查看: 125|回复: 0
直流电机的PID的c程序
ID:416239 发表于 2019-6-15 20:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include"lcd1602.h"
sfr T2MOD = 0x0c9;
sbit Q0 = P2^4;
sbit Q1 = P2^5;
sbit Q2 = P2^6;
sbit Q3 = P2^7;
sbit PWM                 = P1^7;
sbit UP                         = P1^0;
sbit DOWM                 = P1^1;
sbit GORB                = P2^3; //换相
sbit ADDSPEED         = P1^2;
sbit SUBSPEED        = P1^3;
uint tuint = 65535;
uint tpwm = 1;        //pwm周期为10000us tpwm变量表示pwm高电平时间,也相当于占空比 (仿真时,频率高时,电机反应慢。在实物上要加大频率)
uchar t1_flag = 0;
uint pulse = 0;
uint t0_flag = 0;
uchar t2_flag = 0;
bit t2_over = 0;
bit Just_Get = 1;
#define         ZZ                 { Q0 = 0;Q1 = 0;Q2 = 1;Q3 = 1;}        //正转
#define         FZ                 { Q0 = 1;Q1 = 1;Q2 = 0;Q3 = 0;}        //反转
#define         STOP        { Q0 = 1;Q1 = 0;Q2 = 1;Q3 = 0;}        //停止
//禁止出现 Q0 = 0;Q1 = 1;Q2 = 0;Q3 = 1; 不然会烧掉mos管
//************************ PID *************************************
float now = 0,bef = 0,bbef = 0;         //本次采样值,上次采样值,上上次采样值
float err_now,err_bef,err_bbef;                //当前偏差,上次偏差,上上次偏差
float error_add = 0;                                //所有偏差之和
float set = 25;                                                //设定值
float kp = 25;
float ki = 25;
float kd = 0;
void delayms(uint ms)//延时?个 ms
    uchar a,b,c;
        while(ms--)
          for(c=1;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
void timer_init()
        EA = 1;
        ET0 = 1;
        ET1 = 1;
        ET2 = 1;
        TMOD = 0x15; //定时器0 计数模式 定时器1模式1
        T2MOD = 0x01;
        TH0 = TL0 = 255;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
void timer1() interrupt 3
        if(t1_flag == 0)
                t1_flag = 1;
                PWM = 1;
                TH1 = (tuint - tpwm + 1)/256;
                TL1 = (tuint - tpwm + 1)%256;
                t1_flag = 0;
                PWM = 0;
                TH1 = (tuint - 10000 + tpwm + 1)/256;
                TL1 = (tuint - 10000 + tpwm + 1)%256;
void timer0() interrupt 1
        TH0 = TL0 = 255;
        t0_flag++;
void timer2() interrupt 5
        TF2 = 0;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
        t2_flag++;
        if(t2_flag == 2)
                TR0 = 0;
                TR2 = 0;
                t2_flag = 0;
                t2_over = 1;        //表示100ms时间到
void GetPulse()
        t0_flag = 0;
        t2_flag = 0;
        TH0 = TL0 = 255;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
        TR0 = 1;
        TR2 = 1;
int PID()        //增量式PID
        int change;
        err_now = set - now;
        err_bef = set - bef;
        err_bbef = set - bbef;
        change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
        if(set >= now)
                if(set - now > 1)
                        change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
        else if(now > set)
                if(now - set > 1)
        //change = (kp + ki + kd)*(set - now) + (-kp - 2*kd)*(set - bef) + kd*(set - bbef);
        //change = kp*(set - now) + ki*(set - bef) + kd*(set - bbef);
        if(change > 0)
                printchar(1,10,'+');
                printuint(1,11,4,change);
        else if(change < 0)
                printchar(1,10,'-');
                printuint(1,11,4,-change);
        else if(change == 0)
                printchar(1,10,' ');
                printword(1,11," 0  ");
        return(change);
int PID2()                //位置式PID
        int num = 0;
        static num_bef = 0;
        error_add = error_add + err_now;  //误差累加。一旦误差为0则error_add的值不变,PID输出值不变
        num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
        if(set - now >= 0)
                if(set - now > 1)
                        num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
                if(now - set > 1)
        if(num > num_bef)
                printuint(1,11,4,num - num_bef);
        else if(num < num_bef)
                printuint(1,11,4,num_bef - num);
                printuint(1,11,4,0);
        num_bef = num;
        return((uint)num);
        lcd_init();
        timer_init();
        TH1 = TL1 = 255;
        printword(0,0,"P:");                //比例系数
        printword(0,5,"S:");                //设定值
        printword(1,0,"TPWM:");                //当前占空比
        printword(0,10,"PS:");                //当前电机反馈的每秒脉冲数
                if(GORB == 1)
                {        ZZ;                }
                {        FZ;                }
                if(ADDSPEED == 0)
                        set++;
                if(SUBSPEED == 0)
                        set--;
                if(Just_Get == 1)
                        Just_Get = 0;
                        GetPulse();
                else if(t2_over == 1)
                        t2_over = 0;
                        Just_Get = 1;
                        pulse = t0_flag;
                        bbef = bef;
