此次为 两个 595 芯片 串联 控制 8位数码管 , 仅用了3个 IO口。单片机为 5 1 芯片
仿真:
源码:(IO位定义及proteus在源文件中)
- #include<reg52.h>
- #include<intrins.h>
- typedef unsigned char uchar;
- typedef unsigned int uint;
- #define date P0
- #define count 50000
- #define TH_0 (65536-count)/256
- #define TL_0 (65536-count)%256
- uchar diss[8];
- uchar code distab[17] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
- 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40};
- uint sec=0,min=0,hour=0;
- void delay(uint iii)
- while(iii--);
- void hc595(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- sh_cp=0;
- _nop_();
- _nop_();
- ds=dat>>7;
- dat=dat<<1;
- sh_cp=1;
- _nop_();
- _nop_();
- void ds_dat_txd()//锁存发送
- st_cp=0;
- _nop_();
- _nop_();
- st_cp=1;
- _nop_();
- _nop_();
- void display()
- uchar i=0,dat=0;
- for(dat=0xfe;dat!=0xff;dat=dat<<1|0x01)
- hc595(dat);//先发送位码
- hc595(distab[diss[i++]]);//段码,
- ds_dat_txd(); //发送
- if(i==8)i=0;
- delay(100);
- hc595(0x00); //消隐
- ds_dat_txd();
- void disss()
- diss[0]=hour/10;
- diss[1]=hour%10;
- diss[2]=16;
- diss[3]=min/10;
- diss[4]=min%10;
- diss[5]=16;
- diss[6]=sec/10;
- diss[7]=sec%10;
- void timer0_init()
- TMOD=0x01;
- EA=1;ET0=1;TR0=1;
- TH0=TH_0;TL0=TL_0;
- void main()
- timer0_init();
- while(1)
- display();
- disss();
- void timer0() interrupt 1
- static uchar j;
- if(++j==20)
- j=0;
- sec++;
- if(sec==60)
- sec=0;
- min++;
- if(min==60)
- min=0;
- hour++;
- if(hour==24)
- hour=0;
复制代码 源文件 :
74HC595数码管.zip
(128.5 KB, 下载次数: 68)
