查看: 5440|回复: 4
关于51单片机存储FLASH的问题
ID:239793 发表于 2019-1-16 10:21 | 显示全部楼层 |阅读模式
50黑币
STC89C52 STC12 STC15 STC8系列等 串口接收到数据 如何存储在FLASH中 然后换串口或者 在此串口中换器件 并且发送存储的数据。求资料,求程序,或者指教下该去看哪方面的东西。
ID:469039 发表于 2019-1-16 11:39 | 显示全部楼层
直接看数据手册,中间Flash编程部分详细看。网上例程非常多。
ID:7485 发表于 2019-1-16 14:58 | 显示全部楼层
数据手册中有示范程序,可以直接套用。
ID:386762 发表于 2019-1-16 15:04 | 显示全部楼层
ID:281071 发表于 2019-1-16 15:26 | 显示全部楼层
给一个STC8的作为参考
u8 iap_byte_rd(u16 addr)
    u8  tmp;
    F0 = EA;
    EA = 0;
    IAP_CONTR = 0x80;
    IAP_CMD   = 1;
    IAP_ADDRH = (u8)(addr >> 8);
    IAP_ADDRL = addr;
    IAP_TRIG  = 0x5a;
    IAP_TRIG  = 0xa5;
    _nop_();
    tmp       = IAP_DATA;
    IAP_CONTR = 0;
    IAP_CMD   = 0;
    IAP_TRIG  = 0;
    IAP_ADDRH = 0xff;
    IAP_ADDRL = 0xff;
    EA = F0;
    return tmp;
void iap_byte_wr(u16 addr, u8 val)
    F0 = EA;
    EA = 0;
    IAP_CONTR = 0x80;
    IAP_CMD   = 2
    IAP_ADDRL = addr;
    IAP_DATA  = val;
    IAP_TRIG  = 0x5a;
    IAP_TRIG  = 0xa5;
    _nop_();
    IAP_CONTR = 0;
    IAP_CMD   = 0;
    IAP_TRIG  = 0;
    IAP_ADDRH = 0xff;
    IAP_ADDRL = 0xff;
    EA = F0;
void iap_sec_erase(u16 addr)
    F0 = EA;
    EA = 0;
    IAP_ADDRL = addr;
    IAP_CONTR = 0x80;
    IAP_CMD   = 3;
    IAP_TRIG  = 0x5a;
    IAP_TRIG  = 0xa5;
    _nop_();
    IAP_CONTR = 0;
    IAP_CMD   = 0;
    IAP_TRIG  = 0;
    IAP_ADDRH = 0xff;
    IAP_ADDRL = 0xff;
    EA = F0;
