查看: 1503|回复: 1
基于五一单片机的AM2301温湿度传感器源程序
ID:515826 发表于 2019-4-18 20:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include <intrins.h>
#include <stdio.h>
#include "lcd1602.h"
typedef unsigned char  U8;
typedef signed   char  S8;
typedef unsigned int   U16;
typedef signed   int   S16;
typedef unsigned long  U32;
typedef signed   long  S32;
typedef float          F32;
typedef double         F64;
sbit  DHT  = P2^0 ;
bit  flagtemp;//  U8count ,k;
bit flagsendtemp;
U8 U8FLAG;
U8  U8temp;
U8  U8T_data_H  ,U8T_data_L  ,U8RH_data_H  ,U8RH_data_L  ,U8checkdata;
U8  U8T_data_H_temp  ,U8T_data_L_temp  ,U8RH_data_H_temp  ,U8RH_data_L_temp
,U8checkdata_temp;
U8  U8comdata;
U8  outdata[5];
U8  indata[5];
U8  count, count_r=0;
U8 str[5];
U16 DHTData1  ,DHTData2;
U8 data tab[6]={0x00,0x00,0x00,0x00,0x00,oxoo};
U8 code dis1[]={"Humdity:    %"};
U8 code dis2[]={"Temper:    c"};
void Delay(U16 j)
{      U8 i;
    for(;j>0;j--)
for(i=0;i<27;i++);
void  Delay_10us(void)
    U8 i;
    i--;
    i--;
    i--;
    i--;
    i--;
    i--;
void  COM(void)
        U8 i;
   for(i=0;i<8;i++)
        U8FLAG=2;
    while((!DHT)&&U8FLAG++);
  Delay_10us();
        Delay_10us();
        Delay_10us();
    U8temp=0;
     if(DHT)U8temp=1;
     U8FLAG=2;
  while((DHT)&&U8FLAG++);
     if(U8FLAG==1)break;
    U8comdata<<=1;
       U8comdata|=U8temp;        //0
     }//end i
//----????8λ== U8T_data_H------
//----????8λ== U8T_data_L------
//----????8λ== U8RH_data_H-----
//----????8λ== U8RH_data_L-----
//----У?? 8λ == U8checkdata-----
//---- Delay();, Delay_10us();,COM();
void RH(void)
   //????????18ms
       DHT=0;
    Delay(5);
    DHT=1;
  //?????????????????? ???????40us
    Delay_10us();
    Delay_10us();
       Delay_10us();
    Delay_10us();
  //??????????? ?ж?????????
    DHT=1;
  //?ж???????е????????? ?粻????????????????????????
    if(!DHT)   //T !
    U8FLAG=2;
  //?ж???????? 80us ?????????????????
    U8FLAG=2;
  //?ж???????? 80us ????????緢????????????????
    COM();
    U8RH_data_H_temp=U8comdata;
    COM();
    U8RH_data_L_temp=U8comdata;
    COM();
    U8T_data_H_temp=U8comdata;
    COM();
    U8T_data_L_temp=U8comdata;
    COM();
    U8checkdata_temp=U8comdata;
    DHT=1;
  //????У??
    U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
    if(1)
       U8RH_data_H=U8RH_data_H_temp;
       U8RH_data_L=U8RH_data_L_temp;
    DHTData1=U8RH_data_H;
    DHTData1<<=8;
    DHTData1|=U8RH_data_L;
    tab[0]=DHTData1/100+0x30;
    tab[1]=DHTData1%100/10+0x30;
    tab[2]=DHTData1%10+0x30;
    U8T_data_H=U8T_data_H_temp;
       U8T_data_L=U8T_data_L_temp;
    DHTData2=U8T_data_H;
    DHTData2<<=8;
    DHTData2|=U8T_data_L;
    if(DHTData2&0x8000)
     flagtemp=1;
   DHTData2&=0x7FFF;
    tab[3]=DHTData2/100+0x30;
    tab[4]=DHTData2%100/10+0x30;
    tab[5]=DHTData2%10+0x30;
    }//fi
    }//fi
void display()
U8 m;
m=0;
writecmd(0x80);
  while(dis1[m]!='\0')
   writedata(dis1[m]);
   m++;
  writecmd(0x89);
  writecmd(tab[0]);
  writecmd(tab[1]);
  writecmd('.');
  writecmd(tab[2]);
  m=0;
  writecmd(0xc0);
    writedata(dis2[m]);
    m++;
  writecmd(0xc8);
  if(flagtemp)writedata('-');
  else writedata('+');
  writecmd(0xc9);
  writecmd(tab[3]);
  writecmd(tab[4]);
  writecmd('.');
  writecmd(tab[5]);
//main()????????:  AT89C51  11.0592MHz  ?????
//???????????,?????? 9600
U8 buff[4];
U8 timecount;
init_LCD();
  RH();
  display();
  Delay(2000);
ID:1 发表于 2019-4-18 23:15 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
