程序通过输出直接Printf_lcd 打印就可以显示,附件包含有字模取模和图片取模方式!
- 取模软件 液晶汉字字模提取
- // 汉字字模表 //
- // 汉字库: 宋体16.dot 纵向取模下高位,数据排列:从左到右从上到下 输出大小设置128*64 然后输入字符串
- #include<reg51.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
- #include<stdio.h>
- #include "delay.h"
- #include "math.h"
- #include "string.h"
- #include "ascii_hz.h"
- #include "12864.h"
- #define uchar unsigned char
- #define uint unsigned int
- sbit JIESHOU=P3^7;
- sbit led=P1^4;
- unsigned char uart_rx_finish=0;
- unsigned char uart_rx_cnt=0;
- unsigned char uart_rx_cnt_before=0;
- //char dis0[32]; //串口数据显示
- unsigned char dis2[17]; //串口数据显示
- unsigned char dis3[17]; //去掉后缀0x0d 0x0a
- unsigned long time_20ms=0; //定时器计数
- void Init_Timer0(void); //函数声明
- void SendStr(unsigned char *s,unsigned char length);
- void UART_Init(void);
- void SendByte(unsigned char dat);
- void puts_to_SerialPort(uchar *s);
- void main (void)
- uchar i=0;
- Init_Timer0(); //定时器0初始化
- UART_Init();
- InitLcd(); //初始化液晶
- puts_to_SerialPort("Receiving From 8051...\r\n");
- lcd12864_write_one(0,0,"二维码测试系统");
- lcd12864_write_one(2,0,"接收我二维码: ");
- // InitLcd(); //初始化液晶
- // tupiandisplay();
- // DelayS(5);
- while (1) //主循环
- if(JIESHOU==0){
- tupiandisplay();
- if(uart_rx_finish==1){
- uart_rx_finish=0;
- // lcd12864_write_one(2,0," ");//显示
- // lcd12864_write(4,0,dis2,"","");//显示
- uart_rx_cnt_before=uart_rx_cnt;
- uart_rx_cnt=0;
- // memset(dis2,' ',sizeof(dis2));
- // if(tx_send==0){
- // DelayMs(20);
- // if(tx_send==0) {
- // puts_to_SerialPort("PC Receiving From 8051...\r\n");
- // while(!tx_send);
- TMOD |= 0x01; //使用模式1,16位定时器,使用"|"符号可以在使用多个定时器时不受影响
- TH0=(65536-20000)/256; //重新赋值 20ms
- TL0=(65536-20000)%256;
- EA=1; //总中断打开
- ET0=1; //定时器中断打开
- TR0=1; //定时器开关打开
- void Timer0_isr(void) interrupt 1
- time_20ms++;
- if(time_20ms%50==0) //1s时间发蓝牙
- led=~led;
- SCON = 0x50; // SCON: 模式 1, 8-bit UART, 使能接收
- TMOD |= 0x20; // TMOD: timer 1, mode 2, 8-bit 重装
- PCON = 0x00;
- TH1 = 0xFD; // TH1: 重装值 9600 波特率 晶振 11.0592MHz
- TL1 = TH1;
- TR1 = 1; // TR1: timer 1 打开
- EA = 1; //打开总中断
- ES = 1; //打开串口中断
- void SendByte(unsigned char dat)//串口发送单字节数据
- unsigned char time_out;
- time_out=0x00;
- SBUF = dat; //将数据放入SBUF中
- while((!TI)&&(time_out<100)) //检测是否发送出去
- {time_out++;DelayUs2x(10);} //未发送出去 进行短暂延时
- TI = 0; //清除ti标志
- void SendStr(unsigned char *s,unsigned char length) //发送定长度字符串
- unsigned char NUM;
- NUM=0x00;
- while(NUM<length) //发送长度对比
- SendByte(*s); //放松单字节数据
- s++; //指针++
- NUM++; //下一个++
- while(*s != '\0')
- SendByte(*s);
- s++;
- DelayMs(5);
- void UART_SER (void) interrupt 4 //串行中断服务程序
- uchar c;
- if(RI) //判断是接收中断产生
- c = SBUF;
- if(c=='\n') {
- uart_rx_finish=1;
- dis2[uart_rx_cnt]='\0';
- …………限于本文篇幅 余下代码请从51黑下载附件…………
二维码显示C51_V2图片.rar
(8.66 MB, 下载次数: 235)
