查看: 1953|回复: 1
单片机+蜂鸣器播放生日歌
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. sbit SPK = P2^7;
  6. uchar tone_h;                //高音
  7. uchar tone_l;                //低音
  8. uint note = 1;                //音符
  9. uchar beat;                        //节拍
  10. uchar code chuzhi[3][16]={  //音调对应的计数初值
  11.          0xff,0xff,//占0位
  12.          0xf8,0x8c,//低1
  13.          0xf9,0x5b,//  2
  14.          0xfa,0x15,//  3
  15.          0xfa,0x67,//  4
  16.          0xfb,0x04,//  5
  17.          0xfb,0x90,//  6
  18.          0xfc,0x0c,//低7
  19.
  20.          0xff,0xff,//占0位
  21.          0xfc,0x44,//中1
  22.          0xfc,0xac,//  2
  23.          0xfd,0x09,//  3
  24.          0xfd,0x34,//  4
  25.          0xfd,0x82,//  5
  26.          0xfd,0xc8,//  6
  27.          0xfe,0x06,//中7
  28.
  29.          0xff,0xff,//占0位
  30.          0xfe,0x22,//高1
  31.          0xfe,0x56,//        2
  32.          0xfe,0x85,//        3
  33.          0xfe,0x9a,//        4
  34.          0xfe,0xc1,//        5
  35.          0xfe,0xe4,//        6
  36.          0xff,0x03 //高7
  37.         };
  38. //****** 测试曲谱 ****** 个位:音调 ,十位:低中高音 对应 0 1 2,千百位:节拍 1~16
  39. uint code test2[] = {        120, //曲速 暂时未用到
  40.         401,402,403,404,405,406,407,
  41.         611,612,613,614,615,616,617,
  42.         821,822,823,824,825,826,827,
  43.         0xffff        //0xffff表示结尾
  44. };
  45. //****** 生日快乐 ******
  46. uint code test[] = { 120,
  47.         205,205,406,405,411,807,
  48.         205,205,406,405,412,811,
  49.         205,205,415,413,411,407,406,
  50.         314,114,413,411,413,812,
  51.         305,105,406,405,411,807,
  52.         305,105,406,405,412,811,
  53.         305,105,415,413,411,
  54.         407,406,314,114,413,411,412,811,410,
  55.         0xffff
  56. };
  57.
  58. void delayms(uint ms)          /*ms 等于1时,延时1ms 等于2时,延时2ms,以此类推*/
  59. {
  60.         uchar a,b,c;                                   //+3
  61.         while(ms--)
  62.     {
  63.          for(c=1;c>0;c--)                        //         1+2 = 3
  64.         for(b=142;b>0;b--)                  //        1*( 1+142*2)) = 285
  65.             for(a=2;a>0;a--);        //         142*(1+2*2) = 710
  66.         }
  67. }
  68. void delay125ms(uint pai)  //延时 ?*125ms 即?个节拍
  69. {
  70.     uchar a,b,c;
  71.         while(pai--)
  72.         {
  73.         for(c=239;c>0;c--)
  74.                 for(b=104;b>0;b--)
  75.                         for(a=1;a>0;a--);
  76.         }
  77. }
  78. void timer0() interrupt 1
  79. {
  80.         TH0 = tone_h;
  81.         TL0 = tone_l;
  82.         SPK = ~SPK;
  83. }
  84. void timer_init()
  85. {
  86.         EA = 1;
  87.         ET0 = 1;
  88.         PT0 = 1;
  89.         TMOD = 0x11;
  90.         TH0 = 255;
  91.         TL0 = 255;
  92. }
  93. void main()
  94. {
  95.         timer_init();
  96.         note = 1;
  97.
  98.         while(1)
  99.         {
  100.                 if(test[note] == 0xffff)
  101.                 {
  102.                         note = 1;
  103.                 }
  104.                 if(test[note]%10 != 0)        //音调不为0 【音调为0时表示不发声,但有节拍】
  105.                 {
  106.                         tone_h = TH0 = chuzhi[test[note]%100/10][(test[note]%10)*2 ];                //音调高位 【二维数组 第1维表示低中高音,第二维表示音调】
  107.                         tone_l = TL0 = chuzhi[test[note]%100/10][(test[note]%10)*2 + 1];        //音调低位
  108.                         TR0 = 1;
  109.                 }
  110.                 delay125ms(test[note]/100);        //节拍
  111.                 TR0 = 0;
  112.                 delayms(30);
  113.                 note++;                                                //下一个音符
  114.
  115.         }
  116.
  117. }
收藏收藏1 分享淘帖 顶 踩
ID:719215 发表于 2020-6-24 15:50 | 只看该作者
谢谢楼主,很有用
