- // include the library code:
- #include <LiquidCrystal.h>
- #include <SPI.h>
- #include <MD_AD9833.h>
- #include "pins_arduino.h"
- /* Digital potentiometer constants */
- #define DP_nINC 4 // D4
- #define DP_UnD 3 // D3
- #define DP_nCS 2 // D2
- /* LCD Constants */
- #define LCD_D7 14 // A0
- #define LCD_D6 15 // A1
- #define LCD_D5 16 // A2
- #define LCD_D4 17 // A3
- #define LCD_E 19 // A5
- #define LCD_RS 5 // D5
- /* Function generator constants */
- #define DATA 11 // D11
- #define CLK 13 // D13
- #define FSYNC 10 // D10
- /* Other pin definition constants */
- #define VBAT 21 // A7
- #define CAP_ON 18 // A4
- #define CATHODE_PWM 9 // D9
- /* Boolean Constants */
- #define OFF false
- #define ON true
- /* Encoder constants */
- #define ENC_A 8 // D8
- #define ENC_B 7 // D7
- #define ENC_SW 6 // D6
- /* Encoder States */
- #define UP 1
- #define DOWN -1
- #define SAME 0
- /* Sequential state machine constants */
- enum OutputConstants { NOFF = 1, SINE, TRIG, SQUARE };
- enum States { StateOut = 1, StateAmplitude, Coupling, StateFreqHz, StateFreqKhz, StateFreqMhz, Brightness};
- /* Custom LCD battery characters */
- byte Bat0[8] = {0b01110, 0b11011, 0b10001, 0b10001, 0b10001, 0b10001, 0b10001, 0b11111};
- byte Bat1[8] = {0b01110, 0b11011, 0b10001, 0b10001, 0b10001, 0b11111, 0b11111, 0b11111};
- byte Bat2[8] = {0b01110, 0b11011, 0b10001, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111};
- byte Bat3[8] = {0b01110, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111, 0b11111};
- /* AD9833 & LCD Library objects definition */
- MD_AD9833 AD(FSYNC);
- MD_AD9833::channel_t chan;
- MD_AD9833::mode_t mode;
- LiquidCrystal lcd(LCD_RS, LCD_E, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
- /* Global state machine in-used variables */
- unsigned char MenuState = StateOut; // Initial state
- volatile uint8_t OutType = NOFF; // Output waveform type
- volatile uint8_t DigiPotState = 0; // Digital potentiometer wiper state
- volatile bool CouplingOn = true; // AC or DC coupling state
- volatile uint8_t BrightnessState = 0; // LCD Backlight brightness state
- /* Encoder pins state */
- volatile bool encoder_A = false;
- volatile bool encoder_B = false;
- volatile bool encoder_A_prev = false;
- /* Frequency states */
- volatile uint32_t FreqHz = 0;
- volatile uint32_t FreqKhz = 0;
- volatile uint32_t FreqMhz = 0;
- /* Function prototypes */
- volatile uint8_t *port_to_pcmask[] = { &PCMSK0, &PCMSK1,&PCMSK2 };
- static int PCintMode[24];
- typedef void (*voidFuncPtr)(void);
- volatile static voidFuncPtr PCintFunc[24] = { NULL };
- volatile static uint8_t PCintLast[3];
- void EnableInterrupts();
- void DisableInterrupts();
- void InitEncoder();
- void InitOther();
- void InitDigipot();
- void CreateLcdChars();
- byte ProcessBatteryVoltage();
- void SetLcdBrightness(int brightness);
- void PotDown();
- void PotUp();
- void InitPotState();
- void InitDevice();
- void SetADFrequency();
