- #include <iom16v.h>
- #include <macros.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define SCK_CLR PORTC&=~BIT(0)
- //拉低时钟线
- #define SCK_SET PORTC|=BIT(0)
- //拉高时钟线
- #define SCK_OUT DDRC|=BIT(0)
- #define RST_CLR PORTC&=~BIT(2)
- //拉低RST线 复位线
- #define RST_SET PORTC|=BIT(2)
- //拉高RST线
- #define RST_OUT DDRC|=BIT(2)
- //把RST设为输出
- #define IO_CLR PORTC&=~BIT(1)
- //拉低IO线 数据线
- #define IO_SET PORTC|=BIT(1)
- //拉高IO线
- #define IO_IN DDRC&=~BIT(1)
- //把IO设为输入
- #define IO_RD PINC&BIT(1)
- //从IO中读数据
- #define IO_OUT DDRC|=BIT(1)
- //把IO设为输出
- uchar const write_add[]={0x80,0x82,0x84}; //写地址,0x86,0x88,0x8c,0x8a
- //uchar code read_add[] ={0x81,0x83,0x85}; //读地址,0x87,0x89,0x8d,0x8b
- uchar const init_ds[] ={0x55,0x17,0x15,0x01,0x01,0x13,0x13};
- uchar miao,fen,shi;//,ri,yue,week,nian=0x20;
- uchar nfen=0;
- uchar nshi=0;
- /*************写一个数据到对应的地址里***************/
- void write_ds1302(uchar add,uchar dat)
- uchar i;
- RST_SET;
- IO_OUT; //把复位线拉高
- for(i=0;i<8;i++)
- { //低位在前
- SCK_CLR; //时钟线拿低开始写数据
- if(add&0x01)
- IO_SET;
- else
- IO_CLR;
- } //把地址右移一位
- SCK_SET; //时钟线拿高
- add=add>>1;
- for(i=0;i<8;i++)
- SCK_CLR; //时钟线拿低开始读数据
- if(dat&0x01)
- IO_SET;
- else
- IO_CLR;
- } //把数据右移一位
- SCK_SET; //时钟线拿高
- dat=dat>>1;
- RST_CLR; //复位线合低
- SCK_CLR;
- IO_CLR;
- /*************从对应的地址读一个数据出来***************/
- uchar read_ds1302(uchar add)
- uchar value,i;
- RST_SET;
- IO_IN; //把复位线拿高
- for(i=0;i<8;i++)
- { //低位在前
- if(add&0x01)
- IO_SET;
- else
- IO_CLR;
- SCK_SET; //时钟线拿高
- add=add>>1; //把地址右移一位
- for(i=0;i<8;i++)
- value >>= 1;
- if(IO_RD)
- value |= 0x80;
- SCK_SET; //时钟线拿高
- RST_CLR; //复位线合低
- SCK_CLR;
- IO_CLR;
- return value; //返回读出来的数据
- /*************把要的时间年月日都读出来***************/
- void read_time()
- miao = read_ds1302(0x81); //读秒
- fen = read_ds1302(0x83); //读分
- shi = read_ds1302(0x85); //读时
- // ri = read_ds1302(read_add[3]); //读日
- // yue = read_ds1302(read_add[4]); //读月
- // nian = read_ds1302(read_add[5]); //读年
- // week = read_ds1302(read_add[6]); //读星期
- /*************把要写的时间年月日都写入ds1302里***************/
- void write_time()
- write_ds1302(0x8e,0x00); //打开写保护
- // write_ds1302(write_add[0],miao); //写秒
- write_ds1302(0x82,fen); //写分
- write_ds1302(0x84,shi); //写时
- // write_ds1302(write_add[3],ri); //写日
- // write_ds1302(write_add[4],yue); //写月
- // write_ds1302(write_add[5],nian); //写年
- // write_ds1302(write_add[6],week); //写星期
- write_ds1302(0xc2,nshi); //写闹时
- write_ds1302(0xc4,nfen); //写闹分
- write_ds1302(0x8e,0x80); //关闭写保护
- void read_nao()
- nshi = read_ds1302(0xc3); //读闹钟时
- nfen = read_ds1302(0xc5); //读闹钟分
- /*************把数据保存到ds1302 RAM中**0-31***********/
- void write_ds1302ram(uchar add,uchar dat)
- add <<= 1; //地址是从第二位开始的
- add &= 0xfe; //把最低位清零 是写的命令
- add |= 0xc0; //地址最高两位为1
- write_ds1302(add,dat);
- /*************把数据从ds1302 RAM读出来**0-31***********/
- uchar read_ds1302ram(uchar add)
- add |= 0x01; //把最低位清零 是读的命令
- return(read_ds1302(add));
- /*************初始化ds1302时间***************/
- void init_ds1302()
- uchar i;
- RST_CLR; //复位线合低
- SCK_CLR;
- IO_CLR;
- i = read_ds1302ram(30);
- if(i != 3)
- i = 3;
- write_ds1302ram(30,i);
- write_ds1302(0x8e,0x00); //打开保护
- for(i=0;i<3;i++)
- write_ds1302(write_add[i],init_ds[i]); //把最高位值0 允许ds1302工作
- write_ds1302(0x8e,0x80); //关写保护
- void init_ds1302_io()
- RST_CLR; //第一次读写数据是要把io位拿低
- SCK_CLR;
- IO_CLR;
clk.7z
96.78 KB, 下载次数: 16, 下载积分: 黑币 -5
