这是源程序:
#include<reg51.h>
uchar code KEY_TABLE[]={0x11,0x21,0x12,0x22};
uchar code a[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar code b[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
uchar code c[]={0xfe,0xfd,0xfb,0xf7,0xef};
void delay5ms(uint x)
uchar t,ms;
ms=25*x;
while(ms--)
for(t=0;t<120;t++);
void delays()
uint s=10000;while(s--);
uchar n,x,temp,key,num,i,j;
n=0;
x=5;
j=0;
for(;;)
if(j==0)
P1=a[n];
P0=c[x-1];
delay5ms(x);
n=n+1;
if(n==8)
n=0;
P3=0xf0;
if(P3!=0xf0)
delays();P3=0xf0;
if(P3!=0xf0)
temp=P3;
P3=0x0f;
key=temp|P3;
key=0xff-key;
for(i=0;i<4;i++)
if(key==KEY_TABLE)
num=i;
break;
if(num==0)
j=0;
if(num==1)
j=n;
if(num==2)
x=x-1;
if(num==3)
x=x+1;
为什么这时的P1不能正常输出??? |