- void SetADOutput();
- void SetADOutType();
- void BrightnessUp();
- void BrightnessDown();
- volatile int GetEncoderPos();
- void EncoderPositionChanged();
- void MainMenu();
- /* Pin-change interrupts block */
- void PCattachInterrupt(uint8_t pin, void (*userFunc)(void), int mode)
- uint8_t bit = digitalPinToBitMask(pin);
- uint8_t port = digitalPinToPort(pin);
- uint8_t slot;
- volatile uint8_t *pcmask;
- // map pin to PCIR register
- if (port == NOT_A_PORT) return;
- else {
- port -= 2;
- pcmask = port_to_pcmask[port];
- if (port == 1) slot = port * 8 + (pin - 14);
- else slot = port * 8 + (pin % 8);
- PCintMode[slot] = mode;
- PCintFunc[slot] = userFunc;
- *pcmask |= bit;
- PCICR |= 0x01 << port;
- void PCdetachInterrupt(uint8_t pin) {
- else {
- port -= 2;
- *pcmask &= ~bit;
- if (*pcmask == 0) PCICR &= ~(0x01 << port);
- static void PCint(uint8_t port) {
- uint8_t bit;
- uint8_t curr;
- uint8_t mask;
- uint8_t pin;
- curr = *portInputRegister(port+2);
- mask = curr ^ PCintLast[port];
- PCintLast[port] = curr;
- if ((mask &= *port_to_pcmask[port]) == 0) return;
- for (uint8_t i=0; i < 8; i++) {
- bit = 0x01 << i;
- if (bit & mask) {
- pin = port * 8 + i;
- // Trigger interrupt if mode is CHANGE, or if mode is RISING and
- // the bit is currently high, or if mode is FALLING and bit is low.
- if ((PCintMode[pin] == CHANGE
- || ((PCintMode[pin] == RISING) && (curr & bit))
- || ((PCintMode[pin] == FALLING) && !(curr & bit)))
- && (PCintFunc[pin] != NULL)) {
- PCintFunc[pin]();
- /* Interrupt masking functions */
- SIGNAL(PCINT0_vect) { PCint(0); }
- SIGNAL(PCINT1_vect) { PCint(1); }
- SIGNAL(PCINT2_vect) { PCint(2); }
- /* End of pin-change interrupts block */
- /* Enable/disable encoder pin interrupts */
- PCattachInterrupt(ENC_A, EncoderPositionChanged, CHANGE);
- PCattachInterrupt(ENC_B, EncoderPositionChanged, CHANGE);
- PCdetachInterrupt(ENC_A);
- PCdetachInterrupt(ENC_B);
- pinMode(ENC_A, INPUT);
- pinMode(ENC_B, INPUT);
- pinMode(ENC_SW, INPUT);
- void InitOther()
- pinMode(VBAT, INPUT_PULLUP);
- pinMode(CAP_ON, OUTPUT);
- pinMode(CATHODE_PWM, OUTPUT);
- pinMode(DP_nINC, OUTPUT);
- pinMode(DP_UnD, OUTPUT);
- pinMode(DP_nCS, OUTPUT);
- lcd.createChar(1, Bat0);
- lcd.createChar(2, Bat1);
- lcd.createChar(3, Bat2);
- lcd.createChar(4, Bat3);
- /* Process Li-ion battery voltage state and return appropriate character */
- int BatVoltage = analogRead(VBAT);
- //Serial.println(BatVoltage);
- if (BatVoltage >= 950 && BatVoltage <= 1023) return (byte)4;
- else if (BatVoltage >= 900 && BatVoltage < 950) return (byte)3;
- else if (BatVoltage >= 850 && BatVoltage < 900) return (byte)2;
- else {
- //Serial.println("Encoder came here");
- return (byte)1;
- analogWrite(CATHODE_PWM, brightness);
- void PotDown()
- for (uint8_t i = 0; i < 4; i++) {
- digitalWrite(DP_UnD, LOW);
- digitalWrite(DP_nINC, LOW);
- delayMicroseconds(100);
- digitalWrite(DP_nINC, HIGH);
- if (DigiPotState <= 0) DigiPotState = 0;
