查看: 2389|回复: 0
数模转换,可预设电源电压输出(单片机程序+Proteus仿真例程)
ID:508281 发表于 2019-4-9 21:36 | 显示全部楼层 |阅读模式
/* 主程序 */
        uchar j,key;
    uint temp;
        P20 = 1;
        P21 = 1;                                                        // 关闭数码管显示
        TMOD = 0x11;                                                // T0,T1工作方式1
        /* 2ms 定时设置 */
        TH0 = -2000/256;
        TL0 = 2000%256;
        /* 启动计数器0,关闭计数器1 */
        TR0 = 1;
        ET0 = 1;
        TR1 = 0;
        ET1 = 1;
        EA = 1;
        count = 0;                                                // 初始计数器设为0
        enterflag = 0;                                        // 没有按下确认键
        lh = 0;
        pwflag = 0;                                                // 标志先置为0
        digbit = 0x01;                                        // 从第一位数码管开始动态扫描
        /* 刚加电时,bu显示*/
        for (j=0;j<2;j++)
                wordbuf[j] = 17;
        showflag = 1;                                        // 打开数码管显
                key = keyscan();                                        // 调用键盘扫描函数
        switch(key)
                      case 0x11:                                                // 1行1列,数字1
                                if (count<2)
                                        wordbuf[count] = 1;        // 对应位上显示“1”
                                        pwbuf[count] = 1;
                                        if(count==0)
                    {a=1;
                                        if(count==1)
                    {b=1;
                                        count++;
                                break;
                        case 0x21:                                                // 1行2列,数字3
                                if (count<2)
                                        wordbuf[count] = 2;        // 对应位上显示“2"
                                        pwbuf[count] = 2;
                                        if(count==0)
                    {a=2;
                                        if(count==1)
                    {b=2;
                                        count++;
                                break;
                        case 0x41:                                                // 1行3列,数字3
                                if (count<2)
                                        wordbuf[count] = 3;        // 对应位上显示“3"
                                        pwbuf[count] = 3;
                                        if(count==0)
                    {a=3;
                                        if(count==1)
                    {b=3;
                                        count++;
                                break;
                        case 0x12:                                                // 2行1列,数字4
                                if (count<2)
                                        wordbuf[count] = 4;        // 对应位上显示“4"
                                        pwbuf[count] = 4;
                                        if(count==0)
                    {a=4;
                                        if(count==1)
                    {b=4;
                                        count++;
                                break;
                        case 0x22:                                                // 2行2列,数字5
                                if (count<2)
                                        wordbuf[count] = 5;        // 对应位上显示“5"
                                        pwbuf[count] = 5;
                                        if(count==0)
                    {a=5;
                                        if(count==1)
                    {b=5;
                                        count++;
                                break;
                        case 0x42:                                                // 2行3列,数字6
                                if (count<2)
                                        wordbuf[count] = 6;        // 对应位上显示“6"
                                        pwbuf[count] = 6;
                                    if(count==0)
                    {a=6;
                                        if(count==1)
                    {b=6;
                                        count++;
                                break;
                        case 0x14:                                                // 3行1列,数字7
                                if (count<2)
                                        wordbuf[count] = 7;        // 对应位上显示“7"
                                        pwbuf[count] = 7;
                                        if(count==0)
                    {a=7;
                                        if(count==1)
                    {b=7;
                                        count++;
                                break;
                        case 0x24:                                                // 3行2列,数字8
                                if (count<2)
                                        wordbuf[count] = 8;        // 对应位上显示“8"
                                        pwbuf[count] = 8;
                                        if(count==0)
                    {a=8;
                                        if(count==1)
                    {b=8;
                                        count++;
                                break;
                        case 0x44:                                                // 3行3列,数字9
                                if (count<2)
                                        wordbuf[count] = 9;        // 对应位上显示“9"
                                        pwbuf[count] = 9;
                                        if(count==0)
                    {a=9;
                                        if(count==1)
                    {b=9;
                                        count++;
                                break;
                         case 0x18:                                                // 4行1列,数字*
                                count = 0;
                                P3=0;
                                px=0;                                        // 显示清零
                                for (j=0;j<2;j++)
                                        wordbuf[j] = 17;                        // 数码管不显示
                                        pwbuf[j] = 0;                // 用FFFFFF清除已经输入的密码
                                break;
                        case 0x28:                      // 4行2列,数字0
                                if (count<2)
                                        wordbuf[count] = 0;        // 对应位上显示“0"
                                        pwbuf[count] = 0;
                                        if(count==0)
                    {a=0;
                                        if(count==1)
                    {b=0;
                                        count++;
                                break;
                        case 0x48:                                                // 4行3列,数字#
                                 enterflag = 1;                                // 确认键按下
                                 if (count==2)                                 // 只有输入2个数后按确认键才有效输出
                                    pwflag = 1;
                                break;
                        default:break;
                if (enterflag==1)                                        // 如果按下确认键
                        enterflag = 0;                                         // 标志位置回0
                        count = 0;                      // 计数器清零
                        c=0xff/6;
                        if (pwflag==1)
             P3=a*c+b*c/10+12*c/100;
             temp=a*c+b*c/10+12*c/100;
               if(temp>=0xff)
                  P3=0xff;
全部资料51hei下载地址:
可预设电压源.zip (87.87 KB, 下载次数: 37)
