查看: 6022|回复: 11
STM32+0.91寸oled滚动显示bme680测得的数据(温湿度、气压、空气质量指数)
ID:293977 发表于 2019-9-9 18:18 | 显示全部楼层 |阅读模式
https://v.youku.com/v_show/id_XM ... j.8428770.3416059.1
  1. #include "bme680.h"
  2. uint8_t bme680_data[20]={0};
  3. uint8_t aqi_accuracy;
  4. int16_t temperature,altitude;
  5. uint16_t humidity,aqi;
  6. uint32_t pressure,gas;
  7. void Bme680_Config(void)
  8. {
  9.         GPIO_InitTypeDef GPIO_InitStructure;
  10.         USART_InitTypeDef USART_InitStructure;
  11.         NVIC_InitTypeDef NVIC_InitStructure;
  12.
  13.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
  14.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
  15.
  16.         GPIO_InitStructure.GPIO_Pin = TXD;
  17.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  18.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  19.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  20.
  21.         GPIO_InitStructure.GPIO_Pin = RXD;
  22.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  23.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  24.
  25.         USART_InitStructure.USART_BaudRate = 9600;
  26.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  27.         USART_InitStructure.USART_StopBits = USART_StopBits_1;
  28.         USART_InitStructure.USART_Parity = USART_Parity_No;
  29.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  30.         USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
  31.         USART_Init(USART2, &USART_InitStructure);
  32.
  33.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  34.         NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  35.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  36.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  37.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  38.         NVIC_Init(&NVIC_InitStructure);
  39.
  40.         USART_ITConfig(USART2,USART_IT_RXNE, ENABLE);
  41.         USART_Cmd(USART2,ENABLE);
  42. }
  43. void Bme680_Init(void)
  44. {
  45.         USART_SendData(USART2,0xa5);
  46.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  47.         USART_SendData(USART2,0x55);
  48.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  49.         USART_SendData(USART2,0x3f);
  50.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  51.         USART_SendData(USART2,0x39);
  52.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  53.         Delay_ms(100);
  54.
  55.         USART_SendData(USART2,0xa5);
  56.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  57.         USART_SendData(USART2,0x56);
  58.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  59.         USART_SendData(USART2,0x02);
  60.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  61.         USART_SendData(USART2,0xfd);
  62.         while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==Bit_RESET);
  63.         Delay_ms(100);
  64. }
  65. void Bme680_Analysis(void)
  66. {
  67.         temperature=(bme680_data[4]<<8)|bme680_data[5];
  68. //        temperature=temperature/100;        //unit:0.01℃
  69.
  70.         humidity=(bme680_data[6]<<8)|bme680_data[7];
  71. //        humidity=humidity/100;        //unit:0.01%
  72.
  73.         pressure=(bme680_data[8]<<16)|(bme680_data[9]<<8)|bme680_data[10];        //unit:1Pa
  74.
  75.         aqi_accuracy=bme680_data[11]>>4;
  76.
  77.         aqi=((bme680_data[11]&0x0f)<<8)|bme680_data[12];
  78.
  79.         gas=(bme680_data[13]<<24)|(bme680_data[14]<<16)|(bme680_data[15]<<8)|bme680_data[16];
  80.         //unit:1ohm
  81.
  82.         altitude=(bme680_data[17]<<8)|bme680_data[18];        //unit:1m
  83. }
全部资料51hei下载地址:
程序.7z (276.04 KB, 下载次数: 208)
ID:245560 发表于 2019-9-28 10:44 | 显示全部楼层
串口传感器模块。。。。。
ID:639532 发表于 2019-11-11 10:23 | 显示全部楼层
终于找到一个bme680的demo了
ID:641369 发表于 2019-11-13 18:58 | 显示全部楼层
留 个记号。
ID:645263 发表于 2019-11-19 19:09 | 显示全部楼层
终于找到一个bme680的demo了
ID:168554 发表于 2019-11-20 09:42 | 显示全部楼层
分享的是hex文件还是源码呀
ID:261620 发表于 2020-2-13 18:45 | 显示全部楼层
这个程序是串口模块的,,,,  只是数据的解析   不是底层的数据处理
ID:64016 发表于 2020-5-15 16:22 | 显示全部楼层
终于找到一个bme680的demo了
ID:142699 发表于 2020-7-17 17:38 | 显示全部楼层
这个没啥用啊,你都已经封装好了,就当成串口用了,有啥好研究的,BME的IIC底层驱动实现才有价值
ID:757976 发表于 2020-7-17 17:50 | 显示全部楼层
模块代码,很不错,谢谢分享
ID:107741 发表于 2022-2-16 21:10 | 显示全部楼层
用串口读取一个内解算模块,问题是解算模块有卖的吗?指令集有吗?
ID:1005649 发表于 2022-2-18 10:25 | 显示全部楼层
正在学习bme680的驱动,非常感谢.
