查看: 1399|回复: 2
IC卡号通过单片机串口在PC上显示的问题
ID:488211 发表于 2019-4-29 23:08 | 显示全部楼层 |阅读模式
RC522读卡好通过串口传到PC机显示卡号
每次都会有一个字符不一样
请问是什么问题?
代码:
  1. #include "reg52.h"
  2. #include "lcd.h"
  3. #include<stdio.h>
  4. #include <intrins.h>
  5. #include "rc522.h"
  6. unsigned char code lzdID[4]={0xE0,0x23,0xD0,0xA4};
  7. unsigned char code lhjID[4]={0x1E,0x1B,0x06,0xA3};
  8. unsigned char code lqcID[4]={0x80,0x2C,0x04,0x7D};
  9. unsigned char UID[5];
  10. unsigned char Temp[4] ;
  11. unsigned long time_20ms;
  12. char dis0[16];
  13. char dis1[16];
  14. char dis2[16];
  15. unsigned char lzdFlag ='N';
  16. unsigned char lhjFlag ='N';
  17. unsigned char lslFlag ='N';
  18. unsigned char disFlag =0;
  19. unsigned char manNum=0;
  20. unsigned char a;
  21. void Init_Timer0(void);
  22. void UsartInit(void);
  23. void uartSendStr(unsigned char *s,unsigned char length);
  24. void uartSendByte(unsigned char dat);
  25. void UsartInit()
  26. {
  27. SCON=0X50;
  28. TMOD=0X20;
  29. PCON=0X80;
  30. TH1=0XF9;
  31. TL1=0XF9;
  32. ES=1;
  33. EA=1;
  34. TR1=1;
  35. }
  36. void delay(unsigned char i)
  37. {
  38. while(i--);
  39. }
  40. void main()
  41. {
  42. unsigned char disPlace=0;
  43.     Init_Timer0();
  44. delay(100);
  45. UsartInit();
  46. delay(100);
  47. LcdInit();
  48. delay(100);
  49. LCD_Clear();
  50. delay(100);
  51. PcdReset();
  52.     PcdAntennaOn();
  53. while(1)
  54. {
  55. if(PcdRequest(0x52,Temp)==MI_OK)
  56.         {
  57.             if(PcdAnticoll(UID)==MI_OK)
  58.             {
  59.                 uartSendByte(0x00);
  60.     uartSendStr(UID,4);
  61.         uartSendByte(0x00);
  62.                 if((UID[0]==lzdID[0])&&(UID[1]==lzdID[1]))
  63.                 {
  64.                     lzdFlag ='Y';
  65.                     sprintf(dis0,"aaaaaaaa");
  66.                     LCD_Write_String(3,0,dis0);
  67.        }
  68.                 else if((UID[0]==lhjID[0])&&(UID[1]==lhjID[1]))
  69.                 {
  70.                     lhjFlag ='Y';
  71.                     sprintf(dis0,"bbbbbbbb");
  72.                     LCD_Write_String(3,0,dis0);
  73.     }
  74.                 else if((UID[0]==lqcID[0])&&(UID[1]==lqcID[1]))
  75.                 {
  76.                     lslFlag ='Y';
  77.                     sprintf(dis0,"cccccccc");
  78.                     LCD_Write_String(3,0,dis0);
  79.                 }
  80.             }
  81.
  82.   }
  83.   if(disFlag == 1)
  84.         {
  85.             manNum=0;
  86.             if(lzdFlag=='Y')
  87.             {manNum=manNum+1;}
  88.             if(lhjFlag=='Y')
  89.             {manNum=manNum+1;}
  90.             if(lslFlag=='Y')
  91.             {manNum=manNum+1;}
  92.             sprintf(dis2,"ID:");
  93.    LCD_Write_String(0,0,dis2);
  94.    sprintf(dis1,"Num:%d ",(int)manNum);
  95.             LCD_Write_String(0,1,dis1);
  96.             disFlag =0;
  97.             }
  98. }
  99.    }
  100. void Usart() interrupt 4
  101. {
  102. if(RI)
  103.     {
  104.         RI=0;
  105.     }
  106.     if(TI)
  107.     TI=0;
  108. }
  109. void Init_Timer0(void)
  110. {
  111.     TMOD |= 0x01;
  112.     TH0=(65536-20000)/256;
  113.     TL0=(65536-20000)%256;
  114.     EA=1;
  115.     ET0=1;
  116.     TR0=1;
  117. }
  118. void Timer0_isr(void) interrupt 1
  119. {
  120.     TH0=(65536-20000)/256;
  121.     TL0=(65536-20000)%256;
  122.     time_20ms++;
  123.     if(time_20ms%10==0)
  124.     {disFlag = 1 ;}
  125. }
  126. void uartSendByte(unsigned char dat)
  127. {
  128.     unsigned char time_out;
  129.     time_out=0x00;
  130.     SBUF = dat;
  131.     while((!TI)&&(time_out<100))
  132.     { time_out++;delay(100);}
  133.     TI = 0;
  134. }
  135. void uartSendStr(unsigned char *s,unsigned char length)
  136. {
  137.     unsigned char NUM;
  138.     NUM=0x00;
  139.     while(NUM<length)
  140. {   uartSendByte(*s);
  141.      s++;
  142.      NUM++;
  143.     }
  144. }
ID:123289 发表于 2019-4-30 16:28 | 显示全部楼层
你指定每次读的“块”号了吗?
ID:488211 发表于 2019-5-5 16:15 | 显示全部楼层
yzwzfyz 发表于 2019-4-30 16:28
你指定每次读的“块”号了吗?
改了下波特率然后可以了....
