查看: 2262|回复: 0
利用dac0832与51单片机播放WAV格式音乐文件源程序
ID:547040 发表于 2019-5-27 20:33 | 显示全部楼层 |阅读模式
如题没截图
  1. /***************************************************************\
  2. name         : main.c
  3. desctiption  : mp3 main file for testing serial port
  4. author       : coolfire
  5. update       : 6/17/07
  6. /***************************************************************/
  7. #include <reg51.h>
  8. #include "compiler.h"
  9. #include "init\init.h"
  10. #include "buffer\buffer.h"
  11. #include "serial\serial.h"
  12. extern Uint32 wav_len_w;
  13. extern Uint32 wav_len_r;
  14. mode_t mode=download;
  15. void main()
  16. {
  17.         init();
  18.         loop:   switch(mode)
  19.                       {
  20.                        case idle:
  21.                            while(mode==idle);
  22.                           break;
  23.                        case download:
  24.                      while(mode==download)
  25.                      {
  26.                         if(!wav_len_w)
  27.                                                 write_buffer(serial);
  28.
  29.                         read_buffer(flash);
  30.                      }
  31.                                     break;
  32.                  case play:
  33.                           while(mode==play)
  34.                                     {
  35.                         if(!wav_len_r)
  36.                                                write_buffer(flash);
  37.                                            read_buffer(dac);
  38.                                      }
  39.                                     break;
  40.                        }
  41.         goto loop;
  42. }
waefd-1.rar (11.55 KB, 下载次数: 45)
