- #include "main.h"
- #include "stm32f1xx_hal.h"
- #include "tim.h"
- #include "usart.h"
- #include "gpio.h"
- /* USER CODE BEGIN Includes */
- #include "oled.h"
- #include "delay.h"
- #include "bmp.h"
- /* USER CODE END Includes */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval None
- int main(void)
- /* USER CODE BEGIN 1 */
- u8 t;
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_TIM4_Init();
- MX_USART1_UART_Init();
- /* USER CODE BEGIN 2 */
- delay_init();
- OLED_Init(); //初始化OLED
- OLED_Clear() ;
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- t=' ';
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- OLED_Clear();
- // LED_ON;
- //显示汉字
- /*void OLED_ShowCHinese(u8 x,u8 y,u8 no)
- x,y分别代表要显示的汉字在屏上的坐标位置,最后一位是汉字在汉字数组的位数
- OLED_ShowCHinese(0,0,0);//中
- OLED_ShowCHinese(18,0,1);//景
- OLED_ShowCHinese(36,0,2);//园
- OLED_ShowCHinese(54,0,3);//电
- OLED_ShowCHinese(72,0,4);//子
- OLED_ShowCHinese(90,0,5);//科
- OLED_ShowCHinese(108,0,6);//技
- OLED_ShowString(0,3,"1.3' OLED TEST");
- //OLED_ShowString(8,2,"ZHONGJINGYUAN");
- // OLED_ShowString(20,4,"2014/05/01");
- OLED_ShowString(0,6,"ASCII:");
- OLED_ShowString(63,6,"CODE:");
- OLED_ShowChar(48,6,t);//显示ASCII字符
- t++;
- if(t>'~')t=' ';
- OLED_ShowNum(103,6,t,3,16);//显示ASCII字符的码值
- delay_ms(2000);
- OLED_Clear();
- delay_ms(2000);
- // LED_OFF;
- OLED_DrawBMP(0,0,128,8,BMP1); //图片显示(图片显示慎用,生成的字表较大,会占用较多空间,FLASH空间8K以下慎用)
- delay_ms(2000);
- OLED_DrawBMP(0,0,128,8,BMP2);
- delay_ms(2000);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- _Error_Handler(__FILE__, __LINE__);
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- /**Configure the Systick interrupt time
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @param file: The file name as string.
- * @param line: The line in file as a number.
- * @retval None
- void _Error_Handler(char *file, int line)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- while(1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
oled.7z
(3.01 MB, 下载次数: 302)
