查看: 1012|回复: 1
壁障小车的单片机程序哪里出问题了?求帮助
ID:508300 发表于 2019-8-22 20:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
就是自己暑假自学单片机,做了一个壁障小车用了两个红外壁障模块和一个超声波模块做的一个壁障小车,可是小车的壁障却很不理想,不知道哪里出问题所以感觉可能程序有问题,请大佬帮忙看看。
#include"reg51.h"
#include"xiaoche.h"
#include"intrins.h"
typedef unsigned char u8;
typedef unsigned int u16;
char push_val_left=5;
char push_val_right=5;
u8 pwm_val_right=0;
u8 pwm_val_left=0;
u8 pwm_count=0;
char time=0;
unsigned char S=0;//???????????
void delay(unsigned int xms)
    unsigned int i,j;
for(i=xms;i>0;i--)        //i=xms??????xms????
    for(j=112;j>0;j--);
void Delay10us(unsigned int i)     //10us??????? ????????????????
    unsigned int j;
do
    j = 10;
    do
      _nop_();
  while(--j);
while(--i);
void startModle()
TX=1;
Delay10us(2);
TX=0;
void count()//?????????????
S=0;
time=TH1*256+TL1;
TH1=0;
TL1=0;
S=time*0.17+10;
void forward()
IN1=0;//????????
IN2=1;
IN3=1;
IN4=0;
void stop()//???
IN1=0;
IN2=0;
IN3=0;
IN4=0;
void back()
IN1=1;//????????
IN2=0;
IN3=0;
IN4=1;
void left()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
void right()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
void pwm_out_right_moto(void)
    if(Right_PWM_ON)
        if(pwm_val_right<=push_val_right) //20ms??????? 111 111 0000 0000 0000 00
         EN2=1;        //????6:20
         EN2=0;
     if(pwm_val_right>=20)
     pwm_val_right=0;
        EN2=0;   //??δ????PWM??EN2=0 ???? ??
void pwm_out_left_moto(void)
     if(Left_PWM_ON)
          if(pwm_val_left<=push_val_left)
            EN1=1;
            EN1=0;
          if(pwm_val_left>=20)
       pwm_val_left=0;
          EN1=0;   //??δ????PWM??EN1=0 ???? ??
void Timer0() interrupt 1
TH0 = 0xff;   //??????0.1ms
    TL0 = 0xa3;
pwm_count++;
if(pwm_count>=10)
  pwm_val_right++;
  pwm_val_left++;
  pwm_out_right_moto();
  pwm_out_left_moto();
  pwm_count=0;
TMOD|=0X11;
EA=1;
ET0=1;
ET1=0;
TR0=1;
TR1=1;
TH1=0;
TL1=0;
count();
  if((hongwai_left==0)&&(S<=300))
   stop();
   delay(50);
   right();
   delay(50);
  if((hongwai_right==0)&&(S<=300))
   stop();
   delay(50);
   left();
   delay(50);
    forward();
ID:235200 发表于 2019-8-25 23:11 | 只看该作者
   stop();
   delay(50);
   right();
   delay(50);
   stop();
   delay(50);
   left();
   delay(50);
    forward();
循环程序采取顺序结构,先判断左红外,然后判断右红外,且中间还有延时,当程序运行在左红外判断时,此时右边红外无法判断,当程序运行在右红外判断时,此时左边红外无法判断,这就是不理想的原因,程序应该两个条件同时判断,然后根据判断结果作出相应的避障措施
