查看: 6536|回复: 9
单片机+DHT11读不出数据,求助
ID:421538 发表于 2019-8-20 19:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*程序功能:STC15W404AS,DHT11读取
*AUTHOR:BY LSK
/********************定义数据*************************/
#include <STC15F2K60S2.H>
#include <intrins.h>
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable    无符号8位整型变量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable    有符号8位整型变量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable    无符号16位整型变量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable    有符号16位整型变量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable    无符号32位整型变量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable    有符号32位整型变量 */
typedef float          F32;      /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         F64;      /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
#define   Data_0_time    4
sbit  RT_IO  = P3^3 ;//P3.3脚外部中断1
U8  U8FLAG,k;
U8  U8count,U8temp;
U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8  U8comdata;
U8  outdata[5];  //定义发送的字节数
U8  indata[5];
U8  count, count_r=0;
U8  str[5]={"DATA:"};
U16 U16temp1,U16temp2;
SendData(U8 *a)
outdata[0] = a[0];
outdata[1] = a[1];
outdata[2] = a[2];
outdata[3] = a[3];
outdata[4] = a[4];
count = 1;
SBUF=outdata[0];
void Delay(U16 j)
U8 i;
for(;j>0;j--)
  for(i=0;i<27;i++);
void  Delay_10us(void)
U8 i;
i--;
i--;
i--;
i--;
i--;
i--;
void  COM(void)
U8 i;
for(i=0;i<8;i++)
  U8FLAG=2;
  while((!RT_IO)&&U8FLAG++);
  Delay_10us();
  Delay_10us();
  Delay_10us();
  U8temp=0;
  if(RT_IO)U8temp=1;
  U8FLAG=2;
  while((RT_IO)&&U8FLAG++);
  //超时则跳出for循环
  if(U8FLAG==1)break;
  //判断数据位是0还是1  如果高电平高过预定0高电平值则数据位为 1
  U8comdata<<=1;
  U8comdata|=U8temp;        //0
//-----湿度读取子程序 ------------
void RH(void)
//主机拉低18ms
RT_IO=0;
Delay(180);
RT_IO=1;
//总线由上拉电阻拉高 主机延时20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主机设为输入 判断从机响应信号
RT_IO=1;
//判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
if(!RT_IO)   //T !
  U8FLAG=2;
  //判断从机是否发出 80us 的低电平响应信号是否结束
  U8FLAG=2;
  //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
  //数据接收状态
  COM();
  U8RH_data_H_temp=U8comdata;
  COM();
  U8RH_data_L_temp=U8comdata;
  COM();
  U8T_data_H_temp=U8comdata;
  COM();
  U8T_data_L_temp=U8comdata;
  COM();
  U8checkdata_temp=U8comdata;
  RT_IO=1;
  //数据校验
  U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
  if(U8temp==U8checkdata_temp)
   U8RH_data_H=U8RH_data_H_temp;
   U8RH_data_L=U8RH_data_L_temp;
   U8T_data_H=U8T_data_H_temp;
   U8T_data_L=U8T_data_L_temp;
   U8checkdata=U8checkdata_temp;
void RSINTR() interrupt 4 using 2
U8 InPut3;
if(TI==1) //发送中断
  TI=0;
  if(count!=5) //发送完5位数据
   SBUF= outdata[count];
   count++;
if(RI==1)  //接收中断
  InPut3=SBUF;
  indata[count_r]=InPut3;
  count_r++;
  RI=0;
  if (count_r==5)//接收完4位数据
   //数据接收完毕处理。
   count_r=0;
   str[0]=indata[0];
   str[1]=indata[1];
   str[2]=indata[2];
   str[3]=indata[3];
   str[4]=indata[4];
   P0=0;
/*----------串口发数据------------------------------------*/
U8  i,j;
//uchar str[6]={"RS232"};
/* 系统初始化 */
SCON = 0x50;  //8位数据,可变波特率
AUXR |= 0x01;  //串口1选择定时器2为波特率发生器
AUXR |= 0x04;  //定时器2时钟为Fosc,即1T
T2L = 0xE0;  //设定定时初值
T2H = 0xFE;  //设定定时初值
AUXR |= 0x10;  //启动定时器2
ES = 1;
EA = 1;           // 打开所以中断
TI = 0;
RI = 0;
SendData(str) ;   //发送到串口
Delay(1);         //延时100US(12M晶振)
    //调用温湿度读取子程序
    RH();
    //串口显示程序
    str[0]=U8RH_data_H;
    str[1]=U8RH_data_L;
    str[2]=U8T_data_H;
    str[3]=U8T_data_L;
    str[4]=U8checkdata;
    //读取模块数据周期不易小于 2S
    Delay(10000);
ID:277550 发表于 2019-8-20 22:37 | 只看该作者
先根据实际的硬件,把延时等,校准先
ID:421538 发表于 2019-8-21 00:10 | 只看该作者
是时序的问题,已经解决,谢谢各位!
