  514. }
  515. //==========================确认键,并通过相应标志位执行相应功能===============================
  516. void Ensure(void)
  517. {
  518.         unsigned char i,j;
  519.         RdFromROM(CurrentPassword,0,6);                                         //从24C02里读出存储密码
  520.     if(N==6)
  521.         {
  522.             if(ReInputEn==0)                                                        //重置密码功能未开启
  523.                 {
  524.                         for(i=0;i<6;)
  525.                            {
  526.                                 if(CurrentPassword[i]==InputData[i])        //判断输入密码和24c02中的密码是否相同
  527.                                 {
  528.                                         i++;        //相同一位 i就+1
  529.                                 }
  530.                                 else        //如果有密码不同
  531.                                 {
  532.                                         ErrorCont++;                                                //错误次数++
  533.                                         if(ErrorCont==3)                        //错误输入计数达三次时,报警并锁定键盘
  534.                                         {
  535.                                                 write_1602com(er);
  536.                                                 for(i=0;i<16;i++)
  537.                                                 {
  538.                                                         write_1602dat(Error[i]);
  539.                                                 }
  540.                                                 do
  541.                                                 Alam_KeyUnable();
  542.                                                 while(1);
  543.                                         }
  544.                                         else                                         //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
  545.                                         {
  546.                                                 TR0=1;                                //开启定时
  547.                                                 key_disable=1;                        //锁定键盘
  548.                                                 pass=0;                                        //pass位清零
  549.                                                 break;                                        //跳出
  550.                                         }
  551.                                 }
  552.                         }
  553.                         if(i==6)                                         //密码输入对时
  554.                         {
  555.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  556.                                    {
  557.                                         WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
  558.                                         write_1602com(er);
  559.                                         for(j=0;j<16;j++)
  560.                                         {
  561.                                                 write_1602dat(initword[j]);                                //显示初始化密码
  562.                                         }
  563.                                         TwoAlam();        //成功提示音
  564.                                         Delay400Ms();        //延时400ms
  565.                                         TwoAlam();        //成功提示音
  566.                                         N=0;        //输入位数计数器清零
  567.                                 }
  568.                                 else
  569.                                 {
  570.                                         CorrectCont++;                                        //输入正确变量++
  571.                                         if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁
  572.                                         {
  573.                                                 //DisplayListChar(0,1,LockOpen);
  574.                                                 write_1602com(er);
  575.                                                 for(j=0;j<16;j++)
  576.                                                 {
  577.                                                         write_1602dat(LockOpen[j]);                  //显示open开锁画面
  578.                                                 }
  579.                                                 TwoAlam();                        //操作成功提示音
  580.                                                 KEY=0;        //开锁
  581.                                                 pass=1;        //置正确标志位
  582.                                                 TR0=1;        //开启定时
  583.                                                 for(j=0;j<6;j++)        //将输入清除
  584.                                                 {
  585.                                                         InputData[i]=0;        //开锁后将输入位清零
  586.                                                 }
  587.                                         }
  588.                                         else        //当两次正确输入时,开启重置密码功能
  589.                                         {
  590.                                                 write_1602com(er);
  591.                                                 for(j=0;j<16;j++)
  592.                                                 {
  593.                                                         write_1602dat(SetNew[j]);                                        //显示重置密码界面
  594.                                                 }
  595.                                                 TwoAlam();        //操作成功提示
  596.                                                 ReInputEn=1;        //允许重置密码输入
  597.                                                 CorrectCont=0;        //正确计数器清零
  598.                                         }
  599.                                 }
  600.                           }
  601.
