下面程序是在本论坛下载后修改的,下载到开发板后都能用,但是换了一个开发板之后称重模块就不能用了或者说不显示重量了,下面是显示和接线。求大神支招该怎么办?原本显示重量数字的地方现在没有任何显示。
INTRINS.H
Intrinsic functions for C51.
Copyright (c) 1988-2004 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __INTRINS_H__
#define __INTRINS_H__
extern void _nop_ (void);
extern bit _testbit_ (bit);
extern unsigned char _cror_ (unsigned char, unsigned char);
extern unsigned int _iror_ (unsigned int, unsigned char);
extern unsigned long _lror_ (unsigned long, unsigned char);
extern unsigned char _crol_ (unsigned char, unsigned char);
extern unsigned int _irol_ (unsigned int, unsigned char);
extern unsigned long _lrol_ (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
extern void _push_ (unsigned char _sfr);
extern void _pop_ (unsigned char _sfr);
#endif