ID:602185 发表于 2019-8-21 01:11 | 只看该作者
需要是大神的帮忙
ID:138097 发表于 2019-8-21 08:04 | 只看该作者
//#include "dht11.h"
#include "common.h"
//复位DHT11
void DHT11_Rst(void)
        DHT11_IO_OUT();         //SET OUTPUT
    DHT11_DQ_OUT=0;         //拉低DQ
    delay_ms(20);            //拉低至少18ms
    DHT11_DQ_OUT=1;         //DQ=1
        delay_us(30);             //主机拉高20~40us
//等待DHT11的回应
//返回1:未检测到DHT11的存在
//返回0:存在
u8 DHT11_Check(void)
        u8 retry=0;
        DHT11_IO_IN();//SET INPUT
    while (DHT11_DQ_IN&&retry<100)//DHT11会拉低40~80us
                retry++;
                delay_us(1);
        if(retry>=100)return 1;
        else retry=0;
    while (!DHT11_DQ_IN&&retry<100)//DHT11拉低后会再次拉高40~80us
                retry++;
                delay_us(1);
        return 0;
//从DHT11读取一个位
//返回值:1/0
u8 DHT11_Read_Bit(void)
        u8 retry=0;
        while(DHT11_DQ_IN&&retry<100)//等待变为低电平
                retry++;
                delay_us(1);
        retry=0;
        while(!DHT11_DQ_IN&&retry<100)//等待变高电平
                retry++;
                delay_us(1);
        delay_us(40);//等待40us
        if(DHT11_DQ_IN)return 1;
        else return 0;
//从DHT11读取一个字节
//返回值:读到的数据
u8 DHT11_Read_Byte(void)
    u8 i,dat;
    dat=0;
        for (i=0;i<8;i++)
                   dat<<=1;
            dat|=DHT11_Read_Bit();
    return dat;
//从DHT11读取一次数据
//temp:温度值(范围:0~50°)
//humi:湿度值(范围:20%~90%)
//返回值:0,正常;1,读取失败
u8 DHT11_Read_Data(u8 *temp,u8 *humi)
        u8 buf[5];
        u8 i;
        DHT11_Rst();
        if(DHT11_Check()==0)
                for(i=0;i<5;i++)//读取40位数据
                        buf[i]=DHT11_Read_Byte();
                if((buf[0]+buf[1]+buf[2]+buf[3])==buf[4])
                        *humi=buf[0];
                        *temp=buf[2];
        }else return 1;
        return 0;
//初始化DHT11的IO口 DQ 同时检测DHT11的存在
//返回1:不存在
//返回0:存在
u8 DHT11_Init(void)
        RCC->APB2ENR|=1<<4; //使能 PORTC 时钟
        GPIOC->CRL&=0XFFFFFFF0;
        GPIOC->CRL|=0X00000003;//PA0 推挽输出
        GPIOC->ODR|=1<<0; //PA4 输出高
        DHT11_Rst();  //复位DHT11
        return DHT11_Check();//等待DHT11的回应
#ifndef __DHT11_H
#define __DHT11_H
#include "sys.h"
//IO方向设置
#define DHT11_IO_IN()  {GPIOC->CRL&=0XFFFFFFF0;GPIOC->CRL|=8<<0;}
#define DHT11_IO_OUT() {GPIOC->CRL&=0XFFFFFFF0;GPIOC->CRL|=3<<0;}
////IO操作函数
#define        DHT11_DQ_OUT PCout(0) //数据端口        PC0
#define        DHT11_DQ_IN  PCin(0)  //数据端口        PC0
u8 DHT11_Init(void);//初始化DHT11
u8 DHT11_Read_Data(u8 *temp,u8 *humi);//读取温湿度
u8 DHT11_Read_Byte(void);//读出一个字节
u8 DHT11_Read_Bit(void);//读出一个位
u8 DHT11_Check(void);//检测是否存在DHT11
void DHT11_Rst(void);//复位DHT11
#endif
ID:284488 发表于 2019-8-21 08:40 | 只看该作者
可能是时间延迟没调好吧!之前我也碰到这状况,将时间延迟重新设定就正常了。
ID:644972 发表于 2019-11-20 21:07 | 只看该作者
lhxr 发表于 2019-8-21 00:10
是时序的问题,已经解决,谢谢各位!
怎么解决的啊,能说一下吗
ID:644972 发表于 2019-11-20 21:10 | 只看该作者
怎么弄啊
ID:526888 发表于 2019-11-21 22:18 | 只看该作者
就是单片机的延时代码是51的 5A的速度快12倍 需要重新写延时函数
