SHT温湿度传感器数据手册摘要:
Datasheet SHT3x-DIS
Humidity and Temperature Sensor
Fully calibrated, linearized, and temperature compensated digital output
Wide supply voltage range, from 2.4 V to 5.5 V
I2C Interface with communication speeds up to 1 MHz and two user selectable addresses
Typical accuracy of 1.5 %RH and 0.2 °C for SHT35
Very fast start-up and measurement time
Tiny 8-Pin DFN package
完整的pdf格式文档51黑下载地址:
SHT3x_DIS.pdf
(910.44 KB, 下载次数: 16)
