前篇帖子写了基本的GPIO复用技术,现在补上按键矩阵技术,由于STM32的GPIO口不像传统51,准双向口,故而不能使用线反转法,我采用了行列扫描的技术,GPIO口用了A组,故而库函数没法直接调用赋值和读取同时16位的函数,只能调用一个个pin读取函数和赋值函数,显得有点臃肿。但是STM32性能牛逼,这么多if的语句还跑的这么流畅,如果是C51早gg了,在STC12勉强可以看看。仅供参考。STM32学起来比51更费劲,英语不好的话,库函数弄死人。
此工程,主要用于编程4X4按键矩阵的识别和编码的功能
- #include <STM32F10X.H>
- #include <misc.h>
- #define PA0_Low GPIO_ResetBits(GPIOA,GPIO_Pin_0)
- #define PA0_High GPIO_SetBits(GPIOA,GPIO_Pin_0)
- #define PA1_Low GPIO_ResetBits(GPIOA,GPIO_Pin_1)
- #define PA1_High GPIO_SetBits(GPIOA,GPIO_Pin_1)
- #define PA2_Low GPIO_ResetBits(GPIOA,GPIO_Pin_2)
- #define PA2_High GPIO_SetBits(GPIOA,GPIO_Pin_2)
- #define PA3_Low GPIO_ResetBits(GPIOA,GPIO_Pin_3)
- #define PA3_High GPIO_SetBits(GPIOA,GPIO_Pin_3)
- #define PA4 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_4)
- #define PA5 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_5)
- #define PA6 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_6)
- #define PA7 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_7)
- #define PC15_Low GPIO_WriteBit(GPIOC,GPIO_Pin_15,Bit_RESET)
- #define PC15_High GPIO_WriteBit(GPIOC,GPIO_Pin_15,Bit_SET)
- void RCC_Configuration(void); //时钟与复位寄存器
- void GPIO_Configuration(void); //GPIO口初始化函数
- void Delay_ms(u16 n); //ms级别延时函数
- u16 Array_Key(void); //4X4按键矩阵检测函数
- void Led_Show(u16 keystatus); //按键检测后的状态显示函数
- u16 ledcount=0;
- u16 status=0;
- int main(void)
- RCC_Configuration();
- GPIO_Configuration();
- while(1)
- Led_Show(Array_Key());
- SystemInit();
- GPIO_InitTypeDef GPIO_Struct; //定义一个GPIO初始化的结构体变量
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_Struct.GPIO_Mode=GPIO_Mode_Out_PP;
- GPIO_Struct.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_Struct.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
- GPIO_Init(GPIOA,&GPIO_Struct);
- GPIO_Struct.GPIO_Mode=GPIO_Mode_IPU;
- GPIO_Struct.GPIO_Pin=GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_Struct.GPIO_Pin=GPIO_Pin_15;
- GPIO_Init(GPIOC,&GPIO_Struct);
- PA0_High;PA1_High;PA2_High;PA3_High;
- PC15_Low;
- PA0_Low;PA1_High;PA2_High;PA3_High;
- if(PA4 == 0)
- Delay_ms(10);
- if(PA4 == 0)
- while(!PA4);
- status = 1;
- if(PA5 == 0)
- Delay_ms(10);
- if(PA5 == 0)
- while(!PA5);
- status = 2;
- if(PA6 == 0)
- Delay_ms(10);
- if(PA6 == 0)
- while(!PA6);
- status = 3;
- if(PA7 == 0)
- Delay_ms(10);
- if(PA7 == 0)
- while(!PA7);
- status = 4;
- PA0_High;PA1_Low;PA2_High;PA3_High;
- if(PA4 == 0)
- Delay_ms(10);
- if(PA4 == 0)
- while(!PA4);
- status = 5;
- if(PA5 == 0)
- Delay_ms(10);
- if(PA5 == 0)
- while(!PA5);
- status = 6;
- if(PA6 == 0)
- Delay_ms(10);
- if(PA6 == 0)
- while(!PA6);
- status = 7;
- if(PA7 == 0)
- Delay_ms(10);
- if(PA7 == 0)
- while(!PA7);
- status = 8;
- PA0_High;PA1_High;PA2_Low;PA3_High;
- if(PA4 == 0)
- Delay_ms(10);
- if(PA4 == 0)
- while(!PA4);
- status = 9;
- if(PA5 == 0)
- Delay_ms(10);
- if(PA5 == 0)
- while(!PA5);
- status = 10;
- if(PA6 == 0)
- Delay_ms(10);
- if(PA6 == 0)
- while(!PA6);
- status = 11;
- if(PA7 == 0)
- Delay_ms(10);
- if(PA7 == 0)
- while(!PA7);
- status = 12;
- PA0_High;PA1_High;PA2_High;PA3_Low;
- if(PA4 == 0)
- Delay_ms(10);
- if(PA4 == 0)
- while(!PA4);
- status = 13;
- if(PA5 == 0)
- Delay_ms(10);
- if(PA5 == 0)
- while(!PA5);
- status = 14;
- if(PA6 == 0)
- Delay_ms(10);
- if(PA6 == 0)
- while(!PA6);
- status = 15;
- if(PA7 == 0)
- Delay_ms(10);
- if(PA7 == 0)
- while(!PA7);
- status = 16;
- return status;
- u16 i;
- while(n--)
- i=12000;
- while(i--);
- if(keystatus != 0)
- {ledcount++;status=0;}
- if(ledcount % 2 == 0)
- PC15_Low;
- else
- PC15_High;
Key_Array.7z
(192.09 KB, 下载次数: 49)
