查看: 987|回复: 4
error C141: syntax error near 'ADDR3' Keil错误求解
ID:521078 发表于 2019-9-12 08:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
点亮一小灯 然后从左到右,
#include <reg52.h>
sbit LED   = P0^0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
   unsigned int i = 0;
   unsigned char cnt = 0;
   unsigned char sec = 0;
   unsigned char dir = 0;
   unsigned char shift = 0x01
   ADDR3 = 1;
   ENLED = 0;
   ADDR2 = 1;
   ADDR1 = 1;
   ADDR0 = 0;
   TMOD = 0x01;
   TH0  = 0xB8;
   TL0  = 0x00;
   TR0  = 1;
   while (1)
              if (TF0 == 1)
                  TF0 = 0;
                  TH0 = 0xB8;
                  TL0 = 0x00;
                  cnt++;
                  if(cnt >=100)
                     cnt = 0;
                     LED = ~LED;
                               P0 = ~shift;
                               for(i=0; i<30000; i++);
                                 if (dir == 0)
                                  shift = shift << 1;
                                   if ( shift == 0x80)
                                dir = 1;
                                 shift = shift >> 1;
                                  if (shift == 0x01)
                                       dir = 0;
ID:521078 发表于 2019-9-12 08:54 | 只看该作者
从右到左    亮灭一直显示SXLSD.C(20): error C141: syntax error near 'ADDR3'  谢谢大佬们
ID:610816 发表于 2019-9-12 10:37 | 只看该作者
unsigned char shift = 0x01后面缺少分号;
ID:351097 发表于 2019-9-12 11:14 | 只看该作者
unsigned char shift = 0x01  这条语句少了分号
ID:302759 发表于 2019-9-12 15:27 | 只看该作者
注意标点符号,基本语法的错误编译的时候是可以检查出来的。
