- 程序名称:Keyer 自动键控制程序
- #include <STC89C5xRC.H>
- #include <intrins.h>
- #include <stdlib.h>
- #include <config.h>
- /* 定义IO端口宏 */
- #define GPIO_DIG P0 //定义数码管IO
- #define GPIO_KEY P1 //定义键盘IO
- /* 定义数码管 */
- sbit LSA = P2^2;
- sbit LSB = P2^3;
- sbit LSC = P2^4;
- /* 定义IO端口 */
- sbit BEEP = P1^5; //定义蜂鸣器
- sbit CWOUT = P2^0; //定义电键信号发送端口与LED
- sbit K1 = P3^0; //定义K1键为功能键
- sbit K2 = P3^1; //定义K2键为播放键
- sbit K3 = P3^2; //定义Dot键使用外部中断INT0
- sbit K4 = P3^3; //定义Dash键使用外部中断INT1
- /* 声明功能函数 */
- void IntConfiguration(void); //中断配置
- void Delay(uint t); //延时(t=毫秒数)
- void TimeCount(void); //计算Dot/Dash时长
- void Paddle(void); //自控电码发生
- void Straight(void); //手控电码发生
- void Space(uchar n); //间隔发生器(n=间隔数目)
- void Function(void); //功能键控制
- void PlayCall(void); //发送本台呼号
- void Display(void); //数码管显示
- void RecordInfor(void); //录入本台呼号
- void WriteSystem(void); //写入系统参数
- void Player(uchar m, uchar x[]); //发送内置信息(m=发送字符数)
- /* 声明ISP操作函数 */
- void EEPROM_Read(uint EE_address, uchar *DataAddress, uchar n); //字节读
- void EEPROM_Write(uint EE_address, uchar *DataAddress, uchar n); //字节写
- void EEPROM_SectorErase(uint EE_address); //扇区擦除
- /* 数码管显示码表,0 1 2 3 4 5 6 7 8 9 */
- const uchar code DIG_CODE[10] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F};
- /* 侧音频率表,400,500,600,700,800,900,1000Hz */
- const uchar code Tone_H[7] = {0xFB, 0xFC, 0xFC, 0xFD, 0xFD, 0xFD, 0xFE};
- const uchar code Tone_L[7] = {0x1E, 0x18, 0xBF, 0x36, 0x8F, 0xD4, 0x0C};
- /* 呼叫数组 */
- const uchar code C1[10] = {'1','0','1','0','.','1','1','0','1',' '};
- const uchar code C2[6] = {'1','0','0','.','0',' '};
- const uchar code C3[14] = {'0','1','1','0','.','0','0','0','.','0',' ','1','0','1'};
- /* 定义变量 */
- uint DotTime, DashTime; //Dot时长,Dash时长
- uint TCount, Tmax; //时长计数,时长阈值
- uchar KeyValue; //功能键值
- uchar Cmax = 54, CW_x[56]; //数组上标,录入缓存
- uchar WPM = 16; //发报速度4-60wpm (默认16wpm)
- uchar ToneFreq = 3; //侧音频率序号0-6 (默认3/700Hz)
- uchar Number; //播发字符数
- bit KeyFlg = 1; //点划交替标志(1=无点划交替)
- bit SendFlg = 0; //发送标志(1=禁止发射)
- static uint T2Count = 0; //定时器T2计数变量
- void main(void)
- /* 设定初始值 */
- IntConfiguration(); //配置中断
- if (K1 == 0) //按K1键开机进行系统重置
- WPM = 16;
- ToneFreq = 3;
- Number = 0;
- WriteSystem();
- EEPROM_SectorErase(SectorAddr_2);
- else
- EEPROM_Read(SectorAddr_1, CW_x, 3); //读系统设定参数
- if (CW_x[0] != 0xFF)
- WPM = CW_x[0];
- ToneFreq = CW_x[1];
- Number = CW_x[2];
- TimeCount(); //计算Dot/Dash时长
- TH1 = Tone_H[ToneFreq]; //设定定时器T1(侧音频率)初始值
- TL1 = Tone_L[ToneFreq];
- TR2 = 1; //开定时器T2
- /* 运行按键监测程序 */
- while (1)
- SendFlg = 0; //允许发射
- Display();
- Delay(15);
- if (K1 == 0) //功能键按下
- Delay(1000);
- if (K1 == 0)
- Function();
- if (K2 == 0 && Number > 0)
- PlayCall();
- 函 数 名:IntConfiguration
- 函数功能:设置中断参数
- IT0 = 0; //INT0为低电平触发方式
- IT1 = 0; //INT1为低电平触发方式
- EX0 = 1; //INT0中断允许
- EX1 = 1; //INT1中断允许
- TMOD = 0x12; //定时器T0工作方式为2,定时器T1工作方式为1
- PT0 = 1; //定时器T0(时长)高优先级
- PT1 = 1; //定时器T1(侧音)高优先级
- ET0 = 1; //定时器T0中断允许
- ET1 = 1; //定时器T1中断允许
- T2CON = 0x00; //定时器T2工作方式为16位自动重载定时器
- ET2 = 1; //定时器T2中断允许
- TH0 = 0x9C; //设定定时器T0为100us
- TL0 = 0x9C;
- RCAP2H = 0x0B; //设定定时器T2为每秒中断16次
- RCAP2L = 0xDC;
- EA = 1; //开总中断
- 函 数 名:Int0
- 函数功能:外部中断0触发时发送Dot
