题所述,想做个wifi校时时钟,前面AT返回的OK可以读取到,,后面GET返回的数据读取不到,求大神帮助,下面是部份程序(AT命令返回的OK可以读取到,让数码管显示1,但是GET后的数据就读不到了)- void main()
- delay5s();
- UsartInit();
- ESP8266_Set("+++"); //!!退出透传
- delay200ms();
- ESP8266_Set("\r\n"); //!!回车换行
- delay200ms();delay200ms();delay200ms();
- ESP8266_Set("AT+CWMODE_DEF=1\r\n"); //!!配置WiFi模组工作模式为单STA模式,并把配置保存在flash
- delay200ms(); delay200ms(); delay200ms(); delay200ms(); delay200ms();
- ESP8266_Set("AT+RST\r\n"); //!!重启模块
- delay5s();delay5s();
- ESP8266_Set("AT+CWJAP_DEF=\"111\",\"11111111\"\r\n"); // !!连接网络
- delay5s();delay5s();delay5s();
- ESP8266_Set("AT+CIPMUX=0\r\n"); //设置单链接模式
- ESP8266_Set("AT+CWAUTOCONN=1\r\n"); //!!使能上电自动连接AP
- delay200ms();delay200ms();delay200ms();delay200ms();delay200ms();
- ESP8266_Set("AT+CIPSTART=\"TCP\",\"time.beijing-time.org\",80\r\n");//!!连接服务器
- ESP8266_Set("AT+CIPMODE=1\r\n"); //!!设置透传
- ESP8266_Set("AT+CIPSEND\r\n"); //!!启动发送
- ESP8266_Set("GET http://time.beijing-time.org/time.asp"); //!!GET请求
- ES=1;
- //get返回{"success":"1","result":{"timestamp":"1548490735","datetime_1":"2019-01-26 16:18:55","datetime_2":"2019年01月26日 16时18分55秒","week_1":"6","week_2":"星期六","week_3":"周六","week_4":"Saturday"}}
- if(Recive_table[0]=='s')//如果为S则显示1否则0
- TM1650_Set_Time(0x48,0x11);
- TM1650_Set_Time(0x68,d_code[1]);
- else
- TM1650_Set_Time(0x68,d_code[0]);
- //---------------------------------------下面是中断
- void Uart_Interrupt() interrupt 4
- ES=0;
- if(RI)
- Receive=SBUF; //MCU接收wifi模块反馈回来的数据
- if(Receive=='s')
- RX_ok=0;//清除
- RX_flag=1;//开始接收
- if(RX_flag=1)
- Recive_table[ii++]=Receive;
- if(Receive=='\n')
- Recive_table[ii]=='\n';
- //ii=0;
- RX_flag=0;//清0表示这一次数据接收完成
- RX_ok=1;//接收完成
- RI=0;
- else TI=0;
- ES=1;