  602.                         else                        //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
  603.                         {
  604.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  605.                                    {
  606.                                         WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
  607.                                         write_1602com(er);
  608.                                         for(j=0;j<16;j++)
  609.                                         {
  610.                                                 write_1602dat(initword[j]);                                //显示初始化密码
  611.                                         }
  612.                                         TwoAlam();        //成功提示音
  613.                                         Delay400Ms();        //延时400ms
  614.                                         TwoAlam();        //成功提示音
  615.                                         N=0;        //输入位数计数器清零
  616.                                 }
  617.                                 else        //密码输入错误
  618.                                 {
  619.                                         write_1602com(er);
  620.                                         for(j=0;j<16;j++)
  621.                                         {
  622.                                                 write_1602dat(Error[j]);                                 //显示错误信息
  623.                                         }
  624.                                          ThreeAlam();        //错误提示音
  625.                                         pass=0;
  626.                                 }
  627.                         }
  628.                 }
  629.                 else        //当已经开启重置密码功能时,而按下开锁键,
  630.                 {
  631.                         //DisplayListChar(0,1,Er_try);
  632.                         write_1602com(er);
  633.                         for(j=0;j<16;j++)
  634.                         {
  635.                                 write_1602dat(Er_try[j]);                          //错误,请重新输入
  636.                         }
  637.                         ThreeAlam();                                                          //错误提示音
  638.                 }
  639.         }
  640.         else                                   //密码没有输入到6位时,按下确认键时
  641.         {
  642.                 //DisplayListChar(0,1,Error);
  643.                 write_1602com(er);
  644.                 for(j=0;j<16;j++)
  645.                 {
  646.                         write_1602dat(Error[j]);                 //显示错误
  647.                 }
  648.                  ThreeAlam();        //错误提示音
  649.                 pass=0;
  650.         }
  651.
  652.         N=0;        //将输入数据计数器清零,为下一次输入作准备
  653. }
  654. //==============================主函数===============================
  655. void main(void)
  656. {
  657.          unsigned char KEY,NUM;
  658.         unsigned char i,j;
  659.          P3=0xFF;                                    //P3口复位
  660.         TMOD=0x11;                                   //定义工作方式
  661.          TL0=0xB0;
  662.          TH0=0x3C;                                   //定时器赋初值
  663.          EA=1;                                           //打开中断总开关
  664.          ET0=1;                                           //打开中断允许开关
  665.          TR0=0;                                           //打开定时器开关
  666.          Delay400Ms();         //启动等待,等LCM讲入工作状态
  667.          lcd_init();         //LCD初始化
  668.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  669.         for(i=0;i<16;i++)
  670.         {
  671.                 write_1602dat(name[i]);//向液晶屏写开机画面
  672.         }
  673.         write_1602com(er);
  674.         for(i=0;i<16;i++)
  675.         {
  676.                 write_1602dat(start_line[i]);//写输入密码等待界面
  677.         }
  678.         write_1602com(er+9);        //设置光标位置
  679.         write_1602com(0x0f);        //设置光标为闪烁
  680.          Delay5Ms(); //延时片刻(可不要)
  681.          N=0;        //初始化数据输入位数
  682.          while(1)                 //进入循环
  683.          {
  684.                 if(key_disable==1)                                                //锁定键盘标志为1时
  685.                         Alam_KeyUnable();                                        //报警键盘锁
  686.                 else
  687.                         ALAM=1;        //关报警
  688.                 KEY=keynum();                                                        //读按键的位置码
  689.                 if(KEY!=0)        //当有按键按下时
  690.                 {
  691.                         if(key_disable==1)                                        //锁定键盘标志为1时
  692.                         {
  693.                                 second=0;                                                //秒清零
  694.                         }
  695.                         else        //没有锁定键盘时
  696.                         {
  697.                                 NUM=coding(KEY);                                //根据按键的位置将其编码,编码值赋值给NUM
  698.                                 {
  699.                                         switch(NUM)                                        //判断按键值
  700.                                         {
  701.                                                 case ('A'):         ;                                         break;