- void Int0(void) interrupt 0
- Delay(5); //消抖
- if (K3 == 0)
- if (KeyFlg == 1) //不是点划交替发送Dot
- {SEND_DOT();}
- if (K4 == 0) //点划交替发送Dash
- SEND_DASH();
- KeyFlg = 1; //清除点划交替标志
- 函 数 名:Int1
- 函数功能:外部中断1触发时发送Dash
- void Int1(void) interrupt 2
- Delay(5); //消抖
- if (K4 == 0)
- SEND_DASH();
- if (K3 == 0) //点划交替发送Dot
- SEND_DOT();
- KeyFlg = 0; //设置点划交替标志
- 函 数 名:Timer0
- 函数功能:定时器T0的中断函数,产生100us/次的延时,控制发码时长。
- void Timer0(void) interrupt 1
- TCount++;
- 函 数 名:Timer1(void)
- 函数功能:定时器T1的中断函数,控制侧音频率,ToneFre为侧音频率的序列号。
- void Timer1(void) interrupt 3
- BEEP = ~BEEP;
- 函 数 名:Timer2
- 函数功能:定时器T2的中断函数。
- void Timer2(void) interrupt 5
- TF2 = 0;
- T2Count++;
- 函 数 名:Delay
- 函数功能:1ms延时函数
- 输 入:t 延时时长 t x 1ms
- uint max = 10 * t; //计算时长阈值
- TCount = 0;
- TR0 = 1;
- while (TCount <= max); //产生延时
- TR0 = 0;
- 函 数 名:TimeCount
- 函数功能:计算Dot/Dash时长
- DotTime = 12000 / WPM;
- DashTime = 3 * DotTime;
- 函 数 名:Paddle
- 函数功能:产生自动键电码
- void Paddle(void)
- uint max = Tmax; //设定时长阈值
- TR1 = 1; //开音频振荡器
- TCount = 0; //时长计数器清零
- CWOUT = SendFlg; //设定发射状态
- TR0 = 1; //开时长计数器
- while (TCount <= max); //发送
- TR0 = 0; //关时长计数器
- CWOUT = 1; //禁止发射
- TR1 = 0; //关音频振荡器
- Space(1); //点划间隔
- T2Count = 0;
- 函 数 名:Space
- 函数功能:产生间隔
- 输 入:n 间隔数量
- uint max = n * DotTime; //计算时长阈值
- TR0 = 1; //开时长计数器
- while (TCount <= max); //产生间隔
- TR0 = 0; //关时长计数器
- 函 数 名:Function
- 函数功能:按照功能键执行相关设置
- bit p = 0;
- INT_OFF(); //关INT
- SendFlg = 1; //禁止发射
- KeyValue = 0;
- while (K1 == 0) //长按键,每1秒变换一个功能
- Delay(100); //每100ms计数一次
- if (++KeyValue > 40) //保持循环按键
- KeyValue = 0;
- if (KeyValue % 10 == 0) //到达变换时间
- switch (KeyValue)
- case 10: SEND_DASH(); break; //设定发报速度提示
- case 20: SEND_DASH(); SEND_DASH(); break; //设定侧音频率提示
- case 30: SEND_DASH(); SEND_DASH(); SEND_DASH(); break; //录入呼号提示
- KeyValue /= 10;
- T2Count = 0;
- switch (KeyValue)
- case 1: //调整发报速度
- while (K1 == 1 && T2Count <= 96) //K1按下或6秒内无键按下则退出
- Display();
- if (K4 == 0 && WPM < 60) //WPM+
- while (T2Count < 16 && K4 == 0); //松手延迟
- WPM++;
- TimeCount();
- SEND_DASH();
- p = 1;
- if (K3 == 0 && WPM > 4) //WPM-
- while (T2Count < 16 && K3 == 0 ); //松手延迟
- WPM--;
- TimeCount();
- SEND_DASH();
- p = 1;
- if (p == 1)
- WriteSystem(); //记忆参数
- SEND_DASH();
- break;
- case 2: //设定侧音频率
- Display();
- if (K3 == 0 && ToneFreq > 0) //频率减按下
- while (T2Count < 16 && K3 == 0); //松手延迟
- ToneFreq--;
- SEND_DASH();
- p = 1;
- if (K4 == 0 && ToneFreq < 6) //频率加按下
- ToneFreq++;
- SEND_DASH();
- p = 1;
- if (p == 1)
- SEND_DASH();
- break;
- case 3: //录入呼号
- RecordInfor();
- INT_ON(); //开INT
- 函 数 名:RecordInfor
- 函数功能:录入内置信息,最多10个字符
- bit k = 0; //间隔标志清零
- Number = 0; //字符数清零
- T2Count = 0; //退出计时清零
- while (K1 && Number < Cmax && T2Count <= 320) //按K1键/点划数为最大值/者20秒无按键则退出
- if (!K3) //Dot键按下
- Delay(5); //消抖
- if (!K3)
- CW_x[Number++] = '0';
- SEND_DOT();
- TCount = 0; //间隔计时清零
- TR0 = 1; //开定时器T0用于添加字符间隔
- k = 1; //设置间隔标志
- if (!K4) //Dash键按下
- Delay(5);
- if (!K4)
- CW_x[Number++] = '1';
- SEND_DASH();
- TCount = 0;
- TR0 = 1;
- k = 1;
- if (k && TCount >= DashTime) //添加字符间隔
- CW_x[Number++] = '.';
- TR0 = 0; //关定时器T0
- k = 0; //清除间隔标志
- if (Number > 0) //有信息录入则补字符间隔、记忆字符数
- if (CW_x[Number - 1] != '.')
