查看: 770|回复: 1
求教,我这个倒计时的代码为什么烧录后无效
ID:507339 发表于 2019-4-10 20:23 | 显示全部楼层 |阅读模式
#include <STC89C5xRC.H>
#include "F:\keil4\STC\STC89C5xRC.H"
#include <intrins.h>
#define SMG P0
sbit K1=P3^4;
sbit K2=P3^5;
sbit K3=P3^6;
sbit K4=P3^7;
sbit DUAN=P2^6;
sbit WEI=P2^7;
sbit FMQ=P2^3;
unsigned char ZF[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,
                                        0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
unsigned char Wei[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char PLAY[8]={0,0,0,0,0,0,0,0};
unsigned char n=0,TT=0;
void Delay1ms()                //@11.0592MHz
        unsigned char i, j;
        _nop_();
        i = 2;
        j = 199;
        do
                while (--j);
        } while (--i);
void Delay10ms()                //@11.0592MHz
        unsigned char i, j;
        i = 18;
        j = 235;
        do
                while (--j);
        } while (--i);
void Delay100ms()                //@11.0592MHz
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 5;
        j = 52;
        k = 195;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void Timer0Init(void)                //50毫秒
        AUXR &= 0x7F;
        TMOD &= 0xF0;
        TMOD |= 0x01;
        TL0 = 0x00;
        TH0 = 0x4C;
    EA = 1;
    ET0 = 1;
        TF0 = 0;
        TR0 = 0;
void XS(void)
        unsigned char i;
        for (i=0;i<8;i++)
                SMG=Wei[i];
                WEI=1;
                WEI=0;
                SMG=PLAY[i];
                DUAN=1;
                DUAN=0;
                Delay1ms();
                SMG=0x00;
                DUAN=1;
                DUAN=0;
void DISPLAY(void)
        PLAY[5]=ZF[n/100];
        PLAY[6]=ZF[(n%100)/10];
        PLAY[7]=ZF[(n%10)/1];
void main(void)
        unsigned char m;
        bit KS=0;
        Timer0Init();
                if (K1==0)
                        Delay10ms();
                        if (K1==0)
                                n=n+1;
                        for(m=0;((m<50)&&(K1==0));m++)
                                Delay10ms();
                if (K2==0)
                        Delay10ms();
                        if (K2==0)
                                n=n-1;
                        for(m=0;((m<50)&&(K2==0));m++)
                                Delay10ms();
                if (K3==0)
                        Delay10ms();
                        if (K3==0)
                                n=0;
                        for(m=0;((m<50)&&(K3==0));m++)
                                Delay10ms();
                if (K4==0)
                        Delay10ms();
                        if (K4==0)
                                if (n!=0)
                                        TR0=1;
                        for(m=0;((m<50)&&(K4==0));m++)
                                Delay10ms();
                DISPLAY();
                XS();
void Time0 (void) interrupt 1
        unsigned char m;
        TL0 = 0x00;
        TH0 = 0x4C;
        TT++;
        if (TT==20)
                n--;
                if (n==0)
                        for (m=0;m<100;m++)
                                DISPLAY();
                                XS();
                        TR0=0;
                        FMQ=0;
                        Delay100ms();
                        FMQ=1;
                TT=0;
ID:424598 发表于 2019-4-10 21:45 来自手机 | 显示全部楼层
因为TR0=0     定时器停了