- else DigiPotState--;
- void PotUp()
- digitalWrite(DP_UnD, HIGH);
- if (DigiPotState >= 255) DigiPotState = 255;
- else DigiPotState++;
- digitalWrite(DP_nCS, LOW);
- _delay_ms(10);
- for (uint8_t i = 0; i < 255; i++) PotDown();
- void InitDevice()
- InitEncoder();
- InitDigipot();
- InitPotState();
- InitOther();
- Serial.begin(57600);
- Serial.println("Serial logger is enabled");
- lcd.begin(16, 2);
- AD.begin();
- uint32_t u1 = FreqHz + (FreqKhz * 1000) + (FreqMhz * 1000000);
- chan = MD_AD9833::CHAN_0;
- AD.setFrequency(chan, u1);
- AD.setActiveFrequency(chan);
- switch (OutType)
- case NOFF: mode = MD_AD9833::MODE_OFF; break;
- case SINE: mode = MD_AD9833::MODE_SINE; break;
- case TRIG: mode = MD_AD9833::MODE_TRIANGLE; break;
- case SQUARE: mode = MD_AD9833::MODE_SQUARE1; break;
- default: break;
- AD.setMode(mode);
- void setup() {
- InitDevice();
- CreateLcdChars();
- SetADOutput();
- pinMode(A4,OUTPUT);
- digitalWrite(A4,HIGH);
- mode = MD_AD9833::MODE_OFF;
- AD.setMode(mode);
- SetADFrequency();
- BrightnessState = 127;
- SetLcdBrightness(BrightnessState);
- void BrightnessUp() {
- if (BrightnessState >= 250) BrightnessState = 255;
- else BrightnessState += 4;
- void BrightnessDown() {
- if (BrightnessState <= 5) BrightnessState = 0;
- else BrightnessState -= 4;
- volatile int RetVal = 0;
- encoder_A = digitalRead(ENC_A);
- encoder_B = digitalRead(ENC_B);
- delay(10);
- if((!encoder_A) && (encoder_A_prev)){
- if(encoder_B) RetVal = 1;
- else RetVal = -1;
- else RetVal = 0;
- encoder_A_prev = encoder_A; // Store value of A for next time
- return RetVal;
- switch(MenuState) {
- case StateFreqHz:
- switch(GetEncoderPos()) {
- case UP:
- if (FreqHz >= 900) FreqHz = 900;
- else FreqHz += 10;
- break;
- case DOWN:
- if (FreqHz < 10) FreqHz = 0;
- else FreqHz-= 10;
- break;
- default: break;
- SetADFrequency();
- break;
- case StateFreqKhz:
- case UP:
- if (FreqKhz >= 900) FreqKhz = 900;
- else FreqKhz += 1;
- break;
- case DOWN:
- if (FreqKhz <= 10) FreqKhz = 0;
- else FreqKhz -= 1;
- break;
- default: break;
- SetADFrequency();
- break;
- case StateFreqMhz:
- case UP:
- if (FreqMhz >= 10) FreqMhz = 10;
- else FreqMhz++;
- break;
- case DOWN:
- if (FreqMhz <= 0) FreqMhz = 0;
- else FreqMhz--;
- break;
- default: break;
- SetADFrequency();
- break;
- case StateAmplitude:
- case UP: PotUp(); break;
- case DOWN: PotDown(); break;
- default: break;
- break;
- case StateOut:
- case UP:
- if (OutType >= SQUARE) OutType = SQUARE;
- else OutType++;
- break;
- case DOWN:
- if (OutType <= NOFF) OutType = NOFF;
- else OutType--;
- break;
- default: break;
- SetADOutType();
- break;
- case Coupling:
- case UP: CouplingOn = true; break;
- case DOWN: CouplingOn = false; break;
- default: break;
- digitalWrite(CAP_ON,CouplingOn);
- break;
- case Brightness:
- case UP: BrightnessUp(); break;
- case DOWN: BrightnessDown(); break;
- default: break;
- break;
- default: break;
