基于C8051F340(C51)单片机,含发送介绍程序
#include "C8051F340.H"
#include "nRF24L01.h"
Function name : Clock_Init( )
Description : Initialize the system and USB clock
Input : None
Output : None
void Clock_Init( void )
INT16U iTmp;
//Enable internal high speed oscillator
OSCICN |= 0x83;
//Enable internal 4X MULL
if( !( CLKMUL & ( 1<<5 ) ) )
CLKMUL = 0;
CLKMUL = 0x00;
CLKMUL |= ( 1<<7 );
for( iTmp = 0; iTmp < 200; iTmp ++ );
CLKMUL |= ( 1<<6 ) | ( 1<<7 );
for( iTmp = 0; iTmp < 2000; iTmp ++ );
while( !( CLKMUL & ( 1<<5 ) ) );
//USB clock: 48MHz, system clock : 48MHz
CLKSEL = 0x03;
Function name : SPI_Init( )
Description : Initialize the SPI bus
Input : None
Output : None
void SPI_Init( void )
SPI0CN = 0x00;
SPI0CFG |= ( 1<<6 );
SPI0CKR = 10;
SPI0CN = 0x01; //Enable SPI
XBR0 |= ( 1<<1 );
//strong output
P0MDOUT |= ( 1<<0 ) | ( 1<<1 ) | ( 1<<2 ) | ( 1<<3 );
P0 |= ( 1<<0 ) | ( 1<<1 ) | ( 1<<2 ) | ( 1<<3 );
P0SKIP |= ( 1<<0 );
Function name : SPI_ExchangeByte( )
Description : Exchange a byte via the SPI bus
Input : -Byte, The byte sent
Output : The byte returned
INT8U SPI_ExchangeByte( INT8U Byte )
SPI0CN &= ~( 1<<7 );
while( !( SPI0CN & ( 1<<1 ) ) );
SPI0DAT = Byte;
while( !( SPI0CN & ( 1<<7 ) ) );
return SPI0DAT;
/*INT8U RetValue = 0;
INT8S btmp;
for( btmp = 7; btmp >= 0; btmp -- )
SCK_LOW( );
MISO_HIGH( );
if( Byte & ( 1<<btmp ) )
MOSI_HIGH( );
MOSI_LOW( );
SCK_HIGH( );
if( GET_MISO( ) ) RetValue |= ( 1<<btmp );
SCK_LOW( );
return RetValue;*/
* Name : Timer1_Init( )
* Description : Initialize the timer1 for baudrate
* Input : None
* Output : None
* Note : None
*///9600
void Timer1_Init( void )
TH1 = 0x30;
TL1 = 0x30;
TCON &= 0x3f;
TMOD &= 0x0F;
TMOD |= ( 2<<4 );
CKCON |= 0x00 | ( 0<<3 );
TCON |= ( 1<<6 );
* Name : UART0_Init( )
* Description : Initialize the UART0, baudrate
* Input : None
* Output : None
* Note : None
static void UART0_Init( void )
SCON0 = ( 1<<4 );
IE |= ( 1<<4 );
P0MDOUT |= ( 1<<4 );
Timer1_Init( );
volatile unsigned char *Ptr_Send = 0;
volatile unsigned int SendCount = 0;
volatile unsigned char SendBusy = 0;
static UART0_ISR( void ) interrupt 4
if( SCON0 & ( 1<<1 ) )
//TX ok
SCON0 &= ~( 1<<1 );
if( SendCount != 0 && Ptr_Send != 0 )
SendBusy = 1;
SBUF0 = *Ptr_Send;
SendCount--;
Ptr_Send ++;
SendBusy = 0;
else if( SCON0 & ( 1<<0 ) )
//RX ok
SCON0 &= ~( 1<<0 );
void _delay_ms( INT16U x )
INT16U m;
while( x -- )
for( m = 0; m < 5000; m ++ );
void UART0_Send( unsigned char *buf, unsigned int size )
while( SendBusy );
Ptr_Send = buf;
SendCount = size;
SCON0 |= ( 1<<1 );
void UART0_SendStr( char *str )
UART0_Send( (INT8U*)str, strlen( str ) );
int main( void )
INT8U tmp, x;
char *AskData = "How are you?\r\n";
INT8U testbuffer[32];
XBR1 |= ( 1<<6 );
XBR0 |= ( 1<<0 );
Clock_Init( );
SPI_Init( );
UART0_Init( );
EA = 1;
L01_Init( );
L01_SetTXMode( );
L01_WriteHoppingPoint( 0 );
UART0_SendStr( "nRF24L01P Send Start!\r\n" );
while( 1 )
for( tmp = 0; tmp < 200; tmp ++ )
_delay_ms( 10 );
L01_FlushRX( );
L01_FlushTX( );
UART0_SendStr( "Send:" );
UART0_SendStr( AskData );
L01_WriteTXPayload_Ack( AskData, strlen( AskData ) );
while( 1 )
tmp = L01_ReadStatusReg( );
//USART_SendChar(tmp); //for test
tmp &= ( 1<<TX_DS ) | ( 1<<MAX_RT ) | ( 1<<RX_DR );
_delay_ms( 1 );
if( tmp != 0 )
break;
if( tmp & ( 1<<TX_DS ) )
UART0_SendStr( "Send OK!\r\n" );
for( tmp = 0; tmp < 32; tmp ++ )
testbuffer[tmp] = 0;
x = L01_ReadRXPayload( testbuffer );
UART0_SendStr( "Received reply:" );
UART0_SendStr( testbuffer );
if( tmp & ( 1<<MAX_RT ) )
UART0_SendStr( "Send Fail!\r\n" );
if( tmp & ( 1<<RX_DR ) )
L01_ClearIRQ( IRQ_ALL );
return 0;
