查看: 1605|回复: 1
利用oled显示的51单片机六人抢答器源代码
ID:328720 发表于 2019-3-31 21:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个是利用iic驱动的oled屏幕显示,与数码管显示会有不同,但主要的程序还是一样的,希望可以给大家提供一些资料
  1. #include "reg52.h"
  2. #include "intrins.h"
  3. #include "codetab.h"
  4. #include "LQ12864.h"
  5. #include<stdio.h>
  6. #define uchar unsigned char
  7. sbit dula=P2^6;
  8. sbit wela=P2^7;
  9. sbit beep=P2^3;
  10. uchar key,j,k,temp,wei;
  11. daojishi=5;
  12. bit begin,end,clear;
  13. int a0,b0;c0;d0;e0;f0=5;
  14. unsigned int pp;
  15. uchar diss[20]={0};
  16. void delay1(int i)                  //延时函数
  17. {
  18.   for(j=i;j>0;j--)
  19.     for(k=125;k>0;k--);
  20. }
  21. void keyscan()             //按键扫描
  22. {
  23.         P3=0xfe;
  24.     temp=P3;
  25.     temp=temp&0xf0;
  26.     if(temp!=0xf0)
  27.     {
  28.       delay1(10);
  29.       if(temp!=0xf0)
  30.       {
  31.         temp=P3;
  32.         switch(temp)
  33.         {
  34.           case 0xee:
  35.                key=1;
  36.                            wei++;
  37.                break;
  38.           case 0xde:
  39.                key=2;
  40.                            wei++;
  41.                break;
  42.           case 0xbe:
  43.                key=3;
  44.                            wei++;
  45.                break;
  46.           case 0x7e:
  47.                key=4;
  48.                            wei++;
  49.                break;
  50.          }
  51.          while(temp!=0xf0)
  52.          {
  53.            temp=P3;
  54.            temp=temp&0xf0;
  55.            beep=0;
  56.          }
  57.          beep=1;
  58.       }
  59.     }
  60.     P3=0xfd;
  61.     temp=P3;
  62.     temp=temp&0xf0;
  63.     if(temp!=0xf0)
  64.     {
  65.       delay(10);
  66.       if(temp!=0xf0)
  67.       {
  68.         temp=P3;
  69.         switch(temp)
  70.         {
  71.           case 0xed:
  72.                key=5;
  73.                            wei++;
  74.                break;
  75.           case 0xdd:
  76.                key=6;
  77.                            wei++;
  78.                break;
  79.           case 0xbd:
  80.                clear=1;
  81.                break;
  82.           case 0x7d:
  83.                              begin=1;
  84.                break;
  85.          }
  86.          while(temp!=0xf0)
  87.          {
  88.            temp=P3;
  89.            temp=temp&0xf0;
  90.            beep=0;
  91.          }
  92.          beep=1;
  93.       }
  94.       }
  95. }
  96. void kaiji(void)
  97. {
  98.         OLED_Init(); //OLED初始化
  99.         OLED_P16x16Ch(0,0,1);                        //初始显示的字符
  100.         OLED_P16x16Ch(16,0,2);
  101.     OLED_P16x16Ch(33,0,3);
  102.         OLED_P16x16Ch(0,3,4);
  103.         OLED_P16x16Ch(16,3,5);
  104.     OLED_P16x16Ch(32,3,6);
  105.         OLED_P16x16Ch(0,6,7);
  106.         OLED_P16x16Ch(16,6,8);
  107.     OLED_P16x16Ch(32,6,9);
  108. }
  109. void fangui()
  110. {
  111.         if(key!=0)
  112.          {
  113.                 switch(wei)                                         //传递字符,显示
  114.                 {
  115.                         case 1: a0=key;
  116.                                         sprintf((int*)diss,"%d",a0);
  117.                         OLED_P6x8Str(40,0,diss);
  118.                                         beep=0;
  119.                                         break;
  120.                         case 2: b0=key;
  121.                                         sprintf((int*)diss,"%d",b0);
  122.                             OLED_P6x8Str(40,0,diss);
  123.                                         beep=0;
  124.                                         break;
  125.                         case 3: c0=key;
  126.                                         sprintf((int*)diss,"%d",c0);
  127.                             OLED_P6x8Str(40,0,diss);
  128.                                         beep=0;
  129.                                         break;
  130.                         case 4: d0=key;
  131.                                         sprintf((int*)diss,"%d",d0);
  132.                             OLED_P6x8Str(40,0,diss);
  133.                                         beep=0;
  134.                                         break;
  135.                         case 5: e0=key;
  136.                                         sprintf((int*)diss,"%d",e0);
  137.                             OLED_P6x8Str(40,0,diss);
  138.                                         beep=0;
  139.                                         break;
  140.                     case 6: f0=key;
  141.                                         sprintf((int*)diss,"%d",f0);
  142.                             OLED_P6x8Str(40,0,diss);
  143.                                         beep=0;
  144.                                         break;
  145.                 }
  146.          }
  147. }
  148. void main(void)
  149. {
  150.          kaiji();
  151.          TMOD=0x01;
  152.          TH0=(65536-46080)/256;
  153.          TL0=(65536-46080)%256;//46080的来历,为50000*11.0592/12
  154.          ET0=1;
  155.          EA=1;
  156.         while(1)
  157.         {
  158.                   keyscan();
  159.                 if(begin)                           //开始计时并抢答
  160.                 {
  161.                          if(!end)
  162.                                 {
  163.                                   TR0=1;                   //中断开始
  164.                                         if(pp==20)           //中断次数
  165.                                           {
  166.                                                   pp=0;
  167.                                                   daojishi--;
  168.                                           }
  169.                                           sprintf((int*)diss,"%d",daojishi);
  170.                                  OLED_P6x8Str(40,6,diss);
  171.                                          if(key!=0)
  172.                                           {
  173.                                                    a0=key;                                 //倒计时结束
  174.                                                    sprintf((int*)diss,"%d",a0);
  175.                                            OLED_P6x8Str(40,3,diss);
  176.                                            }
  177.                                           if(!daojishi|a0)
  178.                                            {
  179.                                                         end=1;
  180.                                                         TR0=0;                           //中断暂停
  181.                                                         pp=0;
  182.                                            }
  183.                                 }
  184.                 }
  185.                 else
  186.                 {
  187.                   fangui();
  188.                 }
  189.                 if(clear)
  190.                 {
  191.                         a0=0;key=0;begin=0;end=0;beep=1;daojishi=5;f0=5;clear=0;          //数据清除
  192.                         OLED_CLS();//清屏
  193.                         kaiji();
  194.                 }
  195.    }
  196. }
  197. void time0() interrupt 1            //中断函数
  198. {        TH0=(65536-46080)/256;
  199.         TL0=(65536-46080)%256;
  200.         pp++;
  201. }
单片机课设.zip (43.62 KB, 下载次数: 7)
ID:1 发表于 2019-4-1 05:12 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
