STC15F104W虚拟串口 字符串比较
- //本示例在Keil开发环境下请选择Intel的8058芯片型号进行编译
- //若无特别说明,工作频率一般为11.0592MHz
- #include "reg51.h"
- #include<string.h>
- #define d 5 //数组位定义
- //define baudrate const
- //BAUD = 65536 - FOSC/3/BAUDRATE/M (1T:M=1; 12T:M=12)
- //NOTE: (FOSC/3/BAUDRATE) must be greater then 98, (RECOMMEND GREATER THEN 110)
- //#define BAUD 0xF400 // 1200bps @ 11.0592MHz
- //#define BAUD 0xFA00 // 2400bps @ 11.0592MHz
- //#define BAUD 0xFD00 // 4800bps @ 11.0592MHz
- #define BAUD 0xFE80 // 9600bps @ 11.0592MHz
- //#define BAUD 0xFF40 //19200bps @ 11.0592MHz
- //#define BAUD 0xFFA0 //38400bps @ 11.0592MHz
- //#define BAUD 0xEC00 // 1200bps @ 18.432MHz
- //#define BAUD 0xF600 // 2400bps @ 18.432MHz
- //#define BAUD 0xFB00 // 4800bps @ 18.432MHz
- //#define BAUD 0xFD80 // 9600bps @ 18.432MHz
- //#define BAUD 0xFEC0 //19200bps @ 18.432MHz
- //#define BAUD 0xFF60 //38400bps @ 18.432MHz
- //#define BAUD 0xE800 // 1200bps @ 22.1184MHz
- //#define BAUD 0xF400 // 2400bps @ 22.1184MHz
- //#define BAUD 0xFA00 // 4800bps @ 22.1184MHz
- //#define BAUD 0xFD00 // 9600bps @ 22.1184MHz
- //#define BAUD 0xFE80 //19200bps @ 22.1184MHz
- //#define BAUD 0xFF40 //38400bps @ 22.1184MHz
- //#define BAUD 0xFF80 //57600bps @ 22.1184MHz
- sfr AUXR = 0x8E;
- sbit RXB = P3^0; //define UART TX/RX port
- sbit TXB = P3^1;
- typedef bit BOOL;
- typedef unsigned char BYTE;
- typedef unsigned int WORD;
- BYTE TBUF,RBUF;
- BYTE TDAT,RDAT;
- BYTE TCNT,RCNT;
- BYTE TBIT,RBIT;
- BOOL TING,RING;
- BOOL TEND,REND;
- void UART_INIT();
- unsigned char r;
- bit b;
- BYTE t, r;
- BYTE buf[16];
- void RUSRT();
- void TUSRT(unsigned char dat,f);
- sbit R1=P3^3; //输出1
- sbit R2=P3^4;//输出2
- bit cmd; //接收完成标志
- bit Tcmd;
- static unsigned char rc; //接收计数
- static unsigned char tc; //发送计数
- static unsigned char a1[d]={0x61,0x62,0x63,0x64,0x65} ; //5位 比数组多1位 结束位
- static unsigned char q;
- unsigned char c; //数据位计数
- unsigned char *p; //数据指针
- unsigned int n;
- void main()
- unsigned char fc; //发送延时
- TMOD = 0x00; //timer0 in 16-bit auto reload mode
- AUXR = 0x80; //timer0 working at 1T mode
- TL0 = BAUD;
- TH0 = BAUD>>8; //initial timer0 and set reload value
- TR0 = 1; //tiemr0 start running
- ET0 = 1; //enable timer0 interrupt
- PT0 = 1;
- //improve timer0 interrupt priority
- EA = 1; //open global interrupt switch
- UART_INIT();
- while (1)
- { //user's function
- RUSRT(); //调用接收函数
- if(cmd==1) //接收完成
- if(c!=4) //数据位错误
- //发送错误指示
- c=0;
- cmd=0;
- else if(c==4) //数据位正确
- if( 0== strcmp (a1,"R1ONen" )) //字符比较
- R1=0;
- fc = sizeof(a1); //计算数组位数
- for (n=0;n<20000;n++);
- TING =1;
- TEND=1;
- TUSRT(a1,fc); //调用发送函数
- if( 0== strcmp (a1,"R1OFen" )) //字符比较
- R1=1;
- TING =1;
- TEND=1;
- if( 0== strcmp (a1,"R2ONen" )) //字符比较
- R2=0;
- TING =1;
- TEND=1;
- if( 0== strcmp (a1,"R2OFen" )) //字符比较
- R2=1;
- TING =1;
- TEND=1;
- void RUSRT() //接收函数
- if (REND)
- REND = 0;
- if (RBUF!='n') //判断不是结束符
- a1[rc]=RBUF; //接收传送数组位
- rc++;
- c++;
- else if(RBUF=='n') //判断是结束符
- {REND=0;
- rc=0;
- cmd=1;
- void TUSRT(unsigned char dat,f) //发送函数
- if (TEND)
- TEND=0;
- if(tc<=f) //发送数据位比较
- TBUF =a1[tc]; //数组位数据发送到发送寄存器
- tc++;
- p++;
- else if (tc>=f) //发送数据比较
- cmd =0; //发送复位
- c=0;
- tc=0;
- TEND=0; //复位
- TING=0;
- //Timer interrupt routine for UART
- void tm0() interrupt 1 using 1
- if (RING)
- if (--RCNT == 0)
- RCNT = 3; //reset send baudrate counter
- if (--RBIT == 0)
- RBUF = RDAT; //save the data to RBUF
- RING = 0; //stop receive
- REND = 1; //set receive completed flag
- else
- RDAT >>= 1;
- if (RXB) RDAT |= 0x80; //shift RX data to RX buffer
- else if (!RXB)
- RING = 1; //set start receive flag
- RCNT = 4; //initial receive baudrate counter
- RBIT = 9; //initial receive bit number (8 data bits + 1 stop bit)
- if (--TCNT == 0)
- TCNT = 3; //reset send baudrate counter
- if (TING) //judge whether sending
- if (TBIT == 0)
- TXB = 0; //send start bit
- TDAT = TBUF; //load data from TBUF to TDAT
- TBIT = 9; //initial send bit number (8 data bits + 1 stop bit)
- else
- TDAT >>= 1; //shift data to CY
- if (--TBIT == 0)
- TXB = 1;
- TING = 0; //stop send
- TEND = 1; //set send completed flag
- else
- TXB = CY; //write CY to TX port
- //initial UART module variable
- void UART_INIT()
- TING = 0;
- RING = 0;
- TEND = 0;
- REND = 0;
- TCNT = 0;
- RCNT = 0;
15模拟串口.rar
(28.69 KB, 下载次数: 48)
