- #include "./dac/bsp_dac.h"
- //正弦波单个周期的点数
- #define POINT_NUM 32
- /* 波形数据 ---------------------------------------------------------*/
- const uint16_t Sine12bit[POINT_NUM] = {
- 2048 , 2460 , 2856 , 3218 , 3532 , 3786 , 3969 , 4072 ,
- 4093 , 4031 , 3887 , 3668 , 3382 , 3042 , 2661 , 2255 ,
- 1841 , 1435 , 1054 , 714 , 428 , 209 , 65 , 3 ,
- 24 , 127 , 310 , 564 , 878 , 1240 , 1636 , 2048
- uint32_t DualSine12bit[POINT_NUM];
- * @brief 使能DAC的时钟,初始化GPIO
- * @param 无
- * @retval 无
- static void DAC_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- DAC_InitTypeDef DAC_InitStructure;
- /* 使能GPIOA时钟 */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- /* 使能DAC时钟 */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
- /* DAC的GPIO配置,模拟输入 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* 配置DAC 通道1 */
- DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO; //使用TIM2作为触发源
- DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; //不使用波形发生器
- DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; //不使用DAC输出缓冲
- DAC_Init(DAC_Channel_1, &DAC_InitStructure);
- /* 配置DAC 通道2 */
- DAC_Init(DAC_Channel_2, &DAC_InitStructure);
- /* 使能通道1 由PA4输出 */
- DAC_Cmd(DAC_Channel_1, ENABLE);
- /* 使能通道2 由PA5输出 */
- DAC_Cmd(DAC_Channel_2, ENABLE);
- /* 使能DAC的DMA请求 */
- DAC_DMACmd(DAC_Channel_2, ENABLE);
- * @brief 配置TIM
- * @param 无
- * @retval 无
- static void DAC_TIM_Config(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- /* 使能TIM2时钟,TIM2CLK 为72M */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
- /* TIM2基本定时器配置 */
- // TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
- TIM_TimeBaseStructure.TIM_Period = (2250-1); //定时周期 20
- TIM_TimeBaseStructure.TIM_Prescaler = 0x0; //预分频,不分频 72M / (0+1) = 72M
- TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; //时钟分频系数
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
- /* 配置TIM2触发源 */
- TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
- /* 使能TIM2 */
- TIM_Cmd(TIM2, ENABLE);
- * @brief 配置DMA
- * @param 无
- * @retval 无
- static void DAC_DMA_Config(void)
- DMA_InitTypeDef DMA_InitStructure;
- /* 使能DMA2时钟 */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
- /* 配置DMA2 */
- DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12RD_ADDRESS; //外设数据地址
- DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&DualSine12bit ; //内存数据地址 DualSine12bit
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //数据传输方向内存至外设
- DMA_InitStructure.DMA_BufferSize = POINT_NUM; //缓存大小为POINT_NUM字节
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设数据地址固定
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存数据地址自增
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word; //外设数据以字为单位
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word; //内存数据以字为单位
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环模式
- DMA_InitStructure.DMA_Priority = DMA_Priority_High; //高DMA通道优先级
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //非内存至内存模式
- DMA_Init(DMA2_Channel4, &DMA_InitStructure);
- /* 使能DMA2-14通道 */
- DMA_Cmd(DMA2_Channel4, ENABLE);
- * @brief DAC初始化函数
- * @param 无
- * @retval 无
- void DAC_Mode_Init(void)
- uint32_t Idx = 0;
- DAC_Config();
- DAC_TIM_Config();
- /* 填充正弦波形数据,双通道右对齐*/
- for (Idx = 0; Idx < POINT_NUM; Idx++)
- DualSine12bit[Idx] = (Sine12bit[Idx] << 16) + (Sine12bit[Idx]);
- DAC_DMA_Config();
DAC—输出正弦波.rar
(294.27 KB, 下载次数: 65)
