查看: 1125|回复: 1
求看看单片机程序哪里出了问题,仿真一直出错
ID:353425 发表于 2019-5-6 13:26 | 显示全部楼层 |阅读模式
1黑币
#include<reg51.h>
sbit cs=P3^6;
uchar code tab1[200]={28,        30,        32,        34,        36,        38,        40,        42,        44,        46,        48,        50,        52,        54,        56,        58,        60,        62,        64,        66,        68,        70,        72,        74,        76,        78,        80,        82,        84,        86,        88,
        90,        92,        94,        96,        98,        100,        102,        104,        106,        108,        110,        112,        114,        116,        118,        120,        122,        124,        126,        128,        130,        132,        134,        136,        138,        140,        142,        144,        146,        148,
        150,        152,        154,        156,        158,        160,        162,        164,        166,        168,        170,        172,        174,        176,        178,        180,        182,        184,        186,        188,        190,        192,        194,        196,        198,        200,        202,        204,        206,        208,
        210,        212,        214,        216,        218,        220,        222,        224,        226,        228,        226,        224,        222,        220,        218,        216,        214,        212,        210,        208,        206,        204,        202,        200,        198,        196,        194,        192,        190,        188,
        186,        184,        182,        180,        178,        176,        174,        172,        170,        168,        166,        164,        162,        160,        158,        156,        154,        152,        150,        148,        146,        144,        142,        140,        138,        136,        134,        132,        130,        128,
        126,        124,        122,        120,        118,        116,        114,        112,        110,        108,        106,        104,        102,        100,        98,        96,        94,        92,        90,        88,        86,        84,        82,        80,        78,        76,        74,        72,        70,        68,
        66,        64,        62,        60,        58,        56,        54,        52,        50,        48,        46,        44,        42,        40,        38,        36,        34,        32,        30};
uchar shu;
        TMOD=0x01;
        TH0=0x00;
        TL0=0x78;
        EA=1;
        ET0=1;
        TR0=1;
        shu=0;
        cs=0;
void tim0() interrupt 1
        TR0=0;
        TH0=0x00;
        TL0=0x78;
        TR0=1;
        P2=tab1[shu];
        shu=shu+1;
        if(shu==199)
                shu=0;
ID:478236 发表于 2019-5-7 15:15 | 显示全部楼层
怎么出错?哪里出错?程序还是,效果?