  702.                                                 case ('B'):                ;                                     break;
  703.                                                 case ('C'):
  704.        write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  705.        for(i=0;i<16;i++)
  706.        {
  707.        write_1602dat(name[i]);//向液晶屏写开机画面
  708.        }
  709.        if(N>=1) N--;        OneAlam();        //按键提示音
  710.        //DisplayOneChar(6+N,1,'*');
  711.        for(j=N;j<16;j++)
  712.        {
  713.        write_1602com(er+6+j);
  714.        write_1602dat(' ');
  715.        }
  716.        for(j=0;j<N;j++)
  717.        {
  718.        write_1602com(er+6+j);                                //显示位数随输入增加而增加
  719.        write_1602dat('*');                                        //但不显示实际数字,用*代替
  720.        }
  721.        InputData[N]=N+4;
  722.        break;                //ABC是无定义按键
  723.                                                 case ('D'): ResetPassword();                break;      //重新设置密码
  724.                                                 case ('*'): Cancel();                                break;      //取消当前输入
  725.                                                 case ('#'): Ensure();                                 break;           //确认键,
  726.                                                 default:        //如果不是功能键按下时,就是数字键按下
  727.                                                 {
  728.                                                         //DisplayListChar(0,1,Input);
  729.                                                         if(N<6)                                                           //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
  730.                                                         {
  731.        write_1602com(er);
  732.        for(i=0;i<16;i++)
  733.        {
  734.        write_1602dat(Input[i]);                                //显示输入画面
  735.        }
  736.        OneAlam();        //按键提示音
  737.        for(j=0;j<=N;j++)
  738.        {
  739.        write_1602com(er+6+j);                                //显示位数随输入增加而增加
  740.        write_1602dat('*');                                        //但不显示实际数字,用*代替
  741.        }
  742.        InputData[N]=NUM;                                                //将数字键的码赋值给InputData[]数组暂存
  743.        N++;        //密码位数加
  744.                                                         }
  745.                                                         else        //输入数据位数大于6后,忽略输入
  746.                                                         {
  747.        N=6;        //密码输入大于6位时,不接受输入
  748.        break;
  749.                                                         }
  750.                                                 }
  751.                                         }
  752.                                 }
  753.                         }
  754.                  }
  755.         }
  756. }
  757. //*********************************中断服务函数**************************************
  758. void  time0_int(void) interrupt 1                    //定时器T0
  759. {
  760.          TL0=0xB0;
  761.          TH0=0x3C;                  //定时器重新赋初值
  762.          //TR0=1;
  763.          countt0++;                           //计时变量加,加1次时50ms
  764.           if(countt0==20)                   //加到20次就是1s
  765.            {
  766.                 countt0=0;                   //变量清零
  767.                 second++;                   //秒加
  768.                 if(pass==1)                   //开锁状态时
  769.                 {
  770.                         if(second==1)                        //秒加到1s时
  771.                         {
  772.                                 TR0=0;                                //关定时器
  773.                                 TL0=0xB0;
  774.                                  TH0=0x3C;                        //再次赋初值
  775.                                 second=0;                        //秒清零
  776.                         }
  777.                 }
  778.                 else                                                //不在开锁状态时
  779.                 {
  780.                         if(second==3)                        //秒加到3时
  781.                         {
  782.                                 TR0=0;                                //关闭定时器
  783.                                 second=0;                        //秒清零
  784.                                 key_disable=0;                //锁定键盘清零
  785.                                 s3_keydown=0;
  786.                                 TL0=0xB0;
  787.                                 TH0=0x3C;                        //重新赋初值
  788.                         }
  789.                         else
  790.                             TR0=1;                                //打开定时器
  791.                 }
  792.
  793.            }
  794. }
ID:1 发表于 2018-12-29 03:16 | 只看该作者
您这个问题给的信息不全,估计是没人能回答得了的,先转移到冷门区了,自行点击编辑按钮补充一下吧,审核员会帮你重新转到热门问答区的
ID:471066 发表于 2019-1-23 04:46 | 只看该作者
你这个情况是能开锁,但是不能修改密码,现在我将修正过的发给你
改好密码锁LCD1602.rar (93.53 KB, 下载次数: 58)
16位LCD12864密码锁.rar (33.34 KB, 下载次数: 15)
另外给你一个16位的仿真文档。
LCD1602那款同你的是一样的电路与源码
51黑论坛_改好密码锁LCD1602.rar
93.53 KB, 下载次数: 25
51黑论坛_16位LCD12864密码锁.rar
33.34 KB, 下载次数: 15
参与人数 2黑币 +30 收起 理由
Sawardeakar + 15 很给力!
shuisheng + 15 很给力!
