查看: 2161|回复: 1
STM32F103RCT6 RBT6核心板例程 pwm输出加adc源程序
ID:583118 发表于 2019-7-31 23:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "key.h"
  5. #include "usart.h"
  6. #include "exti.h"
  7. #include "wdg.h"
  8. #include "timer.h"
  9. #include "pwm.h"
  10. #include "oled.h"
  11. #include "adc.h"
  12. int main(void)
  13. {
  14.         u8 key;
  15.         u8 str[10];
  16.         u16 adcx;
  17.         u16 led0pwmval=0;
  18.         u16 xxx;
  19.         SystemInit();
  20.         delay_init(72);             //延时初始化
  21.         NVIC_Configuration();
  22.         uart_init(9600);
  23.         LED_Init();
  24.         OLED_Init();
  25.         Adc_Init();
  26.         KEY_Init();      //按键初始化
  27.         PWM_Init(36000,0);         //不分频。PWM频率=72000/900=80Khz
  28.
  29.         led0pwmval=0;
  30.         TIM_SetCompare2(TIM3,led0pwmval);
  31.   delay_ms(1000);
  32.          delay_ms(1000);
  33.         led0pwmval=21240;
  34.         TIM_SetCompare2(TIM3,led0pwmval);
  35.         while(1)
  36.         {
  37.                 delay_ms(10);
  38.                 TIM_SetCompare2(TIM3,led0pwmval);
  39.                 key=KEY_Scan();
  40.                 if(key)
  41.                 {
  42.                         switch(key)
  43.                         {
  44.                                 case 1:
  45.                                         LED0=!LED0;
  46.                                 led0pwmval = led0pwmval-36;
  47.                                         break;
  48.                                 case 2:
  49.                                         LED1=!LED1;
  50.                                         led0pwmval = led0pwmval+36;
  51.                                         break;
  52.                                 case 3:
  53.                                         LED0=!LED0;
  54.                                         LED1=!LED1;
  55.                                         break;
  56.                         }
  57.                 }else delay_ms(10);
  58.
  59.                                 xxx = (led0pwmval*1000)/36000 ;
  60.                                 str[0] = (xxx/100%10)+'0';
  61.                                 str[1] = (xxx/10%10)+'0';
  62.                                 str[2] = '.';
  63.                                 str[3] = (xxx%10)+'0';
  64.                                 str[4] = '\0';
  65.                                 OLED_ShowString(0,0,str);
  66.
  67.                                 adcx=Get_Adc(ADC_Channel_1);        //得到ADC转换值
  68.                                 OLED_ShowNum(0,2,adcx,4,16);    //显示ADC寄存器值
  69.
  70.                                 adcx=adcx*(3.3/4096)*1000;                        //得到ADC电压值
  71.                                 str[0] = (adcx/1000)+'0';
  72.                                 str[1] = '.';
  73.                                 str[2] = (adcx/100%10)+'0';
  74.                                 str[3] = (adcx/10%10)+'0';
  75.                                 str[4] = (adcx%10)+'0';
  76.                                 str[5] = '\0';
  77.                                 OLED_ShowString(60,2,str);
  78.                 }
  79.
  80.
  81. }
32 PWM输出实验+adc 12位 0~3.3v.7z (197.44 KB, 下载次数: 93)
收藏收藏1 分享淘帖 顶 踩
ID:238579 发表于 2020-4-10 18:49 | 只看该作者
你这压缩包里的是RB的,不是RC的