- void MainMenu()
- MenuState = StateOut;
- EnableInterrupts();
- bool OutConfirm = false;
- while(!OutConfirm)
- switch(MenuState)
- case StateFreqHz:
- lcd.setCursor(0,0);
- lcd.print("<Frequency: Hz >");
- lcd.setCursor(0,1);
- lcd.print("<Val:");
- lcd.setCursor(5,1);
- lcd.print(FreqHz);
- if (FreqHz <= 9) {
- lcd.setCursor(6,1);
- lcd.print(" ");
- else if (FreqHz > 9 && FreqHz <= 99) {
- lcd.setCursor(7,1);
- lcd.print(" ");
- lcd.setCursor(8,1);
- lcd.print("[Hz] >");
- if (!digitalRead(ENC_SW)) {
- while(!digitalRead(ENC_SW));
- MenuState = StateFreqKhz;
- break;
- lcd.print("<Frequency:KHz >");
- lcd.print(FreqKhz);
- if (FreqKhz <= 9) {
- lcd.print(" ");
- else if (FreqKhz > 9 && FreqKhz <= 99) {
- lcd.print(" ");
- lcd.print("[KHz] >");
- MenuState = StateFreqMhz;
- break;
- lcd.print("<Frequency:MHz >");
- lcd.print(FreqMhz);
- if (FreqMhz <= 9) {
- lcd.print(" ");
- else if (FreqMhz > 9 && FreqMhz <= 99) {
- lcd.print(" ");
- lcd.print("[MHz] >");
- MenuState = Brightness;
- break;
- lcd.print("<Amplitude in %>");
- lcd.print("<Value:");
- lcd.print((DigiPotState*100)/255);
- if ((DigiPotState*100)/255 <= 9) {
- lcd.print(" ");
- else if ((DigiPotState*100)/255 > 9 && (DigiPotState*100)/255 < 100) {
- lcd.setCursor(9,1);
- lcd.print(" ");
- lcd.setCursor(10,1);
- lcd.print(" [%] >");
- MenuState = Coupling;
- break;
- case StateOut:
- lcd.print("< Out Type >");
- lcd.print("<Out:");
- switch (OutType)
- case NOFF: lcd.print("Off >"); break;
- case SINE: lcd.print("Sine >"); break;
- case TRIG: lcd.print("Triangle >"); break;
- case SQUARE: lcd.print("Square >"); break;
- default: break;
- MenuState = StateAmplitude;
- break;
- case Coupling:
- lcd.print("< Out Coupling >");
- lcd.print("<Type:");
- switch (CouplingOn)
- case true: lcd.print(" [DC] >"); break;
- case false: lcd.print(" [AC] >"); break;
- default: break;
- MenuState = StateFreqHz;
- break;
- case Brightness:
- lcd.print("< Brightness >");
- lcd.print((BrightnessState*100)/255);
- if ((BrightnessState*100)/255 <= 9) {
- lcd.print(" ");
- else if ((BrightnessState*100)/255 > 9 && (BrightnessState*100)/255 < 100) {
- lcd.print(" ");
- OutConfirm = true;
- break;
- delay(50);
- DisableInterrupts();
- void loop() {
- /* Battery Character */
- lcd.setCursor(15, 0);
- lcd.write(ProcessBatteryVoltage());
- /* Out State */
- lcd.print("<Output:");
- lcd.setCursor(8,0);
- if (OutType != NOFF) lcd.print("ON ");
- else lcd.print("OFF");
- lcd.setCursor(11,0);
- lcd.print(" > ");
- /* Output Type */
- lcd.print("<Y:");
- lcd.setCursor(3,1);
- switch(OutType) {
- case NOFF: lcd.print("OFF "); break;
- case SINE: lcd.print("SIN "); break;
- case TRIG: lcd.print("TRN "); break;
- case SQUARE: lcd.print("SQR "); break;
- default: break;
- /* Amplitude */
- lcd.print("[A]:");
- lcd.setCursor(12,1);
- lcd.print(" ");
- lcd.setCursor(13,1);
- lcd.print(" ");
- lcd.setCursor(14,1);
- lcd.print("%>");
- MainMenu();
- delay(50);