- CW_x[Number] = '.' ;
- WriteSystem();
- 函 数 名:WriteSystem
- 函数功能:写入系统参数
- EEPROM_SectorErase(SectorAddr_1);
- CW_x[0] = WPM;
- CW_x[1] = ToneFreq;
- CW_x[2] = Number;
- EEPROM_Write(SectorAddr_1, CW_x, 3);
- 函 数 名:Player
- 函数功能:发送内置信息
- 输 入:m 发送字符数,x[]信息
- uchar j = 0;
- for (; j < m; j++)
- switch (x[j])
- case '0': SEND_DOT(); break; //发送Dot
- case '1': SEND_DASH(); break; //发送Dash
- case '.': Space(2); break; //字符间隔
- case ' ': Space(6); //单词间隔
- 函 数 名:PlayCall
- 函数功能:发送呼叫
- uchar i;
- EEPROM_Read(SectorAddr_2, CW_x, Number);
- for (i = 1; i < 4; i++)
- Player(10, C1);
- Player(6, C2);
- Player(Number, CW_x);
- Space(4);
- Player(14, C3);
- 函 数 名:Display
- 函数功能:使用数码管显示
- uchar i;
- uint f = 400 + ToneFreq * 100;
- for (i = 1; i < 9; i++)
- switch (i)
- case 1: if (WPM/10 != 0) {LSC = 1; LSB = 1; LSA = 1; GPIO_DIG = DIG_CODE[WPM / 10];} break; //显示WPM十位
- case 2: LSC = 1; LSB = 1; LSA = 0; GPIO_DIG = DIG_CODE[WPM % 10]; break; //显示WPM个位
- case 5: if (f == 1000) {LSC = 0; LSB = 1; LSA = 1; GPIO_DIG = 0x06;} break; //显示侧音频率千位
- case 6: LSC = 0; LSB = 1; LSA = 0; GPIO_DIG = DIG_CODE[(f / 100) % 10]; break; //显示侧音频率百位
- case 7: LSC = 0; LSB = 0; LSA = 1;GPIO_DIG = 0x3F; break; //显示侧音频率十位
- case 8: LSC = 0; LSB = 0; LSA = 0;GPIO_DIG = 0x3F; //显示侧音频率个位
- Delay(1);
- GPIO_DIG = 0x00; //消隐
- 函 数 名:EEPROM_SectorErase
- 函数功能:擦除一个扇区(512字节/扇区)
- 输 入:扇区地址 EE_address
- EA = 0; //关总中断
- ISP_ADDRH = EE_address / 256; //扇区地址高字节
- ISP_ADDRL = EE_address % 256; //扇区地址低字节
- ISP_ENABLE(); //允许ISP操作
- ISP_ERASE(); //扇区擦除命令
- ISP_TRIG(); //触发ISP操作
- ISP_DISABLE(); //禁止ISP操作
- EA = 1; //开总中断
- 函 数 名:EEPROM_Read
- 函数功能:读n个字节函数(最多255字节/次)
- 输 入:扇区地址 EE_address, 读出数据 *DataAddress, 读出字节数 n
- EA = 0; //关总中断
- ISP_READ(); //字节读命令
- do
- ISP_ADDRH = EE_address / 256; //地址高字节
- ISP_ADDRL = EE_address % 256; //地址低字节
- _nop_();
- *DataAddress = ISP_DATA; //读数据到指定变量
- EE_address++; //下一个地址
- DataAddress++; //下一个数据
- while (--n); //直到结束
- EA = 1; //开总中断
- 函 数 名:EEPROM_Write
- 函数功能:写n个字节数据(最多255字节/次)
- 输 入:扇区地址 EE_address,写入数据 *DataAddress,写入字节数 n
- EA = 0; //关总中断
- ISP_WRITE(); //字节写命令
- do
- ISP_ADDRH = EE_address / 256; //送地址高字节
- ISP_ADDRL = EE_address % 256; //送地址低字节
- ISP_DATA = *DataAddress; //送数据到ISP_DATA
- _nop_();
- EA = 1; //开总中断
