查看: 2317|回复: 1
关于AD7193的驱动 stm8s单片机SPI代码编写问题
ID:610433 发表于 2019-10-10 16:59 | 显示全部楼层 |阅读模式
下了官方的驱动,但是spi初始化以及读取自己写的,出现了问题,关于spi不太懂他的步骤看一下我哪里写错了?
unsigned char SPI_Read7193(unsigned char slaveDeviceId,
                       unsigned char* data,
                       unsigned char bytesNumber)
  unsigned char byte = 0;
  if(slaveDeviceId == AD7193_SLAVE_ID)PMOD1_CS_LOW;
  for(byte = 0; byte < bytesNumber; byte++)
    while(SPI_GetFlagStatus(SPI_FLAG_RXNE) == RESET);
    *data++ = SPI_ReceiveData();
  if(slaveDeviceId == AD7193_SLAVE_ID)PMOD1_CS_HIGH;
  return bytesNumber;
unsigned char SPI_Write7193(unsigned char slaveDeviceId,
    while(SPI_GetFlagStatus(SPI_FLAG_TXE) == RESET);
    SPI_SendData(*data++);
  return bytesNumber;
这个是官方给的别的单片机的例子,我不太了解这个单片机和寄存器,你们可以参考一下
unsigned char SPI_Read(unsigned char slaveDeviceId,
    if(slaveDeviceId == 1)
        PMOD1_CS_LOW;
    if(slaveDeviceId == 2)
        ST7579_CS_LOW;
        SIO10 = data[byte];
        __no_operation();
        __no_operation();
        while(SSR02 & 0x0040);
        data[byte] = SIO10;
        PMOD1_CS_HIGH;
        ST7579_CS_HIGH;
    return bytesNumber;
* @brief Writes data to SPI.
* @param slaveDeviceId - The ID of the selected slave device.
* @param data - Data represents the write buffer.
* @param bytesNumber - Number of bytes to write.
* @return Number of written bytes.
unsigned char SPI_Write(unsigned char slaveDeviceId,
    unsigned char read = 0;
        PMOD1_CS_LOW;
        ST7579_CS_LOW;          // Assert CS low
        SIO10 = data[byte];
        __no_operation();
        __no_operation();
        read = SIO10;
        PMOD1_CS_HIGH;
        ST7579_CS_HIGH;         // Assert CS high
    return bytesNumber;
ID:282850 发表于 2019-10-11 09:23 | 显示全部楼层
同系列的SPI都会不同,如MSP430的F149 与F2553程序差异大,你问题又没说清,没人能帮你
